Qnap [Firmware Release] QTS 4.3.4.0416 (beta 3) build 20171213
Gravitys
27 Août 2015
351
[Important Notes]
- As QTS previous versions of ARM models do not support snapshots, when you upgrade to QTS 4.3.4, the original volume cannot use this feature immediately. To solve this problem, you have to back up the existing data on your QNAP NAS to external storage. Then you can rebuild the QNAP NAS and take snapshots to the new storage pool with multiple volumes.
- Users can now downgrade QTS on ARM-based models. To downgrade to the target version, first downgrade to QTS 4.3.3.0351 Build 20171023 (or later versions).
- Starting from QTS 4.3.4, QNAP NAS devices no longer support creating storage pools or static volumes using NVMe PCIe/M.2 SSDs. However, this limitation does not apply to the SSDs installed in built-in M.2 slots or on QM2 expansion cards.
[New Features]
Compatibility
- Added support for the TP-Link TL-WDN7200H USB Wi-Fi adapter.
External Storage
- You can now connect a smart phone as an external storage device via the MTP or PTP protocal.
File Station
- Added support for viewing 360° videos and photos in File Station Media Viewer.
- Added support for opening text files with Text Editor.
- Added access to snapshot features in File Station.
- Added access to Qtier Auto-Tiering features in File Station.
- Added support for playing videos with VLC media player in File Station.
- Snapshot Manager can be opened from File Station.
- Snapshot Directory enables users to view and restore snapshots in File Station.
- A shared folder can be automatically migrated to a snapshot shared folder.
GPU
- Added support for discrete GPU cards. A GPU card can improve trascoding performance, and enables your NAS to run HD Station and Linux Station (only supported on TS-1685 and TS-x77 series NAS, but not supported on Linux Station 1.4).
myQNAPcloud
- Users can now use their phone number as their QNAP ID when registering the NAS to their myQNAPcloud account.
Qboost
- New application Qboost helps you optimize RAM usage, clear junk files and schedule your applications.
Qtier Auto Tiering
- Added more Qtier reporting options.
- You can specifiy times that Qtier should not perform auto-tiering in both Qtier scheduling modes.
- Qtier's algorithms have been updated to improve random access performance.
Qtier has a new automatic optimization mode, where advanced settings such as tiering priority, SSD tier reserved space and data allocation priority are hidden.
- A normal storage pool can now be converted to a Qtier storage pool at any time.
RAID 50/60
- RAID 50 and RAID 60 can be used with Qtier and static volumes.
Resource Monitor
- Resource Monitor now shows shared graphics memory usage.
- Resource Monitor now shows dedicated graphics card memory usage.
Snapshot
- Reserved snapshot space has been updated and renamed to "Guaranteed Snapshot Space"
- Added snapshot support for certain ARM-based NAS models (TS-x31P, TS-x31X, TS-x35 series)
- Storage & Snapshots contains new snapshot overview and summary pages.
- When creating a new snapshot timezone information is now included in the snapshot name.
- In Snapshot Manager, files and folders can be restored from a snapshot to a remote location or as a new shared folder.
- File-based LUNs can now be viewed in Snapshot Manager, and can also be restored to their source volume as a new LUN.
Snapshot Replica
- Added new Snapshot Replica backup plans and schedules.
Storage Management
- RAID 50 and RAID 60 are now supported.
- Added instructions on how to fix a RAID group which is in a degraded or error state.
- "Secure Erase" enables you perminantly erase all data from a disk, with three modes: complete erase, ATA command erase and fast erase.
- A thick volume can now be converted to a thin volume.
Users can now adjust RAID rebuild, migration, scrub, sync priority and speed.
Video Station
- Added support for the HTTP Live Streaming protocol.
[Enhancements]
App Center
- QTS now displays a warning message and asks for confirmation when installing a 3rd-party application.
- App Center now helps with dependencies between dependent applications.
Control Panel
- QTS now displays information about QM2 expansion cards in "Control Panel" > "System" > "System Status" > "Hardware Information".
File Station
- File Station now displays information about SSD cache and Qtier auto-tiering.
- Updated the @Recently-Snapshot folder icon in SMB shares.
- A snapshot shared folder can now be created using thick provisioning.
HD Station
- Users can now access HybridDesk Station via Remote Desktop without connecting the NAS to an HDMI monitor.
Kernel
- "Updated the kernel version from 3.10.20 to 4.2.8 for the following models:
TS-231+, TS-431+, TS-531P, TS-131P, TS-231P, TS-431P, TS-231P2, TS-431P2, TS-431X, TS-531X, TS-831X, TS-431X2, TS-431XU, TS-431XU-RP, TS-831XU, TS-831XU-RP, TS-1231XU, TS-1231XU-RP, TS-431XeU, TS-1635."
Qtier Auto Tiering
- Users can now disable Qtier auto-tiering on individual shared folders or LUNs.
QTS
- QTS desktop features an enhanced volume control (only for certain NAS models with a built-in speaker)
- A beginners guide to QTS is shown to new users when they first log into QTS.
- Increased file-based SWAP size to 16GB on advanced NAS models.
Resource Monitor
- Resource Monitor now shows system services and system processes seperately.
Snapshot
- A LUN snapshot can now be reverted while the LUN is mapped to an iSCSI target.
- The automatic deletion of old snapshots can now be disabled.
- Hidden files can be made visible in Snapshot Manager.
- "Storage & Snapshots" replaces "Storage Manager". It includes a redesigned and improved storage management interface.
- Reduced the memory requirement for using snapshots from 4GB to 1GB. The maximum number of snapshots per volume/LUN/NAS is dependent on the amount of installed memory.
SSD Improvement
- The SSD cache flush algorithms have been updated for better caching performance when under high load.
- A disk trim and performance test is now automatically performed when creating a RAID group.
Storage Management
- Improved the storage pool and volume creation wizards.
- Thin volume space can now be automatically reclaimed if storage pool space is low.
- Updated Virtualization Guide content.
- Changed the default bytes per inode options when creating a volume.
- Added a free storage pool space wizard to help create free pool space.
- Detailed RAID scrubbing results including fixed block counts are now recorded in the system event log.
- Added support for creating storage spaces of over 16TB on certain ARM-based NAS (TS-x31P, TS-x31X, TS-x35 series).
- Thin volumes now get status read/delete instead of read-only when their parent storage pool is full. This enables you to delete data and free up storage pool space.
[Fixed Issues]
- Fixed multiple buffer overflow vulnerabilities that could allow for remote code execution (CVE-2017-17029, CVE-2017-17030, CVE-2017-17031, CVE-2017-17032, CVE-2017-17033).
- Fixed a vulnerability in Samba to prevent heap memory leak (CVE-2017-15275).
- Fixed a use-after-free vulnerability in Samba (CVE-2017-14746).
- QTS would not display the "What's New" window using the default language.
- CloudLink would display the connection status as abnormal after users updated QTS from 4.3.3 to 4.3.4.
- QNAP does not guarantee that USB Wi-Fi adapters can be compatible with QTS 4.3.4 (or later versions).
- QTS desktop would display erroneous messages about disabling services or apps after users restarted the NAS.
- QTS would display an incorrect error message when users created a snapshot shared folder with a large quota even if the folder was successfully created.
- Users could not upload an image as a movie poster on Video Station.
- Users could not mount an NFS shared folder after enabling the NFS v4 protocol.
- QTS would not correctly display the icon of Storage & Snapshots when users logged on to QTS via myQNAPcloud.
- Users could not upload files to virtual disks (iSCSI LUNs on a remote NAS) via File Station.
- QTS could not display correct information about QM2 on the dashboard and in Control Panel > System > System Status.
- The TS-x31P could not detect hard drives after users updated QTS from 4.3.3 to 4.3.4 and then downgraded QTS to 4.3.3.
- Storage & Snapshots would display an incorrect confirmation message before users checked file system for a volume.
Merci, c'est étrange je reste "bloqué" en 4.3.4.0411 (Beta 3) build 20171208 je ne l'ai pas encore elle.
