Timezone problem and backup question
Hello Qoolbox.
thanks for this qnap package! it works quite smoothly so far,
but 2 questions remain:
- when using TOTP, the server (qnap) or bitwarden_rs package gives me wrong output of time, so I can't use TOTP
I tried to adjust it manually in the Bitwarden.sh file
#export TZ=$(/sbin/getcfg System 'Time Zone' -f /etc/config/uLinux.conf)
export TZ=America/Buenos_Aires
but this does not work.... server time of bitwarden_rs stays at UTC time
- I was looking into the backup strategy, and found out, that sqlite3 backups can be done on the fly with the .backup command,
but I am struggling with using the resulting backup-file in a worst-case scenario:
for substituting the actual backupfile, one needs to stop bitwarden_rs on the qnap: but if it is stopped, there is no /opt/Bitwarden/data/db.sqlite3,
as there is no /opt/Bitwarden folder at this moment.... what can be done here?
Thanks a lot in advance,
Bernhard Thoni
