Qnap [ Pomerium ] [ 0.13.1 ] an identity-aware proxy that enables secure access to internal applications
QoolBox
Représentant QNAP
2 Janvier 2014
10 562
163
153
50
www.qnap.com
source : https://www.pomerium.io/docs/installation.html
Download :
----QPKG Integration------
before use be sure to fillup correctly /opt/Pomerium/config.yaml and restart QPKG
read documentation : https://www.pomerium.com/docs/quick-start/binary.html
Pomerium is an identity-aware proxy that enables secure access to internal applications. Pomerium provides a standardized interface to add access control to applications regardless of whether the application itself has authorization or authentication baked-in. Pomerium gateways both internal and external requests, and can be used in situations where you'd typically reach for a VPN.
Pomerium can be used to:
provide a single-sign-on gateway to internal applications.
enforce dynamic access policy based on context, identity, and device state.
aggregate access logs and telemetry data.
perform delegated user authorization for service-based authorization systems:
Istio
Google Cloud
provide unified identity attestation for upstream services:
Kubernetes
Grafana
Custom applications
provide a VPN alternative
