Qnap [ SabNZBdPlus 3 ] [ 4.0.1.0 ] The automated Usenet download tool
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
logo-full.svg
Source https://sabnzbd.org
Downloadx64 , arm64
Apache81 : https://www.myqnap.org/product/sabnzbdplus-apache81/
Apache82 : https://www.myqnap.org/product/sabnzbdplus-apache82/
QPKG Integration
This QPKG run on port 9292 by default HTTP
cross compiled with unrar 5.9.4 and Par2CMD Line (MT) ( https://github.com/jkansanen/par2cmdline-mt )
config file /opt/QSabNZBd3/SAB_CONFIG/config.ini
logs file /opt/QSabNZBd3/SAB_CONFIG/logs
About
Small and large screens
With the responsive Glitter interface, you can access SABnzbd and manage your downloads from any device: desktop, tablet or phone. Others have made Android/iOS (LunaSea), Android (nzb360) and iOS (nzbUnity) apps to manage SABnzbd.
Integrates with other tools
Apps like Sonarr, SickChill, Radarr, Headphones, Lidarr and more can integrate with SABnzbd and automate your download process.
SABnzbd can also read and process RSS feeds, activate custom scripts and notify you.
In 16 languages
SABnzbd now ships with 16 localizations:
English, Dansk, Deutsch, Español (castellano), Français, Nederlands, Norsk bokmål, Polski, Português Brasileiro, Româna, Suomi, Svenska, русский язык, српски, עִבְרִית‎‎, 简体中文.
thanks.
What is the best way to migrate from qsabnzbd 2.3.9 to the this application?
Thanks
Lenny
Edit: Possiblement spécifique à Firefox... Chrome ne se plaint pas du certificat. ?
Le certificat d'encryption pour qnapclub.eu semble avoir été révoqué. impossible de télécharger les apps...
"An error occurred during a connection to cdn.qnapclub.eu. Peer’s Certificate has been revoked.
Error code: SEC_ERROR_REVOKED_CERTIFICATE"
Sub_Dude a dit:
Oui la meme de mon coté, par contre c'est sur tous les navigateurs
SABnzbd 3.3.0
Release Notes - SABnzbd 3.3.0
Changes since 3.2.1
The External internet access will automatically detect local network
and no longer requires local network ranges to be defined. Custom ranges
can still be defined through local_ranges in Special settings.
Allow setting inet_exposure from the command line.
Support prefix and netmask for Special setting local_ranges.
The Unwanted extensions detection can be set to Whitelist-mode.
This will block or pause all jobs with non-matching extensions.
Servers article statistics are shown in K, G, M-notation.
Resolution added as a pattern key (%r) for Sorting.
Optimized performance of par2 file parsing.
CPU usage optimizations in the download process.
Revised handling of categories, scripts, and priorities when adding NZB's.
Download statistics are also shown when no History is shown.
Confirm rename if Direct Unpack is active for the job.
Obfuscated-RAR detection will always be performed.
All requests will be logged, not just API calls.
Stability improvement to encrypted RAR-detection.
Allow missing extensions in Unwanted extensions detection.
Removed Special setting max_art_opt.
Add notification that Plush will be removed in 3.4.0.
Windows/macOS: Update UnRar to 6.0.1.
Windows: Update Multipar to 1.3.1.7 (adds faster verification).
Bugfixes since 3.2.1
Prevent failed post-processing if job name ends in multiple dots or spaces.
Failing articles could result in jobs being stuck at 99%.
Jobs could be stuck in the queue or duplicate if they had missing articles.
Prevent jobs getting stuck at 99% due to unreliable servers.
CRC/yEnc errors would be counted twice as bad articles.
Some NZB files would incorrectly be marked as empty.
API-call history would not filter active post-processing by nzo_ids.
Login page could be accessed even if External internet access was set
to No access. Any other calls would still be blocked.
Ignore duplicate files inside messy NZB's.
Windows: Deobfuscate final filenames could fail to deobfuscate.
macOS: Disk space would be incorrect for very large disks.
Upgrade notices
The download statistics file totals10.sab is updated in 3.2.x
version. If you downgrade to 3.1.x or lower, detailed download
statistics will be lost.
Release Notes - SABnzbd 3.6.0​
Changes since 3.5.3​
  • Significantly increased performance by using the yEnc-decoding
    library of @animetosho. Usenet articles are now decoded using
    specialized CPU instructions (SIMD) on x86 and ARM systems.
  • Create and restore a backup of configuration and database.
  • Show source of lower download speed (CPU or disk).
  • Added keyboard shortcuts (Pause, Add, Status, Config).
  • Result of the Deobfuscate step is listed in History details.
  • Path of Default category will be used if category doesn't have one.
  • Disabling api_warnings prevents showing Access Denied
    information to the external client.
  • Jobs with Force priority will always skip the duplicate check.
  • Added ext_rename_ignore to add custom extensions that should
    be ignored during the Deobfuscate step.
  • Removed Indexer Feedback Integration.
  • Removed included Deobfuscate.py as it is outdated.
  • Show a warning when there are no valid news servers active.
  • Show a warning if the filesystem does not support special characters.
  • Allow multiple parameters to be passed to par2cmdline/Multipar.
  • Linux: Added AppStream metadata, desktop shortcut and MimeInfo.
  • Linux: Added support for bash completion.
  • macOS: Application and included tools fully native on M1 systems.
  • macOS/Windows: Updated UnRar to 6.10 and 7-Zip to 21.07.
  • Windows: Updated MultiPar to v1.3.2.3.
API changes since 3.5.3​
  • Removed several (status) fields from the queue API call.
  • Remove unused and undocumented API calls: addid, options, rescan,
    osx_icon, set_speedlimit, get_speedlimit, set_colorscheme.
  • Removed undocumented xcat parameter.
  • None values in XML API-output are left empty.
  • Adding NZB's would not always return nzo_ids.
  • Prevent crash in history call during post-processing.
Bugfixes since 3.5.3​
  • Extended timeout when measuring system performance.
  • Interface settings were sometimes reset on page reload.
  • Par2 sets with duplicate names could skip verification and repair.
  • Ignore .par2 files that could not be parsed.
  • Correctly default to Glitter - Auto on new installs.
  • Download speed was not updated when stalled due to disk performance.
  • Prevent traceback when status functions timeout.
  • Prevent crash if not enough repair blocks are available.
  • Prevent crash when there is an unknown language setting.
  • Source release had Windows line-endings.
  • Windows: If a job password contained a double quote it
    would not be picked up by UnRar and unpack would fail.
Release Notes - SABnzbd 3.6.1​
Bugfixes since 3.6.0​
  • Downloads in Checking status were not displayed correctly.
  • Prevent showing crash on Status window during shutdown.
  • Prevent scheduler crash if removed event is canceled.
  • Updated UnRar to 6.11 (Windows) and 6.12 (macOS).
  • macOS/Windows: Updated dependencies and Python versions.
sabyenc module require a newer gcc to be compiled .. become harder to supply update for armv7 32bit due to old embedded glibc in firmware
OK I guess I have to downgrade my version to 3.5.1.0 because 3.6.0.1 needs SAByenc 5.4.2 that is not included with the qpkg.
Release Notes - SABnzbd 3.7.0​
Changes since 3.6.1​
  • The queue and history can be filtered using keywords:
    cat and priority. For example: show name cat:tv.
  • Use shortcut shift + arrow-key to navigate the queue/history pages.
  • The backup is now created in a local folder for security.
  • Recurring backups can be configured using the scheduler.
  • Improvements to Deobfuscate Final Filenames.
  • RSS overview shows the rule that accepted the job.
  • Added option to sort the queue by % downloaded.
  • Added option to replace underscores with dots in folder names.
  • SABnzbd Host input will be validated before being applied.
  • Moved system load information from the main page to the Status window.
  • Console logging is now written to stdout instead of stderr.
  • Removed Special settings enable_meta, disable_key,
    replace_illegal, osx_speed and show_sysload.
  • Merged Special settings win_menu and osx_menu into tray_icon.
  • macOS/Windows: Use Python 3.11, slightly boosting overall performance.
  • macOS/Windows: Updated UnRar to 6.12.
  • Windows: Updated MultiPar to 1.3.2.5.
API changes since 3.6.1​
  • Minor improvements in API performance.
  • Removed fields scripts and categories from queue API call.
  • Moved loadavg from queue to status API call.
Bugfixes since 3.6.1​
  • Free Space Detection was too strict when using Direct Unpack.
  • File uploads with special characters would be parsed incorrectly.
  • Passwords from NZB meta-data were tried multiple times.
  • Passwords were not always supplied to the pre-queue script.
  • RSS-feed names were not sanitized when renamed.
  • Make sure short-dates are detected as YY-MM-DD in Sorting.
  • Show the custom job name in History when the NZB could not be fetched.
Bonsoir
J'ai installé Sabnzbd sur mon nas qnap via le package fournit sur qnapclub store. tout fonctionne parfaitement, sauf que le User qui créer le répertoire est admin . Première chose comment fait il ? le user admin était désactivé.
je l'ai activé ensuite pour le SSH et me connecter
je vois le répertoire qu'a telechargé Sabnzbd en étant connecte en ssh sous admin, mais rien ne s'affiche dans PLEX. chose bizarre, j'ai changé le owner du fichier en XXXX qui corresponds à mon compte Admin. et les droits du fichier en 777 ( pour le test ) mais le dossier n'apparait pas ni dans Filestation en etant connecte sous mon compte XXXXX admin, ni dans plex. je comprends pas...ca m'enerve
Si je me connecte au nas sous le vrai compte admin pareil , le dossier n'apparait pas dans filestation
j'ai meme change les droits du repertoire "." en 777 pareil
drwxrwxrwx 2 XXXXX everyone 4096 2022-12-02 23:34 ./
drwxrwxrwx 56 admin administrators 4096 2022-12-02 23:34 ../
-rwxrwx--- 1 XXXXX everyone 1875469115 2022-12-02 17:58 le fichier introuvable
je veux bien etre une truffe mais la si quelqu'un pouvait ouvrir la lumière. Merci
Bonne soiree
