Forum des NAS
BitTorrent Sync, KODI, IPKG, NZBGet, pyLoad...
Modérateur : QoolBox
Avatar de l’utilisateur
par QoolBox
#68690
Source : https://adguard.com/https://github.com/AdguardTeam/AdGuardHome
Download :x64, x86, arm-x41 , arm-x31,arm64
https://www.qnapclub.eu/fr/qpkg/649
Note :
Listen on 9638 for web admin
CoreDNS port listen on 16553 (instead of 53)
user : qnap pass : qnap
About :
Privacy protection center for you and your devices
Free and open source, powerful network-wide ads & trackers blocking DNS server.
AdGuard Home
AdGuard Home is a network-wide software for blocking ads & tracking. After you set it up, it'll cover ALL your home devices, and you don't need any client-side software for that.
How does AdGuard Home work?
AdGuard Home operates as a DNS server that re-routes tracking domains to a "black hole," thus preventing your devices from connecting to those servers. It's based on software we use for our public AdGuard DNS servers -- both share a lot of common code.
How is this different from public AdGuard DNS servers?
Running your own AdGuard Home server allows you to do much more than using a public DNS server.
Choose what exactly will the server block or not block;
Monitor your network activity;
Add your own custom filtering rules;
In the future, AdGuard Home is supposed to become more than just a DNS server.
Dernière modification par QoolBox le 24 déc. 2019 12:53, modifié 19 fois.
#68772
j'ai trouvé la parade pour utiliser le port 53
stop adguard
AdGuardHome.yaml et modifier
Code : Tout sélectionner
coredns:
  port: 53
  protection_enabled: true
editer /etc/dnsmasq.conf
changer port 53 to 1053 (par exemple)
editer /etc/resolv.conf et modifier
nameserver 127.0.1.1:1053
en ssh redémarrer dnsmask
killall -9 dnsmasq  # kill dnsmasq process
dnsmasq               # restart dnsmasq
redémarrer adguard.. maintenant ca tourne sur 53
je ne suis pas certains que cela persistant au reboot... j'ai ouvert un ticket auprès de la R&D, car je en comprends pas pour dnsmasq utilise le port 53 par défaut (sans utilisation particulière)
#70490
QoolBox a écrit : 29 nov. 2018 14:19updated
Avez-vous une réponse de votre ticket adressé à la R&D ?
J'ai installé la dernière version de Adguard, ouvert le port 16553. Cela ne fonctionne pas sur mon NAS. En haut à droite j'ai : version: v0.91
addresse: 0.0.0.0:16553
J'ai pris connaissance du post pour le port 53 mais n'y a-t-il pas un autre moyen pour que cela fonctionne dès l'installation du programme ?
Merci de votre réponse.
#70491
la solution de la R&D est de modifier la table IP
rempalcer <YOUR_NAS_IP> par l'ip du NAS
iptables -t nat -I PREROUTING --src 0/0 --dst 127.0.0.1 -p tcp --dport 53 -j REDIRECT --to-ports 16553
iptables -t nat -I PREROUTING --src 0/0 --dst 127.0.0.1 -p udp --dport 53 -j REDIRECT --to-ports 16553
iptables -t nat -I OUTPUT --src 0/0 --dst 127.0.0.1 -p tcp --dport 53 -j REDIRECT --to-ports 16553
iptables -t nat -I OUTPUT --src 0/0 --dst 127.0.0.1 -p udp --dport 53 -j REDIRECT --to-ports 16553
iptables -t nat -I PREROUTING --src 0/0 --dst <YOUR_NAS_IP> -p tcp --dport 53 -j REDIRECT --to-ports 16553
iptables -t nat -I PREROUTING --src 0/0 --dst <YOUR_NAS_IP> -p udp --dport 53 -j REDIRECT --to-ports 16553
Nextcloud-HTTPS
Merci Dam1 pour ces précisions. Nextcloud […]
salut Jules sur ce site tu peux voir si telle ou […]
https://raw.githubusercontent.com/4ch1m/huElectro[…]
Ikoula
