Qnap [ QJDK8 ] [ 1.8.333.0 ] Java Development Kit (dépendance)
QoolBox
Représentant QNAP
2 Janvier 2014
10 565
163
153
50
www.qnap.com
Dépendance JDK8 pour les applications nécessitant JAVA.
Download QJDK8: x86, x64, arm64, x31, x41
https://qnapclub.eu/fr/qpkg/195
A propos :
module passif, les développeurs doivent exporter JAVA_HOME dans /op/QJDK8
Hi QoolBox
Is there a QJDK for TS-221?
I guess TS-221 need arm-x19 version, because I can install QGit_2.8.1_arm-x19.qpkg.
hard to find binaries for armv5
not sure it is possible, and a bit dangerous use java application on such server... Java like to eat your NAS memories :geek:
QoolBox a dit:
Hi QoolBox
Thanks for reply!
If you find the qpkg, please tell me.
thanks a lot!
most likely need a newer 64bit version of JRE.
why not try QJDK8? from QNAP Stephane?
"JDK is a superset of JRE, and contains everything that is in JRE, plus tools such as the compilers and debuggers necessary for developing applets and applications. JRE provides the libraries, the Java Virtual Machine (JVM), and other components to run applets and applications written in the Java programming language"
https://www.forum-nas.fr/viewtopic.php?f=21&t=1595
does this mean it's better than JRE ? o_O
I tried uninstall JRE and use JDK8 instead, but qsirch no longer works, as it uses JRE as a dependency :?
JDK8 is embedding JRE (look inside the directory) /opt/QJDK8
JDK is fully dev environnement, and has many more library than based JRE required by many application
Are you sure it is a problem related to QJDK? What system version are you running? What Qmono version?
Pour info, dans le repo de qnapclub il y a encore la version 101 au lieu de 111. Au moins en regardant par QTS.
giopas a dit:
Sorry, for lack of Information. Let me rectify.
- TS-459 Pro II 3GB Ram x86
- Firmware 4.2.2.20161028 Scheduled update to 4.2.2.20161208 this weekend
- QJDK8 1.8.111 (disabled/stopped) and http://download.qnap.com/QPKG/JRE_8.65.0-0225_x86.zip maintainer: Optimus (Enabled and Active)
- QMONO 4.2.1.0 as found Sonarr is most stable with that version also tried v4.4.2 and 4.6.x but was unstable
For test purposes I've done:
- Disabling JRE and enabling QJDK8 1.8.111 where Sonarr do not start
- Uninstall JRE and enabling QJDK8 1.8.111 Sonarr do not start and complain no JRE on install
- Uninstall QJDK8 1.8.111 and installing JRE Sonarr works
- Installing and disabling QJDK8 1.8.111 while JRE installed and active Sonarr Works (My Current settings)
Note I have full access to ".QPKG" folder (Using ln -s) and add-on source files if needed.
giopas a dit:
Version I have installed is http://www.qnapclub.eu/provider.php/qpkg_dwl/99372/QJDK8_1.8.111_x86.qpkg from http://store.qnapclub.eu/store.php repo
Encore une fois, il parait qu'il y a un problème avec les paquet téléchargé par le repository.
En effet j'ai téléchargé QJDK8 1.8.111 par qnapclub.eu (à travers QTS 4.3 beta) et KeyBox (duquel il dépend) ne marchait pas. J'ai donc téléchargé le paquet (en utilisant Download Station, donc même connection) à partir de ce site et KeyBox marche.
L'installation du QJDK 1.8.71 s'est correctement effectuée et est démarré. Mais impossible d'executer une comme java -jar ... Avez vous une explication ?
