Qnap [firmware release] QTS 4.2.4_20170313 for all model
QoolBox
Représentant QNAP
2 Janvier 2014
10 565
163
153
50
www.qnap.com
QTS 4.2.4 Build 20170313
[Bug fixes]
- Fixed an issue where an error message would appear when the Docker Certificate expired due to users manually setting the time forward.
- Fixed an issue where RTRR FTP backup jobs would not accept passwords that contained more than 16 characters.
- Fixed an issue where users could not upload files larger than 4 GB in File Station when using Internet Explorer 11.
- Fixed an issue where bluetooth devices would disappear from the device list after Container Station was installed and enabled.
- Fixed an issue where users could not connect a Mac to the NAS when using L2TP/IPsec VPN service.
- Fixed an issue where the System Logs would incorrectly display VPN connections as PPTP when PPTP was enabled.
- Fixed an issue where unexpected errors would occur when key combinations were used consecutively in HybridDesk Station.
- Fixed an issue where users could not use Affinity Photo to edit the photos in NAS shared folders mounted on OS X via AFP.
- Fixed an issue where the system would not automatically check for available firmware updates when users logged in after setting the date format as DD/MM/YYYY.
- Fixed a configuration file vulnerability that could be exploited to compromise the security of sensitive data. (CVE-2017-5227)
- Fixed an Apache HTTP Server vulnerability that could be exploited to deny requests to a server. (CVE-2016-8740)
- Fixed a stack overflow vulnerability that could be exploited to gain control of the EIP register.
- Fixed a SQL injection vulnerability that could be exploited to execute arbitrary SQL commands
- Fixed a command injection vulnerability in transcoding that could be exploited to execute unauthorized commands.
- Fixed a heap overflow vulnerability.
- Fixed a cross-site scripting vulnerability that could be exploited to inject arbitrary JavaScript commands.
- Fixed 2 stack overflow vulnerabilities that could be exploited to cause segmentation faults and gain control of the EIP register.
- Fixed a command injection vulnerability in transcoding that could be exploited to gain the administrator privileges and execute unauthorized commands
- Fixed a command injection vulnerability that could be exploited to gain the administrator privileges and execute unauthorized commands. (CVE-2017-6361)
- Fixed a command injection vulnerability that could be exploited to gain the administrator privileges and execute unauthorized commands. (CVE-2017-6359)
- Fixed an access control vulnerability that would incorrectly restrict authorized user access to resources.
- Fixed 2 stack overflow vulnerabilities.
https://eu1.qnap.com/Storage/HS-210TurboNAS/HS-210_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/HS-251/HS-251_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/IS-400/IS-400_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-110TurboNAS/TS-110_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-112TurboNAS/TS-112_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-119TurboNAS/TS-119_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-120TurboNAS/TS-120_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-121TurboNAS/TS-121_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-210TurboNAS/TS-210_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-212TurboNAS/TS-212_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-219TurboNAS/TS-219_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-220TurboNAS/TS-220_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-221TurboNAS/TS-221_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-410TurboNAS/TS-410_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-412TurboNAS/TS-412_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-420TurboNAS/TS-420_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-421TurboNAS/TS-421_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-469U-RP/TS-469U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-470U-RP/TS-470U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-531P/TS-531P_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-563/TS-563_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-809U-RP/TS-809U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-869U-RP/TS-869U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-870U-RP/TS-870U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X31/TS-X31_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X31U/TS-X31U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X35/TS-X35_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X51/TS-X51_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X51A/TS-X51A_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X51U/TS-X51U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X53/TS-X53_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X53A/TS-X53A_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X53S/TS-X53S_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X53U/TS-X53U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X63U/TS-X63U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X80/TS-X80_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X80U/TS-X80U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X82/TS-X82_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TS-X89U/TS-X89U_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TVS-X63/TVS-X63_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TVS-X71/TVS-X71_20170313-4.2.4.zip
https://eu1.qnap.com/Storage/TVS-X71U/TVS-X71U_20170313-4.2.4.zip
je n'arrive plus à suivre ????? loool
4.2.4 et 4.3.3 ya combien de firmware ????? je suis sur 4.3.3
Janick25 a dit:
c'est simple :
Branch 4.2.x = Branche Stable du Firmware
Branch 4.3.x = Branche Beta du Firmawe (sauf modèles x73, x53B, x68, x31x, x28)
D'accord je vois bcp plus clair maintenant...merci
J'attends avec impatience la version finale pour tout remettre au propre.
Par contre, on tjr pas une fourchette pour la version finale 4.3.3 ??? 2 mois, 6 mois?
