Qnap [ Calibre Web ] [ 0.6.19.0 ] Calibre-Web is a web app providing a clean interface for browsing Ebook
QoolBox
Représentant QNAP
2 Janvier 2014
10 562
163
153
50
www.qnap.com
Sourcehttps://github.com/janeczku/calibre-web
Download
Apache80 : https://www.myqnap.org/product/calibre-web80/
Apache81 : https://www.myqnap.org/product/calibre-web81/
Apache82 : https://www.myqnap.org/product/calibre-web82/
Dependency : Apache80
Features
Bootstrap 3 HTML5 interface
full graphical setup
User management with fine-grained per-user permissions
Admin interface
User Interface in brazilian, czech, dutch, english, finnish, french, german, greek, hungarian, italian, japanese, khmer, polish, russian, simplified chinese, spanish, swedish, turkish, ukrainian
OPDS feed for eBook reader apps
Filter and search by titles, authors, tags, series and language
Create a custom book collection (shelves)
Support for editing eBook metadata and deleting eBooks from Calibre library
Support for converting eBooks through Calibre binaries
Restrict eBook download to logged-in users
Support for public user registration
Send eBooks to Kindle devices with the click of a button
Sync your Kobo devices through Calibre-Web with your Calibre library
Support for reading eBooks directly in the browser (.txt, .epub, .pdf, .cbr, .cbt, .cbz, .djvu)
Upload new books in many formats, including audio formats (.mp3, .m4a, .m4b)
Support for Calibre Custom Columns
Ability to hide content based on categories and Custom Column content per user
Self-update capability
"Magic Link" login to make it easy to log on eReaders
Login via LDAP, google/github oauth and via proxy authentication
QPKG Integration
Point your browser to http://localhost:8083 or http://localhost:8083/opds for the OPDS catalog
Set Location of Calibre database to the path of the folder where your Calibre library (metadata.db) lives, push "submit" button
Merci pour cette appli mais quelqu'un a réussi a configurer un BD Calibre dessus ? j'ai bien créé le repertoire avec la BD sur le server mais j'ai toujours "emplacement DB incorrect"
tu met quoi dans ton chemin
il faut mettre le chemin relatif... si tu as mis dans un partage "Public" = "/share/Public"
Bonjour @QoolBox ,
Il y a quelques mises à jour depuis la dernière version que tu proposes.
Possible de faire un nouveau QPKG stp ?
Par avance merci.
Fabwiss.
@QoolBox
En fait il y a un truc qui m'intrigue.
QTS me dit que j'ai la dernière version installée...
...et pourtant Calibre Web me dit tout le contraire
Inévitablement, je lance la RECHERCHER LES MISES A JOUR et on me propose bien la version 0.6.18
Si je poursuis sur EFFECTUER LA MISE A JOUR, j'ai un message d'erreur :(
Aurais-tu une idée pour forcer la mise à jour stp ?
Merci bien pour ton aide ;)
Fabwiss.
J'ai redémarré le serveur puis tenté une nouvelle mise à jour et tout a fonctionné.
Toutefois, j'ai un nouveau problème. Je n'ai pas le bouton permettant d'envoyer en un clic l'epub sur la Kindle.
C'est normalement, une fonctionnalité de base. Le serveur mail est installé et est fonctionnel (test envoi courriel OK).
Une piste ?
un autre navigateur peut être ?
Hello @QoolBox
Je ne pense que le problème vienne de là.
Tests effectués sur :
  • Safari (Mac et iPhone)
  • Chrome (Mac)
  • Firefox (PC)
  • Brave (iPhone)
Aucun de ces navigateurs ne me proposent le lien pour envoyer l’EPUB directement sur le Kindle. Je m’arrache les cheveux à ne rien y comprendre.
Par ailleurs, j’ai également changé le thème de Calibre Web. Inévitablement, que ça soit sur l’un ou sur l’autre, toujours pas de lien ?
Fabwiss.
@QoolBox,
Il y a une chose que je ne comprends pas.
Voici ce que j'ai fait :
  1. Suppression de cette application
  2. Reboot du NAS
  3. Ré installation du QPKG
A chaque fois, il me dit que la version installée est la 0.6.13...
... alors que le QPKG dit que normalement il s'agit de la version 0.6.18.1
Comment je peux faire pour supprimer toute trace de version précédente ?
Une idée/piste stp ?
désolé j' ai pas compris...
si tu installes la 0.6.18.1 .. tu dois te retrouver avec cette version
Ben justement, tout le problème est bien là.
Depuis QTS je lance bien l'installation de la version disponible (la 0.6.18.1). Néanmoins, depuis CALIBRE WEB il me dit que c'est la version 0.6.13 qui est installée.
Je t'avoue que j'en perds mon latin :-(
je ré ouvre ce dossier venant d'installer apache80 et calibre-web sur mon QNAP. j'ai choisi /share/ebook/ comme dossier pour la base de données mais je n'ai pas de base vierge ou puis je la trouver ? merci j'ai ce message : DB Location is not Valid, Please Enter Correct Path
bon j'ai trouvé sur github un fichier vierge que j'ai copié et ca a démarré . par contre maintenant quand je veux téléverser plusieurs fichier j'ai ce message
413 Request Entity Too Large​
avez vous ce pb ?
