Qnap [ Go SSHfs ] [ 1.0.0 ] Mount remote SFTP as a local directory on NAS (sshfs)
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
Source : https://github.com/soopsio/sshfs-go
Download :
https://www.qnapclub.eu/fr/qpkg/718
notes :
sshfs command line added to NAS $PATH
Mounting
Usage:
sshfs mount {mountpoint} [flags]
Flags:
-a, --address string ssh server address (default "127.0.0.1:22")
-h, --help help for mount
-p, --password string ssh password
-r, --root string ssh root (default "/opt")
-u, --username string ssh username (default "root")
To mount secrets, first create a mountpoint (mkdir test), then use sshfs to mount:
sshfs mount -a 10.10.10.10:22 -u root -p ****** --log-level debug -r /tmp/test /opt/data/tmp
Docker untested
Usage:
sshfs docker {mountpoint} [flags]
Flags:
-h, --help help for docker
-s, --socket string socket address to communicate with docker (default "/run/docker/plugins/ssh.sock")
To start the Docker plugin, create a directory to hold mountpoints (mkdir test), then use sshfs to start the server. When Docker volumes request a volume (docker run --volume-driver vault --volume {prefix}:/container/secret/path), the plugin will create mountpoints and manage FUSE servers automatically.
sshfs docker /mnt/sshfs -a 10.10.10.10:22 -u root -p ****** --log-level debug -r /tmp/test
ls /run/docker/plugins/
ssh.sock
docker run --rm -it -v myvola:/data --volume-driver=ssh alpine sh
docker volume ls
DRIVER VOLUME NAME
ssh myvola
