Qnap Firmware release] - QTS 4.2.2.2_20161208 for all models
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
QTS 4.2.2 Build 20161208
[Bug fixes]
-Fixed an issue where Syslog server would not send notification emails when system errors occured.
-Fixed an issue where the upload speed on TS-563 in a 10GbE environment was lower than expected.
-Fixed an issue where taking a large number of snapshots on a volume would cause RTRR jobs to stop unexpectedly
-Fixed an issue where encrypted folders with the ! character (exclamation mark) in their passwords could not be unlocked.
-Fixed an issue where Qfinder could not display the direct link IP address of the second of two Macs connected to the NAS via Thunderbolt.
-Fixed an issue where the NAS would not go into HDD Standby Mode as scheduled.
-Fixed an issue where CPU fans on TVS-882 would sporadically fail after the firmware was updated to 4.2.2_20161028 or newer versions.
-Fixed an issue where the NAS would not respond after users connected a Wi-Fi dongle to the NAS.
-Fixed an issue where Music Station would not show media folders added from VJBOD after the NAS rebooted.
-Fixed an issue where File Station would not display the subfolders in certain folders on the left panel.
-Fixed an issue where the information of the default gateway would disappear from the DHCP server settings window after the NAS rebooted.
-Fixed an issue where users could not enable Domain Controller on QTS 4.2.2_20161117.
-Fixed an issue where unsupported Thunderbolt devices would appear on the list of available interfaces when users created a virtual switch in QTS 4.2.2.
-Fixed an issue where Music Station could not display the album covers of the music files stored on other volumes.
-Fixed an issue where Download Station could not download files from certain magnet links.
-Fixed an issue where users could not share domain links via emails or to social networking websites in Photo Station.
-Fixed an issue where the message "External IP has changed, update ddns" would appear in the system event logs even though the external IP address did not change.
-Fixed an issue where NAS-to-NAS backup jobs would fail when "Replicate ACL and extended attributes" is enabled.
-Fixed an issue where RTRR backup jobs would repeatedly upload and update files that were not modified.
-Fixed an issue where TS-x53A with certain firmware versions could not detect D-Link DWA-172 AC600.
-Fixed an issue where the Samba/CIFS upload/download speeds in a 10GbE environment was slower than expected.
-Fixed an issue where the IP address of the DNS server would be displayed incorrectly after users enabled and then disabled Domain Controller.
-Fixed an issue where all the backup jobs for external drives would disappear after users updated the firmware from 4.2.0 to 4.2.2.
-Fixed an issue where users could not create volumes larger than 16 TB in Storage Manager on the x59 series.
-Fixed an issue where "priRequest.cgi" would use too many CPU resources after a large number of snapshots were mounted and the Quota feature was enabled.
-Fixed an issue where connecting to a CHAP-protected iSCSI target without authenticating the connection would cause a call trace.
http://eu1.qnap.com/Storage/TS-120TurboNAS/TS-120_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X35/TS-X35_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X53S/TS-X53S_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-563/TS-563_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-421TurboNAS/TS-421_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-470U-RP/TS-470U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X31U/TS-X31U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-410TurboNAS/TS-410_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TVS-X63/TVS-X63_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-531P/TS-531P_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X63U/TS-X63U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-870U-RP/TS-870U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X82/TS-X82_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/HS-251/HS-251_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-1269U-RP/TS-1269U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/HS-210TurboNAS/HS-210_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-210TurboNAS/TS-210_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-112TurboNAS/TS-112_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-420TurboNAS/TS-420_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X51/TS-X51_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X89U/TS-X89U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/IS-400/IS-400_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-809U-RP/TS-809U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-412TurboNAS/TS-412_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-119TurboNAS/TS-119_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X80U/TS-X80U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-221TurboNAS/TS-221_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X53A/TS-X53A_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X53/TS-X53_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-121TurboNAS/TS-121_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-212TurboNAS/TS-212_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X51U/TS-X51U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-219TurboNAS/TS-219_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TVS-X71/TVS-X71_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X53U/TS-X53U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-531X_831X/TS-X31X_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-869U-RP/TS-869U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-220TurboNAS/TS-220_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X51A/TS-X51A_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-469U-RP/TS-469U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X31/TS-X31_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-1270U-RP/TS-1270U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-1679U-RP/TS-1679U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X85U/TS-X85U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-1279U-RP/TS-1279U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-110TurboNAS/TS-110_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-X80/TS-X80_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TVS-X71U/TVS-X71U_20161208-4.2.2.zip
http://eu1.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20161208-4.2.2.zip
Merci :geek: En attendant une version 4.3 sur arm (et qu'elle se stabilise un poil) c'est bien !
Mais toujours pas de news de HBS ?... :?
Ok merci, pas encore de changement depuis l'interface, je verrai ce soir si il la voit sinon je lui forcerais la main.
