Forum des NAS
BitTorrent Sync, KODI, IPKG, NZBGet, pyLoad...
Modérateur : QoolBox
#81517
Source :https://hub.github.com/
Download :
https://www.qnapclub.eu/fr/qpkg/813
About :
hub is an extension to command-line git that helps you do everyday GitHub tasks without ever leaving the terminal.
Whether you are beginner or an experienced contributor to open-source, hub makes it easier to fetch repositories, navigate project pages, fork repos and even submit pull requests, all from the command-line.
Scripting your workflows is much easier now that you can list and create issues, pull requests, and GitHub releases.
As someone who loves automation
As an open-source maintainer
Maintaining a project is easier when you can easily fetch from other forks, review pull requests and cherry-pick URLs. You can even create a new repo for your next thing.
Using GitHub for work
Save time at work by opening pull requests for code reviews and pushing to multiple remotes at once. Even GitHub Enterprise is supported.
Erreur réseau 0x8007003
Salut, pourrai tu donner un peu plus dinfo afin qu[…]
Firmware DSM 6.2.3-25426
Yes, moi aussi ! Vous l'avez installé ? Vo[…]
Re, Désolé pour cce retard :oops: […]
CloudSync et le chiffrement
Je n'ai jamais testé... à essayer.
Ikoula
