Source : http://www.universalmediaserver.com/
Download :
https://qnapclub.eu/fr/qpkg/220
Dépendance :
QJDK8 :
ffmpeg :
Note :
Scan par défaut les médias dans /share
Changelog
Changes since 5.2.3:
General:
The main window saves its size and position
Fixed DTS-HD being detected as regular DTS
Fixed the use of UMS profiles
Made automatic updater more stable
Improved detection of write permissions
Improved plugin installation support
Made profile a possible command line argument
Improved speed when reading shared folders
Fixed several bugs
Renderers:
Disabled folder thumbnails on Apple iOS apps
Improved support for VLC for iOS
Panasonic TVs use higher-quality thumbnails
External Components:
Updated FFmpeg for Windows to 7c8fcbb, which increases transcoding quality and speed
Updated h2database to 1.4.190
Updated Maven Assembly plugin to 2.6
Updated Maven Eclipse plugin to 2.10
Updated Maven Surefire plugin to 2.19
Updated MediaInfo for Windows to 0.7.78, which improved file parsing speed
Updated MPlayer/MEncoder for Windows to SB64, which increases transcoding quality and speed
Updated Netty to 3.10.5
5.1.3 - 2015-05-05
General:
Added and improved documentation in UMS.conf and DefaultRenderer.conf
Added the URL for the web interface to the logs on the Logs tab
Improved detection of the H.263 codec (thanks, leroy!)
Improved stability when transcoding subtitles by default
Simplified MEncoder commands in some situations
Fixed bugs
Renderers:
Improves support for Samsung EH5300 TVs (thanks, panzer!)
Fixed initial folders bug on Xbox 360/One
Improved detection of Xbox One
Improved detection of several Samsung TVs
Languages:
Updated Dutch translation (thanks, leroy!)
Updated Spanish translation (thanks, AlfredoRamos!)
5.1.2 - 2015-04-15
General:
Added "upnp_enable" user-level option
Added "log_level" user-level option
Added "UpnpAllow" renderer-level option
Added "Create TRACE logs" button
Added the ability to restart the program (not just the server)
Fixed videos being muxed instead of streamed
Various minor fixes/improvements
Renderers:
Added DSD/DFF streaming support to Cambridge Audio Blu-ray Disc players
Added more tags to DefaultRenderer.conf
Improved renderer detection/handling
Improved Android device detection
Improved detection of Panasonic AS600 Series TVs
Improved PS3 muxing via tsMuxeR
Improved support for Samsung D6400 TVs
Improved support for Samsung EH5300 TVs
Improved support for transcoding to Technisat S1+
Fixed support for MP3 files on some Samsung TVs and Blu-ray Disc players
Updated h2database to 1.4.187
Updated JDom to 2.0.6
Updated Logback to 1.1.3
Updated Maven AntRun Plugin to 1.8
Updated Maven Findbugs Plugin to 3.0.1
Updated Maven Git Commit ID Plugin to 2.1.13
Updated Maven Javadoc Plugin to 2.10.2
Updated Maven PMD Plugin to 3.4
Updated MediaInfo to 0.7.73, which:
Added and improved support for many formats
Fixed bugs
Updated slf4j to 1.7.12
5.1.1 - 2015-04-03
General:
Added support for links in tooltips (thanks, taconaut!)
Added support for customizing background and foreground color in tooltips (thanks, taconaut!)
Added PrependTrackNumbers renderer option to ensure that renderers order audio by track number
Made the RescaleByRenderer setting more consistent
Fixed MP4, M4A and 3GP file compatibility on some renderers
Fixed bug with the renderer selection window
Fixed audio and image compatibility on some renderers
Fixed transcoding with subtitles on 64-bit systems
Renderers:
Made Samsung televisions and Blu-ray Disc players order audio by track number
5.1.0 - 2015-03-21
General:
Added 64-bit versions of FFmpeg for a ~10% increase in transcoding speed
Removed the "Save" button since changes to settings are now saved automatically
Improved detection of playback states
Improved connection awareness
Improved True Motion frame interpolation speed by up to 20%
Improved folder population speed
Improved support for 3GPP files
Improved descriptions of settings
Slightly altered the memory usage bar
Fixed the renderer SeekByTime setting
Fixed renderer detection and recognition in some cases
Fixed display names for videos that have the Track (song title) value set
Fixed incorrect ContentFeatures headers being sent to renderers (thanks, master-nevi!)
Fixed the web logviewer
Fixed bugs with 3D subtitles
Fixed the setting for using embedded subtitles styles
Renderers:
Fixed filename bug on Sony Bravia TVs
Improved support for LG LED-backlit LCD 2014 TVs
Improved support for Samsung H6203 TVs
Languages:
Made more strings translatable
Updated Czech translation
Updated Dutch translation (thanks, ler0y!)
Updated French translation (thanks, Kirvx!)
Updated Italian translation (thanks, bartsimp!)
Updated Chromecast Java API to 0.0.6
Updated Commons Codec to 1.10
Updated FEST Util to 1.2.5
Updated FFmpeg for Windows and OS X, which:
Improved support for many containers and codecs
Fixed bugs
Updated Gson to 2.3.1
Updated h2database to 1.4.186, which:
Fixed memory issues
Fixed caching issues
Updated InterFrame to 2.8.0, which:
Increased processing speed by up to 20%
Reduced memory use
Reduced dependencies
Updated JDom to 2.0.2
Updated JUnit to 4.12
Updated Plexus Utils to 3.0.21
Updated slf4j to 1.7.10
5.0.1 - 2015-02-16
General:
Fixed text in the Windows automatic updater
Fixed MediaInfo not parsing some rare data
Fixed detection of font attachments
Fixed support for subtitled files with apostrophes in the name
Fixed errors when packing debug files
Fixed support for resuming playback on some devices
Improved support for MOV, 3GP and 3G2 files
Reduced CPU load when the Status tab is visible
Improved support for 1920x1088 videos
Fixed logging error
Fixed the web interface when browsing via Safari
Improved stability when disabling renderers
Renderers:
Added support for Kodi Media Center
Added support for more Panasonic Blu-ray players
Added support for Samsung HT-F4 series home entertainment systems
Improved detection of some LG TVs
Improved detection of some Panasonic Blu-ray players and TVs
Improved detection of some Samsung devices
Improved support for Samsung ES6100 TVs
Improved support for Samsung ES6575 TVs
Improved support for Sony Xperia Z3 smart phones
Updated the image for Xbox 360
Fixed 24-bit FLAC playback on PS3 via the Videos folder
Languages:
Updated MediaInfo for OS X to 0.7.71, which:
Improved folder population time
Fixed bugs
5.0.0 - 2015-01-25 - Changes since 4.4.0
General:
Added support for UPnP connections and playback
Added the option to use info from IMDB with filename prettifying
Added HTML5 video support to the web interface
Create custom per-device configuration files to override any general renderer or UMS setting
Major redesign of the status tab to show per-renderer information
Minor tweaks to the GUI
Improved player control
Includes the possibility to allow UMS to control renders automatically
Web player can also be controlled
Automatic reloading of external files
Documentation updates
New xmb playlist folders with optional automatic starting, looping, and saving, editable from web or xmb
A dynamic xmb playlist for on-the-fly playlist creation from web or xmb
Better bump/gui player playlists with optional automatic looping
Push playback support for chromecast and web browsers
Changed the interface for enabling/disabling renderer configurations
Changed the default setting for wrap_dts_into_pcm to false
Made sure files are always directly streamable via the Transcoding folder
Added the UMS_MAX_MEMORY variable to UMS.sh
Fixed audio downsampling
Fixed a bug with parsing formats from MediaInfo
Removed the database compacting method that was never recommended
Fixed a startup error
Minor bugfixes and code optimizations
Renderers:
Added support for Panasonic DMP-BDT360 devices
Added support for Samsung H6500 Blu-ray Disc players
Added support for Telefunken TVs
Improved support for Chromecast (cast from UMS webui/gui)
Improved support for Panasonic Viera AS650 series TVs
Improved support for Samsung C6600 series TVs
Improved support for Sony Blu-ray Disc players
Improved support for Sony Bravia W series TVs
Improved file compatibility on non-PS3 renderers
Fixed detection of some Samsung renderers
Languages:
Updated h2database to 1.4.185
Updated Maven Assembly Plugin to 2.5.2
Updated Maven Compiler Plugin to 3.2
Updated Maven Git Commit ID Plugin to 2.1.11
Updated Maven Source Plugin to 2.4
Updated Maven Surefire plugins to 2.18
Updated MediaInfo for Windows to 0.7.71, which:
Improves folder population time
Improves detection of many formats
Fixes bugs
Updated MPlayer/MEncoder for Windows to SB63, which:
Fixes support for DVD audio
Improves support for many containers and codecs
Fixes bugs
5.0.0 - 2015-01-25 - Changes since 5.0.0-b1
General:
Using info from IMDB with filename prettifying works for anime
Minor improvements to the web interface
All changes from 4.3.1 and 4.4.0
Renderers:
Languages:
Updated Cling to 2.0.1
Fixes bugs
Fixes bugs
Updated Seamless to 1.1.0
4.4.0 - 2015-01-11
General:
Improved compatibility of H.264 transcoded videos
Fixed error on Linux when VLC is not installed
Fixed recognition of BMP, Theora and Vorbis (thanks, ler0y!)
Added support for several more formats and codecs in renderer configs (thanks, ler0y!)
Added "SendFolderThumbnails" renderer option
Fixed some cases of unnecessary video transcoding
Fixed AviSynth output compatibility on some renderers
Improved speed of True Motion processing
Updated setting descriptions
Cleaned up logging
Fixed MP3 transcoding support
Improved library creation speed and prevented unnecessary transcoding for non-video files
Renderers:
Added support for Samsung ES8005 TVs (thanks, wazer!)
Added support for Samsung BD-C6800 Blu-ray Disc Players
Added support for Sony Xperia Z3
Added support for Yamaha R-N500
Improved support for Hama IR320
Improved support for Panasonic AS600E TVs (thanks, Etmoc!)
Improved support for Panasonic VT60 TVs
Improved support for Samsung H6400 series TVs
Improved support for Sony Blu-ray Disc players from 2013
Improved support for Sony Bravia NX70x series TVs
Improved support for Xbox 360
Fixed audio transcoding on Sony Bravia EX series TVs
Fixed timeouts on Philips TVs
Fixed support for images on Panasonic TVs
Updated DefaultRenderer.conf
Languages:
Fixes bugs
Updated MPlayer/MEncoder for Windows to SB62, which:
Fixes support for Opus
Fixes support for DVDs
Fixes color and italic support for MicroDVD subtitles
Improves MPEG-2 output
Fixes x264 hardware acceleration
Fixes VBR and VFR support in H.264 output
Fixes bugs
Updated Netty to 3.9.6, which fixed bugs
4.3.1 - 2014-12-12
General:
Windows installer removes deprecated renderer files
Fixed a startup crash
Renderers:
Added support for Hisense K680 TVs
Added support for Samsung F5505 TVs
Improved support for LG LS5700 TVs (thanks, AngelShine!)
Improved support for Panasonic S60 Series TVs
Improved support for Samsung WiseLink devices
Improved support for Sony Bravia HX75 Series TVs
Description :
Universal Media Server est une application permettant de diffuser facilement des médias dans votre maison grâce au protocole UPnP.
Compatible avec de nombreux téléviseurs connectés (Samsung, Sony...) ainsi que les consoles de jeux de dernière génération, vous pourrez, par exemple, aisément écouter la musique se situant sur votre ordinateur depuis un de ces périphériques compatible n'importe où dans la maison (à condition que l'appareil soit connecté au réseau). Idem pour les photos et les vidéos présentes sur l'ordinateur hébergeant le serveur.
Universal Media Server facilite la configuration et vous aidera à trouver le meilleur compromis entre qualité et fluidité selon la rapidité de votre réseau.
