Forum des NAS
QTS 4.2, QTS 4.3, QTS 4.4, QTS 4.5, QTS 5.0...
par Ishido
#63757
Encore un nouveau firmware !
https://www.qnap.com/fr-fr/download
Code : Tout sélectionner
QTS 4.3.4.0597 build 20180528
[Important Notes]
- To ensure system stability, QNAP recommends updating and then restarting QVPN Service in App Center after you update QTS to 4.3.4.
- As QTS previous versions of ARM models do not support snapshots, when you upgrade to QTS 4.3.4, the original volume cannot use this feature immediately. To solve this problem, you have to back up the existing data on your QNAP NAS to external storage. Then you can rebuild the QNAP NAS and take snapshots to the new storage pool with multiple volumes.
- QTS 4.3.4 is the final available firmware update for the following models:
TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-1269U-RP, TS-869U-RP, TS-469U-RP, TS-469U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, TS-470, TS-869 Pro, TS-869L, TS-669 Pro, TS-669L, TS-569 Pro, TS-569L, TS-469 Pro, TS-469L, TS-269 Pro, TS-269L, IS-400 Pro.
- Starting from QTS 4.3.4, QNAP NAS devices no longer support creating storage pools or static volumes using NVMe PCIe/M.2 SSDs. However, this limitation does not apply to the SSDs installed in built-in M.2 slots or on QM2 expansion cards.
- Below are the kernel versions for the NAS models supported by QTS 4.3.4.0479:
kernel 3.10.20: TS-128, TS-228
kernel 3.2.26: TS-x31, TS-x31U
kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
kernel 4.2.8: HS-251, IS-400, SS-x79U, TS-x79, TS-x79U, SS-x79U, TS-x70, TS-x70U, TVS-x70, TS-x31P, TS-x31P2, TS-x31+, TS-x31X, TS-x31XU, TS-x28A, TS- x35, TS-x51, TS-x51A, TS-x51U, TS-x53, TS-x53A, TBS-x53A, TS-x53B, TS-x53BU, TS-x53S, IS-453S, TS-x53U, TVS-x63, TS-x63, TS-x63U, TS-x73U, TS-x77, TVS-x80, TS-x80, TVS-x80U, TS-x80U, TVS-x82, TVS-x82S, TVS-1582TU, TS-x85, TES-x85U, TDS-16489U, TVS-x71, TVS-x71U, TVS-x73
[Fixed Issues]
- Users could not close the privacy policy announcement when accessing QTS under certain circumstances.
- Users could not connect to the NAS after syncing the files in two shared folders with two client devices via Qsync.
- Files and subfolders in encrypted shared folders would sometimes disappear after a data migration.
- Users could not back up iSCSI LUNs to the shared folders on devices running Windows 10 Pro.
- Users could not access the NAS from Windows if the Samba configuration file was corrupted.
- QTS System Logs could not display connection logs for FTP connections.
- Users could not specify passwords that contained a large number of special characters.
- QTS would automatically create a virtual switch after users restarted the NAS.
- Control Panel could only list up to 1000 domain computers.
- Users could not back up NAS shared folders using scheduled backup on Windows Server 2012 R2.
- Certain folders deleted via SMB would be recovered automatically.
- QTS would automatically translate certain folder names after users changed the system language.
Avatar de l’utilisateur
par lgrnr
#63766
Effectivement, le nouveau Firmware est arrivé.
On note maintenant que dans l'historique du Centre de téléchargement de QNAP le précédent Firmware déclaré est le "QTS 4.3.4.0569 build 20180501", QNAP a définitivement retiré de sa liste le furtif "QTS 4.3.4.0593 build 20180524"... pour le remplacer par le "QTS 4.3.4.0593 build 20180528".
Dernière modification par lgrnr le 29 mai 2018 20:15, modifié 1 fois.
par Ishido
#63767
Pour ma part je vais attendre que les autres essuient les plâtres :-p
par lgrnr
#63768
Pas de souci particulier pour l'instant, ça roule... :)
par webmail
#63769
allé hop mettez à jour pour être mes bétas testeurs :o
hop hop hop :)
par nas75
#63786
webmail a écrit : 29 mai 2018 18:12 allé hop mettez à jour pour être mes bétas testeurs :o
hop hop hop :)
Avec les orages, j'ai eu une coupure de courant :(
Mon onduleur a bien fonctionné :geek:
Du coup, j'ai profité de la remise en route pour faire une mise à jour.
Donc, après 2 mois de fonctionnement sans problème avec le firmware 4.3.4.0537, je tente le 4.3.4.0597 :-?
Pour l'instant, je n'ai rien vu de particulier mais je serre les fes*** :oops::mrgreen:
Bonne journée.
par IL-MAFIOSO
#63877
Hello ,
C’est réglé le soucis de la popup intempestive de sécurité qu’on avait avec l’ancien firmware ?
Edit du 04/06 : Tout est en ordre.
Bonjour, Dans la version 5 d'OMV ils ont commence[…]
NAS avec Raspberry Pi 4
Honnêtement le PI4 8Gb a part pour quelques […]
Bonjour à tous, J'ai relu 2 fois le topic […]
Quel est l'intérêt ou la plus-value […]
Ikoula
