Qnap [ Authelia ] [ 4.37.2 ] The Single Sign-On Multi-Factor portal for web apps
QoolBox
Représentant QNAP
2 Janvier 2014
10 562
163
153
50
www.qnap.com
sourcehttps://github.com/authelia/authelia
Downloadx64, arm64, arm32v7
https://www.myqnap.org/product/authelia/
The Single Sign-On Multi-Factor portal for web apps, Authelia authentication and authorization server
Authelia is an open-source authentication and authorization server providing 2-factor authentication and single sign-on (SSO) for your applications via a web portal. It acts as a companion of reverse proxies like nginx, Traefik or HAProxy to let them know whether queries should pass through. Unauthenticated user are redirected to Authelia Sign-in portal instead.
Documentation is available at https://docs.authelia.com.
The architecture is shown in the diagram below.
QPKG INtegration
Auhtelia service start automatically if your /opt/Authelia/config.yml is well setup
used a sqlitedb by default
4.28.1 (2021-04-16)
Bug Fixes
removed deprecated smtp/ldap options (#1912) (cc4f47f)
suites: ensure k8s suite utilises the registry cache (#1921) (db55325)
validator: misleading warning for empty acl domains (#1898) (1e30b00)
4.29.2 (2021-05-11)
Bug Fixes
oidc: implement required subject types supported meta (#1996) (46c8a25)
4.29.4 (2021-05-23)
Bug Fixes
server: revert github.com/valyala/fasthttp to v1.24.0 (#2021) (bbecf63)
4.30.1 (2021-08-05)
Bug Fixes
cmd: remove microbadger references (#2243) (2c3bc4a)
configuration: missing oidc minimum_parameter_entropy validator key (#2244) (13ae1b4)
notifier: regression in startup check (#2248) (655ae98)
v4.36.3
Latest
4.36.3 (2022-07-26)​
Bug Fixes​
Docker Container​
  • docker pull authelia/authelia:4.36.3
  • docker pull ghcr.io/authelia/authelia:4.36.3
