Qnap [Firmware Release] QTS 4.3.3.0229 build 20170624
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
[Important Notes]
- QTS 4.3.x is the final available firmware update for the following models:
  TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Enhancements]
- Improved the compatibility of the third and fourth drive bays on the TS-451A with high-capacity hard drives.
[Fixes]
- No disk I/O errors occur when an external storage device is selected as the destination for cloud-to-local sync jobs on Hybrid Backup Sync.
- Download Station does not lose connection when multiple download tasks are completed in a short period of time.
- The NAS can still join an Active Directory domain when SMB 1 is disabled on the Active Directory server.
- No connection issues occur when users access certain VPN servers via L2TP/IPSec or OpenVPN using QVPN.
- Domain users can access shared folders after installing a certain Qfix and then restart the NAS.
- The configuration of the DHCP server of the USB QuickAccess port does not affect the DHCP service in Container Station.
- Subtitles can be correctly displayed when users play .mp4 files on File Station.
- VJBOD disconnections do not cause Download Station to stop even when the download locations of download tasks are on the VJBOD volumes.
- Fixed multiple security vulnerabilities regarding input validation and access control.
- Temporary folders can be successfully deleted after users finish backing up files from the QNAP NAS to non-QNAP NAS devices via RTRR.
- Users can successfully delete a large number of LUNs using Cinder without causing Storage Manager interface to stop responding.
- The system does not erroneously display the message "update failed" when users enable or disable antivirus in Control Panel.
[Other Changes]
- In this update, RAID scrubbing is automatically scheduled. RAID scrubbing checks the data integrity of all RAID 5 and RAID 6 groups on the NAS. Running this check regularly is recommended. Storage performance might be degraded while RAID scrubbing is running. You can modify the schedule at "Storage Manager" > "Global Settings" > "RAID Scrubbing".
- After updating the NAS managed by Q'center from 4.2.x to 4.3.x, the administrator of Q'center must input the password of each NAS to continue monitoring.
- Virtualization Station
  Due to advancements in the backup features, virtual machines created in older versions (1.x/2.x) of Virtualization Station can no longer be backed up and restored in 3.0. (A workaround is to clone an older Virtual Machine; the cloned VM can be backed up/restored, but all original snapshots will be removed)
https://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/HS-251/HS-251_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/IS-400/IS-400_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20170624-4.3.3.0229.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20170624-4.3.3.0229.zip
En cours d'installation, je vois que mon NAS avait à priori un soucis sur les 2 dernières baies.
Par contre je ne comprend jamais pourquoi, je ne vois jamais mon NAS dans la liste des NAS compatibles et pourtant j'ai la maj de proposé...
Merci pour l'info, je teste la maj ce soir ...
Après l’installation d'une carte QM2 j'ai eu un soucis de reboot j'attends donc d'être à coté du NAS pour lancer la MAJ, je vous tiens informés de l'opération ;)
MAJ faite sur mes 2 unités.
Aucun soucis au niveau du TS-431+ par contre j'ai des problèmes de boot sur le TVS-463 ...
Depuis l'installation de la carte QM2 je suis obligé de retirer mes disques (sinon pas de bip et blocage sur "booting system" en mode infini), un fois le NAS démarré je dois remonter mon volume en réinsérant les disques dans les baies :?
Je le trouve super long!
Là il est sur "rebooting system please wait..." et rien ne bouge depuis un bout de temps sauf la led orange LAN!
normal ?
