Source : https://github.com/cdr/code-server
Download : amd64 , arm 64
VS Code - MyQNAP
Run VS Code on any machine anywhere and access it in the browser. Visual Studio Code – Open Source (“Code – OSS”) Visual Studio Code is a distribution of the Code - OSS repository with Microsoft-specific customizations released under a traditional Microsoft product license. Visual Studio Code...
www.myqnap.org
QPKG INTEGRATION
- Default password is NAS $HOSTNAME
- Listen by default to HTTPS on port 54442
- detect automatically if MyQnapcloud LetEncrypt certificate are found, and uses it, if not it uses self-signed certificate
or set your own certificate path if you have
Commande line flags /opt/VSCode/code-server/bin/code-server --help
Usage: code-server [options] [path]
Options
--auth The type of authentication to use. [password, none]
--cert Path to certificate. Generated if no path is provide d.
--cert-key Path to certificate key when using non-generated cer t.
--disable-updates Disable automatic updates.
--disable-telemetry Disable telemetry.
--host Host for the HTTP server.
-h --help Show this output.
--open Open in browser on startup. Does not work remotely.
--port Port for the HTTP server.
--socket Path to a socket (host and port will be ignored).
-v --version Display version information.
--user-data-dir Path to the user data directory.
--extensions-dir Path to the extensions directory.
--list-extensions List installed VS Code extensions.
--force Avoid prompts when installing VS Code extensions.
--install-extension Install or update a VS Code extension by id or vsix.
--uninstall-extension Uninstall a VS Code extension by id.
--show-versions Show VS Code extension versions.
-vvv --verbose Enable verbose logging.
About :
Code anywhere: Code on your Chromebook, tablet, and laptop with a consistent dev environment. Develop on a Linux machine and pick up from any device with a web browser.
Server-powered: Take advantage of large cloud servers to speed up tests, compilations, downloads, and more. Preserve battery life when you're on the go since all intensive computation runs on your server.
