Qnap [Firmware release] QTS 4.3.3.0299 build 20170901
QoolBox
Représentant QNAP
2 Janvier 2014
10 565
163
153
50
www.qnap.com
changelogs
QTS 4.3.3.0299 Build 20170901
[Important Notes]
[New Feature]
- TwonkyMedia DLNA Server v8.3 is now a built-in feature for certain NAS models.
- Added a message to remind users that the performance of domain controllers may be affected if the system memory is less than 2 GB.
- Added support for connecting to the Internet via PIX-MT100 LTE USB dongle.
[Fixed Issues]
- Fixed a vulnerability in the Linux kernel that could be exploited to circumvent the stack guard page (CVE-2017-1000364). This fix is available to all NAS models that support QTS 4.3.3.
- Updated the version of MariaDB to 5.5.57 to fix multiple vulnerabilities.
- Updated the version of PHP to 5.6.31 to fix multiple vulnerabilities.
- Fixed multiple command injection vulnerabilities.
- Updated the version of the Portable UPnP SDK (libupnp) to 1.6.22 to fix a vulnerability that could allow for unauthorized modification to arbitrary files (CVE-2016-6255) and a heap overflow vulnerability that could be exploited to execute arbitrary code or cause a denial of service (CVE-2016-8863).
- Fixed a command injection vulnerability in Media Library to prevent unauthorized remote command execution.
- Users could not copy files to a mounted shared folder after installing Container Station on the TS-870.
- Users can now perform and complete McAfee antivirus scan jobs.
- The details of users would not be displayed in "Control Panel" > "Privilege" > "User Groups" when the group name contained certain characters.
- The configuration buttons in "Control Panel" > "Privilege" > "Domain Security" would be incorrectly disabled after users joined the NAS to a domain and then updated the QTS version to 4.3.3.
- Performing I/O tests on the TS-EC1279U would cause the NAS to randomly restart.
- Installing and using Container Station on the TS-EC1679U would cause the NAS to run out of memory and then restart.
- Users could not access folders with circular symbolic links via AFP.
- File Station could not correctly display the properties of Qsync files or folders.
- When users synced the same shared folder to two devices using two accounts, some synced files would be missing on one of the devices.
- Duplicate files might appear in the destination folder when users uploaded a large number of files to the synced shared folder.
- Qsync could not sync the files in a shared folder if the option "Only admin can create files/folders" was enabled for its parent folder.
- On the TS-431X, the clock speed of the CPU was not correctly displayed in "System Information".
- Active Directory users could not access the previous versions of a shared folder on Windows.
- Active Directory users would not be immediately blocked from or logged out of Qsync after the NAS left an - Active Directory domain.
- Remote controls might not function correctly after the NAS woke up from the S3 Sleep Mode.
- Users could not complete upload tasks when uploading large files to Amazon Drive.
- Users could not join the NAS to an Active Directory domain if SMB1 was disabled on the Active Directory server.
- The NAS occasionally could not connect to the Internet after users created a virtual switch with the system default gateway.
- The network configuration of the Thunderbolt Bridge would revert from a static IP address to an automatic IP address after users restarted the NAS.
- Backup Station could not correctly display the time left, the transfer speed, or the job status of RTRR FTP jobs in the "Job Status and Logs".
- After uploading files from a Mac to a NAS shared folder, users could not transfer the files to Windows 7 or Windows Server 2008.
- Fans would rotate at an abnormally high speed after users set the fans to the Quiet Mode and then restarted the NAS.
- After restarting the NAS when migrating the folder to an encrypted folder, users could not access a shared folder via SMB.
- The settings of the primary DNS server would not be correctly configured when Domain Controller was enabled.
- Antivirus scan jobs could not be completed if users uploaded renamed virus definition files.
- Non-admin users could not run NAS-to-NAS backup jobs on Backup Station.
- Users could not back up the files in certain paths to an external storage device using USB One Touch Copy.
- Duplicate users would appear as user groups after administrators granted folder permissions to domain users via Windows ACL.
- Using Rsync commands on a command line interface would cause errors after users updated the version of QTS to 4.3.3.0238.
- Administrators could not grant users permission to access the NAS via SSH if their usernames contained a whitespace character.
- Users could not enable RAID Scrubbing again if they did not modify the previous RAID Scrubbing schedule.
- Users could not select the highest SMB version on the TS-x31, TS-x28, and TAS-x68 series.
- The Control Panel interface would take longer to respond when users added a large number of IP addresses to the blacklist or whitelist.
- Users could not access the NAS running certain QTS versions when using Firefox 54.0.1 and Java 8 Update 144 - (32-bit).
- The option to specify snapshot reserved space was available during QTS installation on the NAS models that do not support snapshot features.
- Some NFS shared folders would not be mounted after users restarted the NAS.
- StarWind iSCSI Initiator would stop responding when accessing the iSCSI targets after users updated the QTS version to 4.3.3.
- An error about default gateway configuration would occur when users signed in to myQNAPcloud if VLAN was enabled and static IP address was used for a network interface.
- Users could not remotely access the NAS via CloudLink when the access control permission in myQNAPcloud was set to "Private".
- Users were unable to install Let's Encrypt on myQNAPcloud after installing QTS SSL Certificate.
- After taking snapshots for shared folders and then updating the QTS version to 4.3.3, users could not access the previous versions of shared folders on Windows via SMB.
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_count=74
https://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/HS-251/HS-251_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/IS-400/IS-400_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TAS-X68/TAS-X68_20170901-4.3.3.0299.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20170901-4.3.3.0299.zip
Bien cool tout ça :)
Je lance la MAJ ce soir en rentrant ;)
[New Feature]
Il me semblait que Twonky était payant, je me trompe peut être ...
Et puis il y avait :
QoolBox a dit:
[ QTwonky ] [ 8.4.2] DLNA Server [ Trial ]
juste pour le fun, si comme moi vous avez une licence Twonky
et comme Qnap ne compte pas renouveler le contrat avec Twonky, je prends le relais avec la version Trial officiel
Bref ça m'étonne ce revirement de situation :lol:
OMG, est ce enfin la fin de mes galères avec HBS et Amazon Drive ???
Je ne vais pas crier victoire avant d'avoir fais plusieurs tests.
Par contre j'ai beau vérifier les MAJ du firmware, le NAS ne me trouve pas de MAJ.
Avoues Stéphane quand tu as lu cette ligne tu as pensé à moi lol
P.S : Si finalement le problème serait résolu via un update de firmware, cela voudrait dire que le soucis venait pas d'HBS mais du NAS en lui même ( QTS )
QoolBox a dit:
Ce lien (le premier de la liste en fait) n'est pas valide, pas de chance pour mon TS-431+, il devra attendre :p
Edit : Ha non j'ai fini par l'avoir :lol: :lol:
Bon il y a un truc la ... Après la fin du premier update j'ai demandé à redémarrer, en vain, j'ai fini par le couper au bouton. Je relance, je demande à redémarrer, idem en vain. Je le coupe avec "reboot -f" du coup, je refais une installation de l'update (au cas ou elle avait foirée avant), et redémarrage, idem pas moyen... Donc en 4.3.3.0299 pour ma part sur 251+ pas moyen d'avoir un reboot normal qui marche :(
edit : bon la même avec reboot -f ça fait rien, je peux donc rien tenter de plus à distance et je suis bloqué en attendant de rentrer le couper électriquement encore...
J'ai un problème similaire sur mon TVS-463 depuis quelques MAJ (et l'installation de la carte QM2).
Il se bloque sur "Rebooting System" -> obligé de passer par l'extinction sauvage du bouton power.
Lors du redémarrage il se bloque avant le premier bip.
j'ai résolu le problème temporairement en éteignant le NAS, en retirant les racks disques, redémarrage, attente du premier bip puis réinsertion des 4 disques et là ça passe ...
Bien pratiques les racks finalement, je me verrais mal faire la manip avec un machin qu'il faut ouvrir en 2 pour dévisser et déconnecter les disques des ports SATA ...
J'envisage d'acheter d'occasion un QNAP 459 pro II. Je vois que le firmware 4,3,3 n'est pas supporté.
Est ce que cette limitation est définitive ou peut on espérer une man ?
Antoine
antoinec78 a dit:
il ne faut pas confondre : Il y aura des mises à niveau, mais pas en 4.3.
Le TS-459 Pro II est plafonné en 4.2.
La dernière release est datée du 05/09, donc il y a toujours du support pour les questions de sécurité, mais pas de nouvelles fonctionnalités.
Merci pour ta réponse.
C'est bien ce que j'ai vu et je trouve dommage que ce NAS soit bridé au niveau des évolution.
Antoine
antoinec78 a dit:
Antoine
Je ne sais pas si bridé est le terme exact, vu le proc et la mémoire disponible (Atom D525+1Go) si je ne me trompe pas, faire tourner les dernieres evolutions de QTS me semble utopique.
peut être que je me trompe, mais il me semble que Qnap limite les evolutions en fonction des capacités du hard et pas de la roadmap... enfin j'espère...
fbernard a dit:
antoinec78 a dit:
J'ai ma réponse sur le site de Qnap.
Pour les series xx9, arrêt des mises à jour le 31 octobre 2017.
Je vais regarder ailleurs :(
Pour info si vous avez un ancien NAS qui ne fait pas la mise à jour vers 4.3.3
Qnap propose un ODR,... une offre de remise sur un NAS de votre choix ... suffit de contacter le service commercial France
QoolBox a dit:
Qnap propose un ODR,... une offre de remise sur un NAS de votre choix ... suffit de contacter le services commercial France
Intéressant... merci de l'information !
je pense que c'est plus ta partie librairie multimédia que photo station
à mon avis doit y a voir ta base de corrompu.. tu confirmes que c'est la même chose et que tu ne peux ajouter de répertoire dans celle-ci ?
QoolBox a dit:
Je peux ajouter un dossier (il apparait en bas, même si je n'ai pas cliqué sur le bouton Enregistrer) depuis la configuration de PhotoStation,
mais je n'ai rien que le nom, après toutes les colonnes sont vides.
attention je parle pas de photostation, mais de la librairie multimedia du NAS dans QTS...
les deux sont étroitement liés... si ca plante de se côté là, y ade forte chance que cela impacte photostation
