Qnap [Firmware Release] QTS 4.3.4.0675 build 20180810 for all models
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
[Important Notes]
- To ensure system stability, QNAP recommends updating and then restarting QVPN Service in App Center after you update QTS to 4.3.4.
- As QTS previous versions of ARM models do not support snapshots, when you upgrade to QTS 4.3.4, the original volume cannot use this feature immediately. To solve this problem, you have to back up the existing data on your QNAP NAS to external storage. Then you can rebuild the QNAP NAS and take snapshots to the new storage pool with multiple volumes.
- QTS 4.3.4 is the final available firmware update for the following models:
TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-1269U-RP, TS-869U-RP, TS-469U-RP, TS-469U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, TS-470, TS-869 Pro, TS-869L, TS-669 Pro, TS-669L, TS-569 Pro, TS-569L, TS-469 Pro, TS-469L, TS-269 Pro, TS-269L, IS-400 Pro.
- Starting from QTS 4.3.4, QNAP NAS devices no longer support creating storage pools or static volumes using NVMe PCIe/M.2 SSDs. However, this limitation does not apply to the SSDs installed in built-in M.2 slots or on QM2 expansion cards.
- Below are the kernel versions for the NAS models supported by "QTS 4.3.4.0675":
kernel 3.10.20: TS-128, TS-228
kernel 3.2.26: TS-x31, TS-x31U
kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
kernel 4.2.8: HS-251, IS-400, SS-x79U, TS-x79, TS-x79U, TS-x70, TS-x70U, TVS-x70, TS-x31P, TS-x31P2, TS-x31+, TS-x31X, TS-x31XU, TS-x28A, TS- x35, TS-x51, TS-x51A, TS-x51U, TS-x53, TS-x53A, TBS-x53A, TS-x53B, TS-x53BU, TS-x53S, IS-453S, TS-x53U, TVS-x63, TS-x63, TS-x63U, TS-x73U, TS-x77, TVS-x80, TS-x80, TVS-x80U, TS-x80U, TVS-x82, TVS-x82S, TVS-1582TU, TS-x85, TES-x85U, TDS-16489U, TVS-x71, TVS-x71U, TVS-x73
[Fixed Issues]
- Fixed a stack-based buffer overflow vulnerability (CVE-2018-0721).
- Fixed a cross-site scripting vulnerability (CVE-2018-0719).
- Write speeds on external NTFS disks during file transfer were slower than expected.
- Users could not access exFAT disks after updating QTS to 4.3.4.0644 20180710 on the TS-x69 models.
- Creating an encrypted shared folder in a subfolder would cause files in the same folder to disappear.
- Devices on the same network as the NAS sometimes could not obtain IP addresses via DHCP when UPnP Discovery Service and secure connection (HTTPS) were both enabled.
- Users could not enable CodexPack when certain Nvidia graphics cards were installed.
- After users installed an SSL certificate via myQNAPcloud, if users recovered the QTS default certificate, myQNAPcloud would automatically install the SSL certificate again.
- The "Replace Disk One by One" option in Storage & Snapshots would become unavailable after users set a disk as the spare disk.
- It would sometimes take longer to start the NAS after a storage pool or volume was created.
- Control Panel could not display domain computers due to unexpected connection timeouts.
- Users could not change the configuration of a storage pool from RAID 1 to RAID 5 when using M.2 SSDs.
- App Center did not notify users of available updates for License Center.
- On the TS-x28A models, users could still connect to the NAS from blocked IP addresses.
- Users could not scroll the list of available domain controllers on the Active Directory Wizard in "Control Panel" > "Privilege" > "Domain Security".
- Garbled texts would appear when users opened certain .txt files in File Station.
- On Safari, File Station would stop responding when users uploaded files by dragging and dropping files.
- Users could not find torrents from certain sources when performing a search in Download Station.
- The dates modified of files might be inconsistent with the client time when users accessed shared folders via SMB.
- Mac Finder would display a QNAP NAS with a question mark icon when users accessed shared folders via SMB.
- Color tags attached to files would disappear after Mac woke up from sleep if users accessed shared folders via SMB.
- Snapshot log entries would not be sorted from the latest to the oldest when DD-MM-YY was used as the date format.
- QTS would incorrectly report false SNMP DoS (denial-of-service) attacks.
- Users could not securely erase SSDs when 2-step verification was enabled.
- QTS could not correctly display the remaining time for certain background tasks.
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/HS-251/HS-251_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/IS-400/IS-400_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/SS-1279U/SS-1279U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/SS-1879U/SS-1879U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/SS-2479U/SS-2479U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-1079/TS-1079_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-1269U/TS-1269U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-1270U/TS-1270U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-1279U/TS-1279U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X41/TS-131P_231P_431P_X31+_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-1679U/TS-1679U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-269/TS-269_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-469/TS-469_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-469U/TS-469U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-470/TS-470_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-470U/TS-470U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-569/TS-569_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-669/TS-669_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-670/TS-670_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-869/TS-869_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-869U/TS-869U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-870/TS-870_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-870U/TS-870U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-879/TS-879_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-879U/TS-879U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20180810-4.3.4.0675.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20180810-4.3.4.0675.zip
