Qnap [ Serposcope ] [ 2.13.1 ] Search engine rank checker for SEO
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
Source : https://serposcope.serphacker.com/
Download : arm64, armx31, armx41, x86, x86_64
https://www.qnapclub.eu/fr/qpkg/725
Dependencies : QJDK8
About :
Unlimited keywords and websites
Because serposcope is totally free, you can track any keywords and any websites you want without any limits.
Competitor tracking
The software automatically track all the websites for a specific keyword, you can retrieve ranking history of a competitor at any time.
Local & custom search
Serposcope can do searches from a specific city or country and view local search result. A lot of other parameters are customizable.
User account management
If you plan to monitor keywords for your customers, you can create user accounts and restrict them to a specific set of keywords.
Run on a desktop PC or server
Designed to be flexible, can run full time on a dedicated server, or used periodically on a desktop computer.
Proxy and Captcha support
Check thousands of keywords : support proxies and fail-over IPs, provide automatic captcha breaking via external service.
Open Source
Fully open-source under MIT license : use, edit, copy, resell without restriction. Access the code source on github.
Easy setup
Serposcope now provides a one click installer. The only requirement is Java which is available on all operating system.
Tip Me !
Your gratitude and finance will help me to continue integration of this QPKG and maintain up to date versions.
Je m'adresse à @Qoolbox en particulier, Serposcope a été mis à jour et l'ancien package créé ne fonctionne plus correctement malheureusement est il possible de trouver la dernière version de Serposcope en package Qnap quelque part ?
J'ai un NAS TS431+ (je veux en changer mais c'est un autre sujet :) )
Merci d'avance.
je regarde dés que possible...
pour changer de NAS contact frsales (at) qnap.com et demande une offre de renouvellement
