Qnap [Firmware release] - QTS4.2.0 build 20160203 official release for TAS series
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
Le TAS passe en firmware 4.2.0 ce soir
TAS-168/TAS-268
2016-02-03
4.2.0 Build 20160203
QTS 4.2.0 Build 0203 for TAS
[Enhancement]
- QTS: Upgrades main system to QTS 4.2.0. Please refer to:
https://www.qnap.com/qts/4.2/ for more information about the enhancements and
changes in QTS 4.2. Some features may not be available on TAS-168/TAS-268. Please
check the software specification page for details.
[Bug fix]
- Android: The Auto Updater will no longer crash when there is no Internet connection.
- Android: Google Play™ will no longer display “Require Wi-Fi connection” when
downloading large files.
- Android: Fixed an issue that would cause Google Play™ 6.0.5 to crash when launched.
- Android: Fixed a compatibility issue with Amazon Video.
- Android: GMS settings will be skipped and when initializing Android in the region does
not support Google Services.
- QTS: Fixed an issue that stops the Antivirus from updating virus definitions.
[Known issue]
- Older versions of iOS Qremote may crash when trying to connect to a TAS that is set to
the Japanese UI in Android. Please update iOS Qremote to 1.0.10.
[Notice]
- You must connect a keyboard and mouse to the TAS if you plan to set up using HDMI
output.
- Android is enabled by default. You can disable/enable it by pressing and holding the USB
copy button for 6 seconds.
- When you connect USB storage to the TAS, Android will create two folders ("Android"
and "obb") on it.
- Pre-installed Google Apps may not work if Google Services are blocked by your firewall.
- Downgrade QTS to 4.1.4 may cause system become unstable after upgrade to QTS 4.2.0.
Please make sure you have back up important data if you plan to perform manual
downgrade.
