Source : https://github.com/allinurl/goaccess
Download :
https://www.qnapclub.eu/fr/qpkg/807
What is it?
GoAccess is an open source real-time web log analyzer and interactive viewer that runs in a terminal on *nix systems or through your browser. It provides fast and valuable HTTP statistics for system administrators that require a visual server report on the fly. More info at: https://goaccess.io.
Features
GoAccess parses the specified web log file and outputs the data to the X terminal. Features include:
Completely Real Time
All panels and metrics are timed to be updated every 200 ms on the terminal output and every second on the HTML output.
Minimal Configuration needed
You can just run it against your access log file, pick the log format and let GoAccess parse the access log and show you the stats.
Track Application Response Time
Track the time taken to serve the request. Extremely useful if you want to track pages that are slowing down your site.
Nearly All Web Log Formats
GoAccess allows any custom log format string. Predefined options include, Apache, Nginx, Amazon S3, Elastic Load Balancing, CloudFront, etc.
Incremental Log Processing
Need data persistence? GoAccess has the ability to process logs incrementally through the on-disk B+Tree database.
Only one dependency
GoAccess is written in C. To run it, you only need ncurses as a dependency. That's it. It even features its own Web Socket server — http://gwsocket.io/.
Visitors
Determine the amount of hits, visitors, bandwidth, and metrics for slowest running requests by the hour, or date.
Metrics per Virtual Host
Have multiple Virtual Hosts (Server Blocks)? It features a panel that displays which virtual host is consuming most of the web server resources.
Color Scheme Customizable
Tailor GoAccess to suit your own color taste/schemes. Either through the terminal, or by simply applying the stylesheet on the HTML output.
Support for Large Datasets
GoAccess features an on-disk B+Tree storage for large datasets where it is not possible to fit everything in memory.
Nearly all web log formats...
GoAccess allows any custom log format string. Predefined options include, but not limited to:
Amazon CloudFront (Download Distribution).
Amazon Simple Storage Service (S3)
AWS Elastic Load Balancing
Combined Log Format (XLF/ELF) Apache | Nginx
Common Log Format (CLF) Apache
Google Cloud Storage.
Apache virtual hosts
Squid Native Format.
W3C format (IIS).
Why GoAccess?
GoAccess was designed to be a fast, terminal-based log analyzer. Its core idea is to quickly analyze and view web server statistics in real time without needing to use your browser (great if you want to do a quick analysis of your access log via SSH, or if you simply love working in the terminal).
While the terminal output is the default output, it has the capability to generate a complete, self-contained, real-time HTML report, as well as a JSON, and CSV report.
You can see it more of a monitor command tool than anything else.
