Suite aux dernières MAJ, l'onduleur n'apparaît plus dans l'interface, alors que le système le détecte...
Pour information, j'ai testé ceci :
Changement de port USB
Changement de câble USB
Redémarrage NAS
Auriez-vous une autre piste, idée ?
[~] # echo "NAS Model: $(getsysinfo model)"
NAS Model: TS-219P
[~] # echo "Firmware: $(getcfg system version) Build $(getcfg system 'Build Number')"
Firmware: 4.3.3 Build 20181029
[~] # dmesg
for level 5
[ 49.926971] md: raid4 personality registered for level 4
[ 50.023162] device-mapper: ioctl: 4.22.1-ioctl (2012-06-01) initialised: dm-devel@redhat.com
[ 50.410116] MV-CESA:Fallback driver 'hmac(sha1)' could not be loaded!
[ 50.416629] alg: hash: Failed to load transform for mv-hmac-sha1: -2
[ 50.479562] cryptodev: driver 0.9 loaded.
[ 54.385012] generic-usb 0003:0463:FFFF.0001: hiddev0: USB HID v1.10 Device [EATON Ellipse PRO] on usb-orion-ehci.0-1.3/input0
[ 54.417788] usbcore: registered new interface driver usbhid
[ 54.423393] usbhid: USB HID core driver
[ 54.463078] usbcore: registered new interface driver usblp
[ 54.506425] sysinfo: Module loaded.
[ 54.624909] jnl: driver (UFSD_HEAD UFSD_HEAD_r314144_b230) loaded at bf1c8000
[ 54.696831] ufsd: module license 'Commercial product' taints kernel.
[ 54.703218] Disabling lock debugging due to kernel taint
[ 54.714799] ufsd: driver (UFSD_HEAD UFSD_HEAD_r314144_b230, acl, ioctl, sd2(5), rsrc, car) loaded at bf1d7000
[ 54.714811] NTFSJ support included
[ 54.714815] Hfs+J support included
[ 54.714819] Build_for__QNAP_TS-120_k3.4.6_2014-11-19_UFSD_HEAD_r314144_b230
[ 54.738688] ufsd: PAGE_SIZE=4K, THREAD_SIZE=8k
[ 54.743148] ufsd: Kernel .config hash: original 0x65bbbc9a, current can't check.
[ 54.824022] RPC: Registered named UNIX socket transport module.
[ 54.830002] RPC: Registered udp transport module.
[ 54.834805] RPC: Registered tcp transport module.
[ 54.839528] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 54.903479] NFS: Registering the id_resolver key type
[ 54.955086] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 55.082017] fnotify: Load file notify kernel module.
[ 55.113150] lib80211: common routines for IEEE802.11 drivers
[ 55.118873] lib80211_crypt: registered algorithm 'NULL'
[ 55.170465] cfg80211: Calling CRDA to update world regulatory domain
[ 56.814688] usbcore: registered new interface driver snd-usb-audio
[ 56.844994] usbcore: registered new interface driver snd-usb-caiaq
[ 56.896915] Linux video capture interface: v2.00
[ 56.996721] uvcvideo: Unable to create debugfs directory
[ 57.021620] usbcore: registered new interface driver uvcvideo
[ 57.027420] USB Video Class driver (1.1.1)
[ 57.467937] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 58.357850] eth0: mac address changed
[ 58.391530] eth0: link down
[ 58.394345] eth0: started
[ 61.901483] eth0: link up, full duplex, speed 1 Gbps
[ 73.578122] kjournald starting. Commit interval 5 seconds
[ 73.594985] EXT3-fs (md9): using internal journal
[ 73.599714] EXT3-fs (md9): mounted filesystem with ordered data mode
[ 77.203446] active port 0 :139
[ 77.206610] active port 1 :445
[ 77.209677] active port 2 :20
[ 89.935046] md: bind<sda2>
[ 89.954703] md/raid1:md2: active with 1 out of 1 mirrors
[ 89.960131] md2: detected capacity change from 0 to 542851072
[ 91.024740] md2: unknown partition table
[ 93.184838] Adding 530124k swap on /dev/md2. Priority:-1 extents:1 across:530124k
[ 97.895391] md: bind<sdb2>
[ 97.935249] RAID1 conf printout:
[ 97.935262] --- wd:1 rd:2
[ 97.935272] disk 0, wo:0, o:1, dev:sda2
[ 97.935281] disk 1, wo:1, o:1, dev:sdb2
[ 97.945038] md: recovery of RAID array md2
[ 97.949311] md: minimum _guaranteed_ speed: 5000 KB/sec/disk.
[ 97.955097] md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
[ 97.964715] md: Recovering started: md2
[ 97.968564] md: using 128k window, over a total of 530128k.
[ 104.236705] md: md2: recovery done.
[ 104.240215] md: Recovering done: md2, degraded=1
[ 104.334858] RAID1 conf printout:
[ 104.334870] --- wd:2 rd:2
[ 104.334879] disk 0, wo:0, o:1, dev:sda2
[ 104.334888] disk 1, wo:0, o:1, dev:sdb2
[ 221.003479] [usb.001.001] /sys/devices/platform/orion-ehci.0/usb1 added.
[ 221.268381] [usb.001.001] bInterfaceClass=08
[ 221.848359] [usb.001.002] /sys/devices/platform/orion-ehci.0/usb1/1-1 added.
[ 222.180774] [usb.001.002] bInterfaceClass=08
[ 256.614215] md: md0 stopped.
[ 256.665331] md: md0 stopped.
[ 256.768619] md: bind<sdb3>
[ 256.771593] md: bind<sda3>
[ 256.777806] md/raid1:md0: active with 2 out of 2 mirrors
[ 256.783227] md0: detected capacity change from 0 to 1998792294400
[ 257.866981] md0: unknown partition table
[ 278.256608] EXT4-fs (md0): Mount option "noacl" will be removed by 3.5
[ 278.256619] Contact linux-ext4@vger.kernel.org if you think we should keep it.
[ 278.256626]
[ 278.416413] ext4_init_reserve_inode_table0: md0, 14893
[ 278.421579] ext4_init_reserve_inode_table2: md0, 14893, 0, 0, 4096
[ 278.427878] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: usrjquota=aquota.user,jqfmt=vfsv0,user_xattr,data=ordered,nodelalloc,noacl
[ 294.213076] eth0: stopped
[ 296.270150] eth0: link down
[ 296.272963] eth0: started
[ 299.918890] eth0: link up, full duplex, speed 1 Gbps
[ 314.774058] eth0: stopped
[ 314.803099] eth0: link down
[ 314.805923] eth0: started
[ 318.311134] eth0: link up, full duplex, speed 1 Gbps
[ 330.460196] active port 0 :139
[ 330.463269] active port 1 :445
[ 330.466367] active port 2 :20
[ 331.360748] warning: `proftpd' uses 32-bit capabilities (legacy support in use)
[ 341.211485] active port 0 :139
[ 341.214558] active port 1 :445
[ 341.217667] active port 2 :20
[ 381.509895] Bluetooth: Core ver 2.16
[ 381.523760] NET: Registered protocol family 31
[ 381.528258] Bluetooth: HCI device and connection manager initialized
[ 381.534653] Bluetooth: HCI socket layer initialized
[ 381.539552] Bluetooth: L2CAP socket layer initialized
[ 381.544628] Bluetooth: SCO socket layer initialized
[ 381.605087] usbcore: registered new interface driver btusb
[ 381.671865] Bluetooth: RFCOMM TTY layer initialized
[ 381.676804] Bluetooth: RFCOMM socket layer initialized
[ 381.681968] Bluetooth: RFCOMM ver 1.11
[ 387.502973] active port 0 :139
[ 387.506079] active port 1 :445
[ 387.509142] active port 2 :20
[ 412.671428] FAT-fs (sds1): bogus number of reserved sectors
[ 412.677068] FAT-fs (sds1): Can't find a valid FAT filesystem
[ 415.446749] warning: process `pic_raw' used the deprecated sysctl system call with 8.1.2.
[ 417.967141] rule type=2, num=0
[ 418.242459] WOL disable
[ 422.415550] Loading iSCSI transport class v2.0-871.
[ 423.005171] iscsi: registered transport (tcp)
[ 424.439348] iscsid (8223): /proc/8223/oom_adj is deprecated, please use /proc/8223/oom_score_adj instead.
[ 440.089085] ufsd: "mount" (dm-0): is mounted as NTFS at 2018-11-12 15:26:19
[ 470.905106] Initializing XFRM netlink socket
[ 471.025063] NET: Registered protocol family 15
[ 471.534809] PPP generic driver version 2.4.2
[ 471.600170] NET: Registered protocol family 24
[ 471.725053] PPP BSD Compression module registered
[ 471.817419] PPP MPPE Compression module registered
[ 471.895638] PPP Deflate Compression module registered
[ 471.964939] L2TP core driver, V2.0
[ 472.025050] L2TP IP encapsulation support (L2TPv3)
[ 472.074085] L2TP netlink interface
[ 472.145721] L2TP ethernet pseudowire support (L2TPv3)
[ 472.205104] PPPoL2TP kernel driver, V2.0
[ 472.265030] tun: Universal TUN/TAP device driver, 1.6
[ 472.270114] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 472.484754] nf_conntrack version 0.5.0 (8053 buckets, 32212 max)
[ 472.598179] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 498.559261] NET: Unregistered protocol family 15
[ 501.676623] active port 0 :139
[ 501.679692] active port 1 :445
[ 501.682752] active port 2 :20
[ 512.722929] Initializing XFRM netlink socket
[ 512.850393] NET: Registered protocol family 15
[~] # lsusb
Bus 001 Device 004: ID 0bc2:2322 Seagate RSS LLC
Bus 001 Device 003: ID 0463:ffff MGE UPS Systems UPS
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Redémarrage NAS
dmesg
lsusb
