Qnap [ QSABnzbdPlus ] [ 3.5.3 ] Usenet Downloader
Update: Safihre has patched the issue! It will be patched for 1.2.1. Though you can always manually apply the patch.
QoolBox do you plan on making QSABnzbdPlus auto-updatable like the other SABnzbd qpkg?
feasible, but i didnt had time to work on it yet
QoolBox a dit:
why not... it in my built script by error.. for all Python qpkg..
Good to know. Thanks for all the time you put into these!
A review of the bundled binaries, to reduce bloat, wouldn't be a bad idea.
Hi,
Sabnzbd 1.2.1 has been released, fixing a lot of problems with rar's naming and par2 repair!
+Release Notes - SABnzbd 1.2.1
+## What's new in 1.2.1
+- QuickCheck will perform fast rename of obfuscated posts
+- RSS Downloaded page now shows icon to indicate source
+- HTML tags are filtered from single-line script output
+- New self-signed certificates now list local IP in SAN-list
+- Handle jobs on Windows with forbidden names (Con.*, Aux.*,..)
+## Bug fixes in 1.2.1
+- Fix crashing Assembler
+- 'Only Download Top of Queue' was broken for a long time
+- Cloaked files (RAR within RAR) were not detected anymore
+- Incorrectly labeled some downloads as Encrypted
+- Passwords were not parsed correctly from filenames
+- RSS reading could fail on missing attributes
+- Multi-feed RSS will not stop if only 1 feed is not functioning
+- Duplicate detection set to Fail would not work for RSS feeds
+- Incorrectly marking jobs with folders inside as failed
+- Categories were not matched properly if a list of tags was set
+- PostProcessing-script was not called on Accept&Fail or Dupe detect
+- Support for newer par2cmdline(-mt) versions that need -B parameter
+- Some newsservers would timeout when connecting
+- More robust detection of execute permissions for scripts
+- CPU type reporting on Windows and macOS
+- Failed to start with some localhost configs
+- Removed some more stalling issues
+- Retry rename 3x before falling back to copy during "Moving"
+- Catch several SSL errors of the webserver
+- Disk-space information is now only checked every 10 seconds
best regards
Lenny
I have version 1.2.0 installed, when I try to install 1.2.1 from you repo I get that:
Error 2017/02/25 20:55:41 admin x.x.x.x localhost [App Center] The internal name of QSabNZBdPlus has been registered by QSabNZBdPlus. You must uninstall QSabNZBdPlus before installing QSabNZBdPlus
If I uninstall will I lose all my settings?
If I download the package from the web site and install it it is ok, just got the error when I try from the repo.
save the settings from /share/MD0_DATA/.qpkg/QSabNZBdPlus/SAB_CONFIG
Connect via sftp on filezilla
J'ai installé [Par2cmdline-mt] [0.6.14-mt] de votre lien, mais SABnzbd dit toujours "Multicore Par2 non disponible".
il me semble dans la partie des paramètres de sabnzbd ca doit être possible...
je n'ai pas de compte usenet je ne peux pas vérifier
