Forum des NAS
QTS 4.2, QTS 4.3, QTS 4.4, QTS 4.5, QTS 5.0...
Avatar de l’utilisateur
par QoolBox
#37199
Le firmware 4.3.2 Public Beta sort ce soir (Taiwan Time)
Le live update pour les series x51 & x53 sera mis en place ce soir, et pour les autres modèles Lundi prochain
QTS 4.3.2 Public Beta
Code : Tout sélectionner
[New feature]
Security:
- Added support for certificates from Let's Encrypt.
- Users can now be forced to change their passwords on a regular basis.
Help Center:
- Enhanced the Help Center UI to provide a better user experience.
Notification:
- Added a firmware update notification.
- Added browser notifications
Installation:
- Added support for establishing CloudLink connections during Cloud installation
QTS desktop:
- More customization options have been added to the login screen.
App Center:
- Apps can now send notifications and be automatically updated..
Network:
- Port trunking general warnings have been replaced with individual warnings.
- Users can now examine the change in network status after a system restart.
- Virtual Switch
(1) Added support for the combination of different physical adapters, virtual adapters. of virtual machines, virtual adapters of containers, and Thunderbolt interfaces.
(2) Added support for STP (Spanning Tree Protocol) to prevent network loops.
(3) Added support for NAT (Network Address Translation).
(4) Virtual switches can now be set as the default gateway.
[Bug fixes]
- Fixed an issue where Download Station would not find any results after searching on certain torrent sites.
- Fixed an issue where users could still transfer files via USB QuickAccess even when it was disabled.
- Fixed an issue where segmentation faults would appear in the kernel logs during smoke testing on certain models.
- Fixed an issue where the "Embedding subtitles when playing videos" option in the Media Streaming Add-on would disappear.
- Fixed an issue where Resource Monitor would not display all of the processes.
- Fixed an issue where domain users and groups would not be shown on the interface in Domain Controller.
- Fixed an issue where some strings in the Port Trunking Wizard would not be correctly presented.
- Fixed an issue where the transmission rates shown in Resource Monitor's "Network Usage" section would be underestimated.
- Fixed an issue where users would not see the successful installation message when using HDMI installation.
- Fixed an issue where users could not remove storage pools and volumes at the same time in Storage Manager.
- Fixed an issue where TS-112P would not go into Standby Mode even after a designated period of inactivity.
- Fixed an issue where the NAS could not create thumbnails for pictures whose filename contained the "%" character.
- Fixed an issue where running the help command in CLI mode would cause a segmentation fault on QTS 4.3.0.
- Fixed an issue where the firmware update progress on ARM models would be shown as decimal numbers.
Intel/ AMD Link
http://download.qnap.com/Storage/HS-251/HS-251_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/IS-400/IS-400_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-469U-RP/TS-469U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-470U-RP/TS-470U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-563/TS-563_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-869U-RP/TS-869U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-870U-RP/TS-870U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X51/TS-X51_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X51A/TS-X51A_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X51U/TS-X51U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X53/TS-X53_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X53A/TS-X53A_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X53S/TS-X53S_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X53U/TS-X53U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X63U/TS-X63U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X80/TS-X80_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X80U/TS-X80U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X82/TS-X82_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TS-X89U/TS-X89U_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TVS-X63/TVS-X63_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TVS-X71/TVS-X71_20161202-4.3.2.0017.zip
http://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20161202-4.3.2.0017.zip
Dernière modification par QoolBox le 13 déc. 2016 12:30, modifié 4 fois.
par giopas
#37211
je suis chaud! :)
j'espère aussi qu'il sera possible de faire une connection à une folder remote d'un autre NAS qui a le 2FA activé car mnt (avec l'alpha) cela n'est pas possible. :)
  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
J'ai vu que le Mode Actif de FileZilla permet de &[…]
En faite, tu peut activer ou non le versioning. […]
Coup de gueule !
Ah Fx excuse-moi , mais tu sais il faut pas trop c[…]
Cadenas en https
Effectivement cela peut-être un pb de naviga[…]
Ikoula
