Qnap [Firmware Release] QTS 4.3.4.0370 (beta) build 20171103 for x86 models
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
QTS 4.3.4.0370 (Beta) build 20171103 for x86 models
[Important Notes]
[New Features]
Compatibility
- Added support for the TP-Link TL-WDN7200H USB Wi-Fi adapter.
External Storage
- You can now connect a smart phone as an external storage device via the MTP or PTP protocal.
File Station
- Added support for viewing 360° videos and photos in File Station Media Viewer.
- Added support for opening text files with Text Editor.
- Added access to snapshot features in File Station.
- Added access to Qtier Auto-Tiering features in File Station.
- Added support for playing videos with VLC media player in File Station.
- Snapshot Manager can be opened from File Station.
- Snapshot Directory enables users to view and restore snapshots in File Station.
- A shared folder can be automatically migrated to a snapshot shared folder.
GPU
- Added support for discrete GPU cards. A GPU card can improve trascoding performance, and enables your NAS to run HD Station and Linux Station (only supported on TS-1685 and TS-x77 series NAS, but not supported on Linux Station 1.4).
myQNAPcloud
- Users can now use their phone number as their QNAP ID when registering the NAS to their myQNAPcloud account.
Qboost
- New application Qboost helps you optimize RAM usage, clear junk files and schedule your applications.
Qtier Auto Tiering
- Added more Qtier reporting options.
- You can specifiy times that Qtier should not perform auto-tiering in both Qtier scheduling modes.
- Qtier's algorithms have been updated to improve random access performance.
Qtier has a new automatic optimization mode, where advanced settings such as tiering priority, SSD tier reserved space and data allocation priority are hidden.
- A normal storage pool can now be converted to a Qtier storage pool at any time.
RAID 50/60
- RAID 50 and RAID 60 can be used with Qtier and static volumes.
Resource Monitor
- Resource Monitor now shows shared graphics memory usage.
- Resource Monitor now shows dedicated graphics card memory usage.
Snapshot
- Reserved snapshot space has been updated and renamed to "Guaranteed Snapshot Space"
- Storage & Snapshots contains new snapshot overview and summary pages.
- When creating a new snapshot timezone information is now included in the snapshot name.
- In Snapshot Manager, files and folders can be restored from a snapshot to a remote location or as a new shared folder.
- File-based LUNs can now be viewed in Snapshot Manager, and can also be restored to their source volume as a new LUN.
Snapshot Replica
- Added new Snapshot Replica backup plans and schedules.
Storage Management
- RAID 50 and RAID 60 are now supported.
- Added instructions on how to fix a RAID group which is in a degraded or error state.
- "Secure Erase" enables you perminantly erase all data from a disk, with three modes: complete erase, ATA command erase and fast erase.
- A thick volume can now be converted to a thin volume.
Users can now adjust RAID rebuild, migration, scrub, sync priority and speed.
Video Station
- Added support for the HTTP Live Streaming protocol.
[Enhancements]
App Center
- QTS now displays a warning message and asks for confirmation when installing a 3rd-party application.
- App Center now helps with dependencies between dependent applications.
Control Panel
- QTS now displays information about QM2 expansion cards in "Control Panel" > "System" > "System Status" > "Hardware Information".
File Station
- File Station now displays information about SSD cache and Qtier auto-tiering.
- Updated the @Recently-Snapshot folder icon in SMB shares.
- A snapshot shared folder can now be created using thick provisioning.
HD Station
- Users can now access HybridDesk Station via Remote Desktop without connecting the NAS to an HDMI monitor.
Qtier Auto Tiering
- Users can now disable Qtier auto-tiering on individual shared folders or LUNs.
QTS
- QTS desktop features an enhanced volume control (only for certain NAS models with a built-in speaker)
- A beginners guide to QTS is shown to new users when they first log into QTS.
- Increased file-based SWAP size to 16GB on advanced NAS models.
Resource Monitor
- Resource Monitor now shows system services and system processes seperately.
Snapshot
- A LUN snapshot can now be reverted while the LUN is mapped to an iSCSI target.
- The automatic deletion of old snapshots can now be disabled.
- Hidden files can be made visible in Snapshot Manager.
- "Storage & Snapshots" replaces "Storage Manager". It includes a redesigned and improved storage management interface.
- Reduced the memory requirement for using snapshots from 4GB to 1GB. The maximum number of snapshots per volume/LUN/NAS is dependent on the amount of installed memory.
SSD Improvement
- The SSD cache flush algorithms have been updated for better caching performance when under high load.
- A disk trim and performance test is now automatically performed when creating a RAID group.
Storage Management
- Improved the storage pool and volume creation wizards.
- Thin volume space can now be automatically reclaimed if storage pool space is low.
- Updated Virtualization Guide content.
- Changed the default bytes per inode options when creating a volume.
- Added a free storage pool space wizard to help create free pool space.
- Detailed RAID scrubbing results including fixed block counts are now recorded in the system event log.
- Thin volumes now get status read/delete instead of read-only when their parent storage pool is full. This enables you to delete data and free up storage pool space.
[Fixed Issues]
- Fixed multiple vulnerabilities in WPA2 to prevent the exposure of sensitive information via Wi-Fi networks (CVE-2017-13077, CVE-2017-13078, CVE-2017-13079, CVE-2017-13080, CVE-2017-13081, CVE-2017-13082, CVE-2017-13084, CVE-2017-13086, CVE-2017-13087, CVE-2017-13088).
- Changed the maximum numbers of supported expansion units for the NAS models with Annapurna Labs processors. For details, see below:
TS-1635: 1 x UX-800P or 1 x UX-500P
TS-431XU, TS-431XU-RP, TS-431XeU:  1 x UX-1200RP, 2 x UX-800U-RP, or 1 x UX-1200U-RP and 1 x UX-800U-RP
TS-831XU, TS-831XU-RP: 1 x UX-1200U-RP or 1 x UX-800-RP
TS-1231XU, TS-1231XU-RP: 1 x UX-1200U-RP or 1 x UX-800U-RP
TS-531P, TS-431X, TS-431X2, TS-531X, TS-831X: 2 x UX-800P or 2 x UX-500P
- HybridDesk Station no longer displays information about non-existing HDMI ports on the TVS-882ST2.
[Known Issues]
- Unable to delete files via SMB when a volume is in read/delete mode.
- If users select all NAS ports for port trunking, the "Port Trunking" button will disappear and users will not be able to delete existing trunk groups.
https://download.qnap.com/Storage/HS-251/HS-251_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/IS-400/IS-400_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20171103-4.3.4.0370.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20171103-4.3.4.0370.zip
Parfait ça merci ! N'hésitez pas à faire vos retours pour ceux qui peuvent tester cette première mouture ! :D
ehehe, désolé mais j'étais un peu pris au taf en ces derniers temps :)
T'enquête pas, je vais m'assurer que ton help desk log ne soit pas vide :lol:
Bon je viens de l'installer sans soucis pour l'instant :)
Première remarque sur QBoost ... Sympa dans l'idée mais peut mieux faire dans la formulation ! Je m'explique : Il indique une "Mémoire libre" toujours minable, le robot pleure, c'est la tristesse ! :( Et donc on est tenté de la libérer avec l'outil. Très bien sauf qu'il s'agit en fait de la mémoire libre du système SANS compter la mémoire utilisée en cache ! Donc en fait le système va très bien, il a par exemple 5% de libre et 45% de cache, on panique et on vide le tout, et bien on va ralentir le système car on vide son cache. C'est contre productif, il faudrait indiquer la quantité dispo de ram comme le monitoring classique du NAS.
Je l'ai testé puis j'ai du downgrader car :
Une fois la mise à jour effectuée, le reboot du NAS ne se faisait pas, même en me connectant à QTS et en lui demandant de rebooter était sans effet...
J'ai donc du l'éteindre manuellement, ce qui fait que j'ai eu pleins d'erreurs au démarrage.
L'assistant restait présent à chaque connexion à QTS malgré la case cochée "Ne plus afficher"
Impossible de me connecter à distance à QTS
Ainsi que d'autres erreurs que je n'ai pas bien compris..
Bref, je suis repassé à la 4.3.3 et même revenir à la 4.3.3 n'a pas été si simple.
je vais attendre la version stable
Bon Finalement, j'ai réussi à remettre la version 4.3.4
Les erreurs ne sont pas réapparues et le problème de connexion à distance venait simplement du fait que mon fournisseur internet à remis la config de ma box par défaut...
Bref, ça fonctionne.
Par contre, je viens de lire l'article https://www.cachem.fr/qnap-expo-2017-nouveautes-qts-4-3-4-plus-de-nas/ sur Cachem, ou il parle de l'application Cinema28.
Je n'ai pas encore pu l'essayer ou même la trouver et le lien de l'article me redirige vers Acronis True Image.
C'est normal ?
Merci.
Mikiya a dit:
Tout à fait d'accord: j'ai 16 go de RAM, même pas tout remplis, et le petit robot pleure comme un gamin :lol:
Au moins, il devrait dire plus clairement ce qui occupe autant et comment..
Pour le reste, je n'ai pas testé pour l'instant.
Merci pour cette beta.
Moi le robot me dit "mémoire suffisante" et ne pleure pas du tout :).
:lol:
Ce matin une mise à jour de Photo Station m'est proposée.
Par contre impossible de procéder à la mise à jour : Photo Station can only run on firmware version 4.3.4 or newer.
Je suis pourtant avec la version citée ici en objet.
Tiens ben justement mise à jour de QBoost pour corriger la mémoire, c'est bien mieux ainsi :cool:
