Following the last firmware upgrade (to version 5.0.0.1850 on my TVS-863), I'm not able to get Komga to start anymore and get below error message. Despite various change/test, I'm not able to fix it. Any idea/help will be highly appreciated.
[xxxx@xxxx Komga]# ./Komga.sh start
19:04:57.049 [main] ERROR org.springframework.boot.SpringApplication - Application run failed
org.yaml.snakeyaml.scanner.ScannerException: while scanning for the next token
found character '\t(TAB)' that cannot start any token. (Do not use \t(TAB) for indentation)
in 'reader', line 2, column 39:
... aries-scan-cron: "* 15 * * * ?" #periodic scan every 15 minutes
at org.yaml.snakeyaml.scanner.ScannerImpl.fetchMoreTokens(ScannerImpl.java:439)
at org.yaml.snakeyaml.scanner.ScannerImpl.checkToken(ScannerImpl.java:248)
at org.yaml.snakeyaml.parser.ParserImpl$ParseBlockMappingKey.produce(ParserImpl.java:602)
at org.yaml.snakeyaml.parser.ParserImpl.peekEvent(ParserImpl.java:165)
at org.yaml.snakeyaml.comments.CommentEventsCollector$1.peek(CommentEventsCollector.java:59)
at org.yaml.snakeyaml.comments.CommentEventsCollector$1.peek(CommentEventsCollector.java:45)
at org.yaml.snakeyaml.comments.CommentEventsCollector.collectEvents(CommentEventsCollector.java:140)
at org.yaml.snakeyaml.comments.CommentEventsCollector.collectEvents(CommentEventsCollector.java:119)
at org.yaml.snakeyaml.composer.Composer.composeScalarNode(Composer.java:221)
at org.yaml.snakeyaml.composer.Composer.composeNode(Composer.java:191)
at org.yaml.snakeyaml.composer.Composer.composeValueNode(Composer.java:313)
at org.yaml.snakeyaml.composer.Composer.composeMappingChildren(Composer.java:304)
at org.yaml.snakeyaml.composer.Composer.composeMappingNode(Composer.java:288)
at org.yaml.snakeyaml.composer.Composer.composeNode(Composer.java:195)
at org.yaml.snakeyaml.composer.Composer.getNode(Composer.java:115)
at org.yaml.snakeyaml.constructor.BaseConstructor.getData(BaseConstructor.java:135)
at org.springframework.boot.env.OriginTrackedYamlLoader$OriginTrackingConstructor.getData(OriginTrackedYamlLoader.java:99)
at org.yaml.snakeyaml.Yaml$1.next(Yaml.java:512)
at org.springframework.beans.factory.config.YamlProcessor.process(YamlProcessor.java:198)
at org.springframework.beans.factory.config.YamlProcessor.process(YamlProcessor.java:166)
at org.springframework.boot.env.OriginTrackedYamlLoader.load(OriginTrackedYamlLoader.java:84)
at org.springframework.boot.env.YamlPropertySourceLoader.load(YamlPropertySourceLoader.java:50)
at org.springframework.boot.context.config.StandardConfigDataLoader.load(StandardConfigDataLoader.java:54)
at org.springframework.boot.context.config.StandardConfigDataLoader.load(StandardConfigDataLoader.java:36)
at org.springframework.boot.context.config.ConfigDataLoaders.load(ConfigDataLoaders.java:107)
at org.springframework.boot.context.config.ConfigDataImporter.load(ConfigDataImporter.java:128)
at org.springframework.boot.context.config.ConfigDataImporter.resolveAndLoad(ConfigDataImporter.java:86)
at org.springframework.boot.context.config.ConfigDataEnvironmentContributors.withProcessedImports(ConfigDataEnvironmentContributors.java:121)
at org.springframework.boot.context.config.ConfigDataEnvironment.processInitial(ConfigDataEnvironment.java:240)
at org.springframework.boot.context.config.ConfigDataEnvironment.processAndApply(ConfigDataEnvironment.java:227)
at org.springframework.boot.context.config.ConfigDataEnvironmentPostProcessor.postProcessEnvironment(ConfigDataEnvironmentPostProcessor.java:102)
at org.springframework.boot.context.config.ConfigDataEnvironmentPostProcessor.postProcessEnvironment(ConfigDataEnvironmentPostProcessor.java:94)
at org.springframework.boot.env.EnvironmentPostProcessorApplicationListener.onApplicationEnvironmentPreparedEvent(EnvironmentPostProcessorApplicationListener.java:102)
at org.springframework.boot.env.EnvironmentPostProcessorApplicationListener.onApplicationEvent(EnvironmentPostProcessorApplicationListener.java:87)
at org.springframework.context.event.SimpleApplicationEventMulticaster.doInvokeListener(SimpleApplicationEventMulticaster.java:176)
at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:169)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:143)
at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:131)
at org.springframework.boot.context.event.EventPublishingRunListener.environmentPrepared(EventPublishingRunListener.java:82)
at org.springframework.boot.SpringApplicationRunListeners.lambda$environmentPrepared$2(SpringApplicationRunListeners.java:63)
at java.util.ArrayList.forEach(ArrayList.java:1257)
at org.springframework.boot.SpringApplicationRunListeners.doWithListeners(SpringApplicationRunListeners.java:117)
at org.springframework.boot.SpringApplicationRunListeners.doWithListeners(SpringApplicationRunListeners.java:111)
at org.springframework.boot.SpringApplicationRunListeners.environmentPrepared(SpringApplicationRunListeners.java:62)
at org.springframework.boot.SpringApplication.prepareEnvironment(SpringApplication.java:374)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:332)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:1343)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:1332)
at org.gotson.komga.ApplicationKt.main(Application.kt:16)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.boot.loader.MainMethodRunner.run(MainMethodRunner.java:49)
at org.springframework.boot.loader.Launcher.launch(Launcher.java:108)
at org.springframework.boot.loader.Launcher.launch(Launcher.java:58)
at org.springframework.boot.loader.JarLauncher.main(JarLauncher.java:88)
