[ NexRender Server ][ 1.5.10 ] Data-driven render automation Server for After Effects
BitTorrent Sync, KODI, IPKG, NZBGet, pyLoad...
Répondre
Avatar du membre
QoolBox
Représentant de QNAP
Professionnel : Oui
Contact :
Message par QoolBox » 14 juin 2019 20:18
source : https://www.qnapclub.eu/fr/qpkg/releasenotes/749
Download :
https://www.qnapclub.eu/fr/qpkg/749
Note :
Start nexrender on port 3000 with secret qnap
nexrender-server command added to $PATH
please read documentation on the Github : https://github.com/inlife/nexrender
About :
nexrender is a simple, small, carefully designed application with the main goal of rendering automation for Adobe After Effects based rendering workflows.
At this point in time, the project is mainly targeted at people at least somewhat comfortable with scripting or development, and that have basic knowledge of javascript language and json formats.
Features
data-driven, dynamic, personalized video rendering
automated video management, processing, and delivery
network oriented project structure, render farm
highly modular nature, extensive plugin support
works only in cli mode, never launches After Effects GUI application
does not require licenses for Adobe After Effects on any worker machine
free to use and open source
How it works
rendering: It uses Adobe After Effects' aerender command-line interface application.
compositing: It creates a temporary folder, copies project and replaces assets with provided ones.
personalization: It uses AE's expressions, scripting, and compositing (noted above).
scheduling: It stores projects in a local database, managed from anywhere using http api.
network: It renders project per machine, and can be used to render several projects simultaneously.
farm: Can be used to render a single project on several machines via Multi-Machine Sequence.
Modifié en dernier par QoolBox le 17 juil. 2019 16:20, modifié 4 fois.
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Re: [ NexRender Server ][ 1.5.0 ] Data-driven render automation Server for After Effects
Message par QoolBox » 18 juin 2019 12:46
updated
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Re: [ NexRender Server ][ 1.5.5 ] Data-driven render automation Server for After Effects
Message par QoolBox » 11 juil. 2019 13:43
updated
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Re: [ NexRender Server ][ 1.5.7 ] Data-driven render automation Server for After Effects
Message par QoolBox » 12 juil. 2019 14:31
updated
Avatar du membre
QoolBox
Professionnel : Oui
Contact :
Re: [ NexRender Server ][ 1.5.9 ] Data-driven render automation Server for After Effects
Message par QoolBox » 17 juil. 2019 12:56
updated
Répondre
Retourner vers « Applications tierces »
Qui est en ligne
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 3 invités
