Qnap [ Firmware Release ] - QTS 4.2.1 Build 20160201 Public Beta
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
QTS 4.2.1 Build 20160201 Public Beta dans le live update demain
QTS4.2.1 Build 20160201
[Bug Fixes]
Fixed an issue where the  Expand Capacity button will be enabled before changing any drive in Storage Manager.
Fixed an issue where an increasing amount of system RAM will be displayed while copying a large number of small files to the NAS.
Fixed an issue where the unallocated size will change after taking snapshots, copying some files, then rebooting the NAS.
Fixed an issue where the content of encrypted folders are not included in snapshots.
Fixed an issue where the system will fail to create a snapshot replica job to a remote NAS when there is a special character ')' in the password.
Fixed an issue where there is nothing shown in Background Tasks after Snapshot Replica is executed.
Fixed an issue where the system log shows "The file system is not clean...." when rebooting with various apps launched and RTRR in process.
Fixed an issue where the Media Library would occasionally show incomplete file information when changing the iTunes media folder to the NAS multimedia folder.
Fixed an issue where the WebDAV connection would fail after the HTTPS port is changed to 443.
Fixed an issue where the content page of songs would be cleared when uploading specific MP3 files.
Fixed an issue where the AFP connection would be interrupted when connecting through an encrypted folder.
Fixed an issue where files would be incompletely moved when repeatedly moving files between a shared folder and an external folder in File Station.
Fixed an issue where changing folder permissions would not take effect if changing the folder permissions from R/W to Read-only via Samba protocol.
Fixed an issue where the connection would fail during backing up a VM image to an external device.
Fixed an issue where an error message would appear when performing a RTRR task to backup files from local to remote and placing a folder to the source folder through SAMBA protocol.
Fixed an issue where the total number of music in the Media Library would be incorrect when adding .cue, .flac, and MP3 files into a folder.
Fixed an issue where the system would become unresponsive when uploading high-resolution pictures in Photo Station.
Fixed an issue where an error message would appear after creating a backup job and selecting specific folders in the source and destination folder where the selected folders have a prefix “share” in the folder name.
Fixed an issue where files in the root folder would become folders after cloning a Snapshot.
Fixed an issue where the system would show a warning message when linking to an OpenVPN server.
Fixed an issue where the log file would report incorrect information when swapping HDD locations in a NAS and removing the pool.
Fixed an issue where the pool expansion operation would fail.
Fixed an issue where the system would be unable to show a clear indication of the maximum volume size when creating volume with default settings.
Fixed an issue where the volume resize operation would fail if the file system is not clean.
Fixed an issue where background tasks would be stuck in a calculation step when uploading files to File Station using Firefox.
Fixed an issue where the “copy the link” option cannot be selected in download operations when sharing files with share links with the Android browser.
Fixed an issue where "Compression" in Backup settings would be unable to remain on the edit page when doing iSCSI Storage.
[Known issues]
A NAS may occasionally reboot twice and display a "The system was not shut down properly last time" in the system log.
iSCSI LUNs may be occasionally missing after 2-3 days in a environment with prolonged heavy I/O loading.
et les liens pour les plus pressés
http://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20160201-4.2.1.zip
http://download.qnap.com/Storage/HS-251/HS-251_20160201-4.2.1.zip
http://download.qnap.com/Storage/IS-400/IS-400_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-469/SS-469_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-110TurboNAS/TS-110_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-210TurboNAS/TS-210_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-410TurboNAS/TS-410_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-469U-RP/TS-469U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-470U-RP/TS-470U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-563/TS-563_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-809U-RP/TS-809U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-869U-RP/TS-869U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-870U-RP/TS-870U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31/TS-X31_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31+/TS-X31+_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31P/TS-X31P_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31U/TS-X31U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X51/TS-X51_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X51U/TS-X51U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53/TS-X53_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53A/TS-X53A_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53S/TS-X53S_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53U/TS-X53U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X63U/TS-X63U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X80/TS-X80_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X80U/TS-X80U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X89U/TS-X89U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TVS-X63/TVS-X63_20160201-4.2.1.zip
http://download.qnap.com/Storage/TVS-X71/TVS-X71_20160201-4.2.1.zip
http://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20160201-4.2.1.zip
J'ai du aussi refemmarer 1 fois, et aprės toujours ce ventillo qui se declenche plusieurs fois á tout moment :evil:
darnak a dit:
Il y un patch pour ce problème: http://forum.qnap.com/viewtopic.php?f=151&t=119274&start=15#p532168
Pour ceux qui n'ont pas de compte, je mets la procédure ici : Téléchargez le fichier à cette adresse https://drive.google.com/file/d/0B2ipctij9EKqYzh5ZWlneHBGNFk/view et mettez le fichier .BIN dans le dossier Public. Installer la mise à jour en passant par ssh
hal_app --update_ec_fw file=/share/Public/QX47EC14.BIN
hal_app --reset_ec_fw
La seconde commande va arrêter votre NAS. Redémarrez-le et tout devrait rentrer dans l'ordre.
FX Cachem a dit:
:eek: je te les ai filé ?
ou big brother est dans le site :lol:
et il y aura CERTAINEMENT OCEANKTV.... fonctionnel... intégré... promis juré depuis des semaines.... :twisted: :twisted:
Mes 2 micros HF sont impatients d'envoyer du bois dans les 2 gros jacks arrière... :geek:
superboost a dit:
c'est pas le Karaoké qui me semblait le plus attrayant, mais je peux comprendre :)
pour ma part c'est davantage le boost dans la navigation des fichiers et les nouvelles fonctions de virtualisation qui m'interressent
j'ai mis la version beta, il me semble qu'il y a un bug au niveau de l'utilisation Ethernet
j'ai 2 box, et le nas est sur les deux, mais la passerelle est sur une seule
l’Ethernet 1 a un débit entrant constant de 440ko/s en moyenne, pourtant, rien ne rentre dans le théorie et je ne vois pas ce qui peut afficher ça
si je vais sur le moniteur, tantôt il affiche bien ces 440ko tantôt il est a 0, mais si je me met sur la ligne du bas de la grille, il m'affiche 440k.
dans le tableau de bord, par contre, il l'affiche tout le temps
j'oubliais, j'ai un 453A avec 4 ports Ethernet
lol, c'est pas un bug, je viens de comprendre, j'ai une camera, ça enregistre en permanence, c'est ça qui occupe la bande passante.
hello, des news de la version finale ? ça fait un moment que c'est repoussé il me semble ?
