Qnap [ QCouchPotato ] [ 160822 ] Movie Downloader
hi could someone help me edit torrent providers?
thepiratebay.se and torrentz2.eu does not seem to work for me i edited both like that :
config files found in /share/CACHEDEV1_DATA/.qpkg/QCouchPotato/CouchPotatoServer-master/couchpotato/core/media/_base/providers/torrent
    urls = {
         'detail': 'https://thepiratebay.org/torrent/%s',
         'search': 'https://thepiratebay.org/search/%s'
and
    urls = {
         'detail': 'https://torrentz2.eu/search?f=%s',
         'search': 'https://torrentz2.eu/search?f=%s',
         'verified_search': 'https://torrentz2.eu/verifiedN?f=%s'
onehans a dit:
giopas a dit:
I think the easiest is to use Cardigann and/or Jackett to do so.
thanks, could you provide some link to tutorial please?
i have installed cardigann and added there an piratebay eztv and demonoid they all return results in search. i added ip adderess and api key in couchpotato but get this errors
[edia._base.providers.base] Failed to parsing TorrentPotato: Traceback (most recent call last): File "/share/CACHEDEV1_DATA/.qpkg/QCouchPotato/CouchPotatoServer-master/couchpotato/core/media/_base/providers/base.py", line 84, in getJsonData return json.loads(data) File "/share/CACHEDEV1_DATA/.qpkg/QCouchPotato/lib/python2.7/json/__init__.py", line 338, in loads return _default_decoder.decode(s) File "/share/CACHEDEV1_DATA/.qpkg/QCouchPotato/lib/python2.7/json/decoder.py", line 366, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "/share/CACHEDEV1_DATA/.qpkg/QCouchPotato/lib/python2.7/json/decoder.py", line 384, in raw_decode raise ValueError("No JSON object could be decoded") ValueError: No JSON object could be decoded
what did i do wrong?
j'ai installé Couch, mais quand je souhaite l'ouvrir, mon navigateur me dis qu'il y a une erreur de chargement de la page... :?
quelqu'un sait où je dois chercher pour arranger cela?
je suis aller sur ma box pour ouvrir le port 5050 mais rien n'y fait...
comment le savoir?
je l'ai installé depuis l'app center mais je n'ai pas le choix des versions.
je l'ai depuis supprimer et j'ai télécharger le x86 sur le repo QnapclubStore.
ça fonctionne depuis! :)
merci Qoolbox pour ta simple et rapide réponse! ;)
Bonjour!
Depuis le passage en QTS 4.3 officiel depuis la 4.2, je n'arrive pas à changer les données de configuration de QCouchpotato pour QTransmission.
Celles-ci se remettent automatiquement aux anciennes données (port, identifiant et mot de passe), empêchant QCouchpotato de snatcher quoi que ce soit.
Quelqu'un a une idée? J'ai déjà essayé de modifier le fichier de config via SSH mais celui-ci revient également aux anciennes données.
Merci d'avance!
Is there a Qnap version for arm41?
I was looking everywhere but didn't find it.
I have some version and wants python and git so installed qgit and python 3.5 and it doesn't work.
Hi
I have had QCouchPotato [160822] installed for a number of years. For some reason it has just stopped working?! I have updated QMono, uninstalled & reinstalled QCouchPotato. Can anyone help... the "app centre" in QNAP interface shows it as working...
Versions
QTS: TS-453A 4.4.1.0978
QMono: 5.20.1.19
QCouchPotato: 160822
Help appreciated
Just to add
I also had Python 2.7.14 installed...
and since the earlier post I have uninstalled both QMono & Python 2.7.14 to downgrade to the Application centre Mono & Python 2.7.12
This did not change anything unfortunately...
this application package is pretty old now...
just tested it on TBS-453-DX ... all is working fine...
you dont need python or anything else to start it
Thanks @QoolBox
Any idea what might be wrong then?
Attached the views I have (I have some knowledge of logging into the QNAP via SSH and could test a few things that way ... but really not sure where to start?)
Hi
As an update: I have completely refreshed my router settings and cleared my browser cache due to the 'Err_Connection_Refused' which I read could be any one of multiple issues. None worked!!
I have also opened a ticket with QNAP and spoke with them today, they have rolled back to an earlier firmware which has ironically fixed Qsonarr and Plex (that had similar issues) but has not fixed QCouchpotato. I am not sure what may or may not have been corrupted by the more recent firmware but I wonder whether there is a chance for a more updated qpkg that hopefully will reset all the required settings? (I have uninstalled and reinstalled the package without success).
Thanks
