Source : https://github.com/bastillion-io/Bastillion
Download :
https://www.myqnap.org/product/bastillion/
QPKG INFO :
HTTP on port 8256 / HTTPS on port 8443
Login with
username:admin
password:changeme
About :
Web-based SSH console that centrally manages administrative access to systems. Web-based administration is combined with management and distribution of user's public SSH keys.
Administrators can login using two-factor authentication with FreeOTP or Google Authenticator. From there they can manage their public SSH keys or connect to their systems through a web-shell. Commands can be shared across shells to make patching easier and eliminate redundant command execution.
Bastillion layers TLS/SSL on top of SSH and acts as a bastion host for administration. Protocols are stacked (TLS/SSL + SSH) so infrastructure cannot be exposed through tunneling / port forwarding. More details can be found in the following whitepaper: Implementing a Trusted Third-Party System for Secure Shell. Also, SSH key management is enabled by default to prevent unmanaged public keys and enforce best practices.
