Qnap [Firmware Release] QTS 4.4.1.0949 Build 20190528 Public Beta for all models except TS-X41/TS-X31X/TS-531P
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
QTS 4.4.1.0949 Build 20190528 beta
[Important Notes]
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.4.1 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: "phpEasyProject", "Dolphin", "CMS Made Simple", "Vtiger CRM", "iStat", and "PostgreSQL".
- QTS 4.4.1 currently does not support QcalAgent or Notes Station 2. QNAP will add support for these applications in upcoming updates.
[New feature]
Control Panel - Multimedia Console
- Replaced Multimedia Management with Multimedia Console.
- Added support for sorting and hiding categories.
- Added feature that automatically uses image files as thumbnails for videos with the same filename.
- Added volume control function.
- Added support for new movie and TV show categories.
Virtualization Station
- vQTS 4.4.1 supports local installation via HTML5 console.
Control Panel - Hardware
- vQTS 4.4.1 supports GPU pass-through from Virtualization Station. This makes the resources of the assigned GPU available for use by the apps/services of that vQTS.
Encyption
- Added support for managing shared folder encryption in File Station.
File Station
- Added support for document collaboration via Microsoft Office Online.
Qtier
- Added support for removing the ultra-high speed (SSD) tier from a Qtier auto-tiering storage pool.
Snapshot
- Added Smart Snapshot Retention feature. Snapshots can now be retained by time period (hourly, daily, weekly, monthly).
Storage Management
- Added support for creating hardware-encrypted storage pools using SED drives.
- Added support for creating a one-time scheduled file system check.
- Storage & Snapshots now tracks and displays the estimated remaining life of SSDs.
- Added support for Fibre Channel storage protocol.
- QNAP drive adapters QDA-A2AR and QDA-A2MAR can now be used to create NAS storage space.
- QNAP drive adapter QDA-UMP can now be used to create NAS storage space.
User Group
- Added quota support for user groups.
Encyption
- File Station supports encryption and decryption for files with the ".qenc" extension.
Expansion Card
- Added support for Mustang-F100 FPGA and Mustang-V100 VPU cards. You can go to Control Panel and assign them as resources for the OpenVINO™ Workflow Consolidation Tool.
App Center
- Added support for validating digital signatures and certificates.
CacheMount
- Files on mounted Google Drive accounts (.gdoc, .gslides, .gsheet) can now be downloaded as Microsoft Office files (.docx, .pptx, .xlsx) in File Station.
Network and Virtual Switch
- Added support for displaying Fibre Channel adapter information and status.
Resource monitor
- Added support for displaying kernel processes on the system processs category.
File Sharing Protocol
- Added support for Samba 4.7.
[Enhancement]
CacheMount
- The new CacheMount application has replaced remote mount in File Station. Install CacheMount from the App Center to keep using remote mount services.
Control Panel - Daylight SavingTime
- Added support for cross-year daylight saving time settings.
- Moved Media Streaming Add-on to App Center repository.
QTS - Security
- Added version settings for TLS.
- Added support for HTTP compression.
UPS
- Added support for up to 20 UPS devices.
Web Server
WebDAV
- WebDAV is now disabled by default.
Storage Management
- Updated IronWolf Health Management (IHM) to support new Seagate IronWolf and IronWolf Pro drive models.
- QTS can now check for firmware updates for connected expansion devices and then prompt you to update them each time you log in.
- Added indicators for interfaces that support WoL.
File Station
- Added support for checking access logs in file or folder properties in File Station.
Performance
- Reduced and optimized the maximum latency for SSD storage space.
[Other Changes]
Library
- Updated to SQLite 3.26.0.
- Updated the Apache version to 2.4.39.
- Updated the PHP version to 7.3.4.
File Station
- Removed the "Show files and folders of my PC" function from File Station.
/Storage/HS-251/HS-251_20190528-4.4.1.0949.zip
/Storage/Mustang-200/Mustang-200_20190528-4.4.1.0949.zip
/Storage/QB-103/QB-103_20190528-4.4.1.0949.zip
/Storage/TS-KVM/TS-KVM_20190528-4.4.1.0949.zip
/Storage/TS-X28A/TS-X28A_20190528-4.4.1.0949.zip
/Storage/TS-X31P2/TS-X31P2_20190528-4.4.1.0949.zip
/Storage/TS-X31XU/TS-X31XU_20190528-4.4.1.0949.zip
/Storage/TS-X32/TS-X32_20190528-4.4.1.0949.zip
/Storage/TS-X32U/TS-X32U_20190528-4.4.1.0949.zip
/Storage/TS-X35/TS-X35_20190528-4.4.1.0949.zip
/Storage/TS-X35A/TS-X35A_20190528-4.4.1.0949.zip
/Storage/TS-X51/TS-X51_20190528-4.4.1.0949.zip
/Storage/TS-X51A/TS-X51A_20190528-4.4.1.0949.zip
/Storage/TS-X51B/TS-X51B_20190528-4.4.1.0949.zip
/Storage/TS-X51U/TS-X51U_20190528-4.4.1.0949.zip
/Storage/TS-X53/TS-X53_20190528-4.4.1.0949.zip
/Storage/TS-X53II/TS-X53A_20190528-4.4.1.0949.zip
/Storage/TS-X53B/TS-X53B_20190528-4.4.1.0949.zip
/Storage/TS-X53BU/TS-X53BU_20190528-4.4.1.0949.zip
/Storage/TS-X53D/TS-X53D_20190528-4.4.1.0949.zip
/Storage/SS-X53/TS-X53S_20190528-4.4.1.0949.zip
/Storage/TS-X53U/TS-X53U_20190528-4.4.1.0949.zip
/Storage/TS-X63U/TS-X63U_20190528-4.4.1.0949.zip
/Storage/TS-X72/TS-X72_20190528-4.4.1.0949.zip
/Storage/TS-X72U/TS-X72U_20190528-4.4.1.0949.zip
/Storage/TS-X73U/TS-X73U_20190528-4.4.1.0949.zip
/Storage/TS-X77/TS-X77_20190528-4.4.1.0949.zip
/Storage/TS-X77U/TS-X77U_20190528-4.4.1.0949.zip
/Storage/TS-X80/TS-X80_20190528-4.4.1.0949.zip
/Storage/TS-X80U/TS-X80U_20190528-4.4.1.0949.zip
/Storage/TS-X82/TS-X82_20190528-4.4.1.0949.zip
/Storage/TS-X82S/TS-X82S_20190528-4.4.1.0949.zip
/Storage/TS-X82U/TS-X82U_20190528-4.4.1.0949.zip
/Storage/TS-X83XU/TS-X83XU_20190528-4.4.1.0949.zip
/Storage/TS-X85/TS-X85_20190528-4.4.1.0949.zip
/Storage/TS-X85U/TS-X85U_20190528-4.4.1.0949.zip
/Storage/TS-X88/TS-X88_20190528-4.4.1.0949.zip
/Storage/TS-X89U/TS-X89U_20190528-4.4.1.0949.zip
/Storage/TS-XA28A/TS-XA28A_20190528-4.4.1.0949.zip
/Storage/TS-XA51/TS-XA51_20190528-4.4.1.0949.zip
/Storage/TS-XA73/TS-XA73_20190528-4.4.1.0949.zip
/Storage/TS-XA82/TS-XA82_20190528-4.4.1.0949.zip
/Storage/TS-X63/TVS-X63_20190528-4.4.1.0949.zip
/Storage/TS-X71/TVS-X71_20190528-4.4.1.0949.zip
/Storage/TS-X71U/TVS-X71U_20190528-4.4.1.0949.zip
/Storage/TS-X73/TVS-X73_20190528-4.4.1.0949.zip
Je viens de tester le fait de retirer le tier le plus rapide, et c'est limite mensonger.
Mon cas, un tier de stockage (des hdds) et un high speed tier (des ssd, 1.6tb). J'ai environ 5tb de dispo sur le tier de stockage, et j'ai environ 16% d'utilisé sur le tier de sdd.
Quand je veux retirer mon tier le plus rapide, ça me dit non, car il faut 2tb de dispo sur les autres tiers, ce qui n'a aucun sens... Vu que je n'ai pas 2tb de stocké sur le tier le plus rapide, et dans tous les cas j'ai de la place dispo dans l'autre tier...
ton tiers rapide fait 2TB...
il faut donc libérer 2 TB sur l'autre pool...
le tiering c'est comme du span ... c'est agrégé, s'il veut pouvoir démonter la partie SSD, tout doit redescendre les datas de l'autre côté
QoolBox a dit:
Mais je n'ai que 16% d'utilisé sur ce pool de 1.6tb. Si je désactive l'auto qtiering sur tous les dossiers, ça me descend toutes les données sans soucis sur le storage, et j'ai un tier rapide vide...
Actuellement , ça voudrait dire que j'aurais du créer mon 1er volume de "stockage", en laissant en non alloué l'espace de mon tier rapide (que je ne pouvais prévoir à l'époque), pour qu'il puisse réaliser son opération. Ce qui n'a aucun sens au niveau usage... Là, ma seule solution serait de repasser en thin, voir si je peux réduire mon tier de "stockage" (et non "tout" le volume), puis refaire la manip de supprimer mon tier rapide...
certains modèle resteront en 4.3.6 comme le x79...
pour x70 je suis pas certain.. faut que j'aille à la pêche aux infos
QoolBox a dit:
Merci...
Sinon, il faudra que je trouve une astuce pour prendre le firmware d'un autre NAS pour le mettre sur le mien :twisted:
Avec TVS-473 et le Firmware en question.
L' installation manuelle dans HD-STATION mouline indefiniment. Elle ne s'execute donc pas . Pour en sotir je suis obligé de fermer l' onglet sur mon PC.
Une idée !!
FX Cachem a dit:
QoolBox a dit:
Merci...
effectivement EOL
https://www.qnap.com/en-us/product/eol.php
il est bloqué en 4.3.6 .... :-|
camiel a dit:
Une idée !!
je vois pas même après désinstallation et réinstallation ?
Desinstallation et reinstallation de quoi?
HD-station est en 4.0.2. Aucune installation manuelle ne s' exécute. J' ai redémarré QTS, Hd-station, testé plusieurs QPKG, rien n' y fait ça boucle indefiniment !!
Salut
Pour ma part, soucis dans HBS, les taches ont un statut en erreur alors que tout va bien (en cliquant sur les details de l'erreur on a plus d'info et l'état courant est bon en fait), les dates de dernières synchro sont fausses aussi.
Plus gênant, Photo Station ne voit pas les dossiers que je déclare dans la Multimedia Console, et du coup je n'ai plus de photos ... Et quand je tente de regénérer les miniatures, message d'erreur et ça ne lance rien.
camiel a dit:
ouvre un ticket
Mikiya a dit:
Salut
pareil ouvre un ticket pour chaque problème
QoolBox a dit:
FX Cachem a dit:
QoolBox a dit:
Merci...
effectivement EOL
Ça veut dire que le 470 ne sera plus mis à jour ?
FX Cachem a dit:
QoolBox a dit:
Merci...
Salut FX,
As-tu trouvé une solution pour passer ton x70 en version 4.4 ?
Si oui je suis preneur...
