Qnap [ Firmware Release ] QTS 4.2.2.20160812
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
QTS 4.2.2.20160812
[New feature]
Storage management:
- VJBOD host functions are now supported by the x89, x82, x80, x79, x71, x70, x63, x53, x51, IS-400 Pro series (with firmware 4.2.2. or newer).
- NAS models that support Storage Pools and iSCSI service with firmware 4.2.1 (or newer) can be used as a remote NAS for VJBOD. Refer to the product specifications for details.
Audio Alert (models with speakers):
- Added Voice Alert.
Smart Fan(x82 only):
- Added separate fan controls for system and CPU.
Volume Control (models with speakers)
- Added volume control options in the QTS desktop toolbar (TBS-453A and TVS-x82 series).
Helpdesk:
- Added Helpdesk.
File Station
- Added support for directly opening .eml files using QmailAgent in File Station.
Container Station
- Added bridge mode in Container Station (every container can have its own unique IP).
[Enhancement]
Virtualization Station 2.2
- Added support for automatically checking network connections and remote storage capacities of imported/exported VM in Virtualization Station.
[Known issue]
Back up
- The Container Station folder can only be backed up using Rsync when no containers are running. It is recommended to use the import/export feature in Container Station to back up containers.
Container Station
- Setup default folder of Contrainer Station on a VJBOD shared folder and reboot VJBOD would cause Container Station crash. Container Station v1.6 will not support VJBOD and filter out all VJBOD  shared folders.
[Bug fixes]
QTS
- Fixed an issue where File Station would fail to move all of the files from an NTFS-formatted external device to the NAS.
- Fixed an issue where File Station would be unable to stream videos to media players.
- Fixed an issue where Samba might crash after backing up a domain controller database.
- Fixed an issue where editing file permissions in File Station would fail (with a “Permission Denied” message).
- Fixed an issue where a Time Machine backup job would fail if the "save encryption key" option is disabled during the volume creation process.
- Fixed an issue where the system fan would keep rotating at a high speed after the CPU temperature decreases.
- Fixed an issue where a backup job (with the “Delete extra files” option enabled) would fail after deleting files in the source directory.
- Fixed an issue where the system would fail to detect mSATA drives after scanning disks for bad blocks.
- Fixed an issue where the NAS may reboot during an I/O test.
- Fixed an issue where CEC-enabled devices would fail after connecting a NAS to one of these HDMI devices.
http://download.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20160812-4.2.2.zip
http://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X53S/TS-X53S_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-809U-RP/TS-809U_20160812-4.2.2.zip
http://download.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20160812-4.2.2.zip
http://download.qnap.com/Storage/SS-469/SS-469_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-110TurboNAS/TS-110_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20160812-4.2.2.zip
http://download.qnap.com/Storage/HS-251/HS-251_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X51U/TS-X51U_20160812-4.2.2.zip
http://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20160812-4.2.2.zip
http://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X80U/TS-X80U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X31+/TS-X31+_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20160812-4.2.2.zip
http://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X31P/TS-X31P_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20160812-4.2.2.zip
http://download.qnap.com/Storage/TVS-X71/TVS-X71_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X89U/TS-X89U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X80/TS-X80_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X53U/TS-X53U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20160812-4.2.2.zip
http://download.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X31X/TS-X31X_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-869U-RP/TS-869U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X31U/TS-X31U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X31/TS-X31_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X51/TS-X51_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X63U/TS-X63U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-210TurboNAS/TS-210_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-563/TS-563_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-470U-RP/TS-470U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TVS-X63/TVS-X63_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-531X/TS-531X_831X_20160812-4.2.2.img
http://download.qnap.com/Storage/TS-X53A/TS-X53A_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-469U-RP/TS-469U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-X53/TS-X53_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20160812-4.2.2.zip
http://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-410TurboNAS/TS-410_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-870U-RP/TS-870U_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20160812-4.2.2.zip
http://download.qnap.com/Storage/IS-400/IS-400_20160812-4.2.2.zip
http://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20160812-4.2.2.zip
Super, merci Stéphane ! La première feature c'est la plus importante pour moi, mis à part la résolution des problèmes avec les repositories tierces (qui ont été résolues n'est pas ?).
Mnt je n'ai plus d'excuses pour m'acheter un TS-453A qui va avec le TS-243Pro :)
Sent from my A0001 using Tapatalk
Merci Stéphane ! Je commençais à désespérer :lol:
Comme mon voisin du dessus c'est la nouvelle fonctionnalité que j'attendais :)
Donne-nous une petite avant première des changements de la 4.3.0!
Question bête : je ne vois pas le lien pour mon NAS (TS-x53Pro), est-ce qu'il faut que j'utilise le TS-x53?
EDIT: je vois de toute façon que QTS voit déjà qu'il y a un nouveau firmware. Je vais faire faire la mise à jour automatique alors :)
Bonjour ;)
J'ai mis en place et testé le VJBOD, c'est juste génial, j'en ai rêvé QNAP l'a fait ! :D
Ça se fait très simplement à partir du moment où l'on a un pool de stockage avec un minimum d'espace libre sur l'unité cible ;)
Attention toutefois si vous cochez le mode web sécurisé à bien changer le port (8080 vers 443) pour que ce soit détecté :lol:
Pour le reste cela permet de créer des dossiers et des partages exactement comme sur l'unité principale, ils sont visibles dans Filestation par vos utilisateurs, si tant est qu'ils aient les droits ;)
Bref chapeau bas QNAP c'est du super boulot ! C'est une option qui va faire pencher la balance en votre faveur :geek:
Par contre ce n'est pas sur que vous continuiez à vendre des unités UX et TX après ça :p
Ekto63 a dit:
Bonjour ;)
à vrai dire vu le prix des expander, mieux acheter un NAS à mon avis et utiliser VJBOD comme tu dis ;)
je viens d'updater mon TBS-453A, vla maintenant qu'il cause... j'avais oublié qu'il y avait des enceintes intégrés.. ca surprend :lol:
Gros bug sur la sauvegarde RRTR ?
Je rencontre un problème curieux depuis la mises à jour en 4.2.2.
J'ai une sauvegarde RRTR qui fonctionnait ainsi:
-Mode synchronisation
- Distant -> Local
- TS-112P -> TS-251
Depuis la mise à jour du firmware, j'ai une erreur d'appairage des dossiers.
Je remplace le dossier distant à sauvegarder par le dossier distant "Public"
Ça semble marcher. Sauf que... Il vient de me sauvegarder le dossier local "Public" dans le répertoire de sauvegarde au lieu du dossier distant !!!
Je crée un partage sur le serveur local du même nom que le partage distant à sauvegarder.
Je remet ma conf d'origine. Et ça remarche. Enfin presque, puisqu'il me sauvegarde le dossier local !!!
J'ai l'impression qu'il se mélange les pinceaux entre les dossiers locaux et distants :-(
Du coup, plus de sauvegarde de mon NAS distant.
Quelqu'un est dans le même cas ?
QoolBox a dit:
C'est évident quand on voit le prix de ces unités ça refroidi, j'avais longuement pesé le pour et le contre avant d'en venir à acheter mon TS-431+, j'avais bien entendu déjà parler du VJBOD à cette époque et de la fameuse fonction ISCI Block based ce que la version "non +" ne prend pas en charge il me semble ;)
Sans compter que le marketing est assez avare niveau infos en ce qui concerne ces unités, vu le tarif demandé on regarde à plusieurs fois ...
Bref j'étais tombé sur la super occas sur Ebay 220€ le TS-431+ FDPI et du coup je regrette pas mon choix :)
QoolBox a dit:
En effet ça doit surprendre :D
plop3 a dit:
Pas eu de soucis particulier de mon côté, as-tu tenté de récréer la tache et tester sur un petit nombre de fichiers ?
