Qnap [Firmware Release] QTS 4.4.1.0948 Build 20190527 Public Beta
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
for TS-X51/TS-X53
QTS 4.4.1.0948 Build 20190527 for TS-X51/TS-X53
[Important Notes]
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.4.1 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: "phpEasyProject", "Dolphin", "CMS Made Simple", "Vtiger CRM", "iStat", and "PostgreSQL".
- QcalAgent and Notes Station 2 are currently not supported on QTS 4.4.1 but will be available soon.
[New feature]
Control Panel - Multimedia Console
- Replaced Multimedia Management with Multimedia Console.
- Added support for sorting and hiding categories.
- Added feature that automatically uses image files as thumbnails for videos with the same filename.
- Added volume control function.
- Added support for new movie and TV show categories.
Virtualization Station
- vQTS 4.4.1 supports local installation via HTML5 console.
Control Panel - Hardware
- vQTS 4.4.1 supports GPU pass-through from Virtualization Station. This makes the resources of the assigned GPU available for use by the apps/services of that vQTS.
Encyption
- Added support for managing shared folder encryption in File Station.
File Station
- Added support for document collaboration via Microsoft Office Online.
Qtier
- Added support for removing the ultra-high speed (SSD) tier from a Qtier auto-tiering storage pool.
Snapshot
- Added Smart Snapshot Retention feature. Snapshots can now be retained by time period (hourly, daily, weekly, monthly).
Storage Management
- Added support for creating hardware-encrypted storage pools using SED drives.
- Added support for creating CacheMount cache space.
- Added support for creating a one-time scheduled file system check.
- Storage & Snapshots now tracks and displays the estimated remaining life of SSDs.
- Added support for Fibre Channel storage protocol.
- QNAP drive adapters QDA-A2AR and QDA-A2MAR can now be used to create NAS storage space.
- QNAP drive adapter QDA-UMP can now be used to create NAS storage space.
User Group
- Added quota support for user groups.
Encyption
- File Station supports encryption and decryption for files with the ".qenc" extension.
Expansion Card
- Added support for Mustang-F100 FPGA and Mustang-V100 VPU cards. You can go to Control Panel and assign them as resources for the OpenVINO™ Workflow Consolidation Tool.
App Center
- Added support for validating digital signatures and certificates.
CacheMount
- Files on mounted Google Drive accounts (.gdoc, .gslides, .gsheet) can now be downloaded as Microsoft Office files (.docx, .pptx, .xlsx) in File Station.
Network and Virtual Switch
- Added support for displaying Fibre Channel adapter information and status.
Resource monitor
- Added support for displaying kernel processes on the system processs category.
File Sharing Protocol
- Added support for Samba 4.7.
[Enhancement]
CacheMount
- The new CacheMount application has replaced remote mount in File Station. Install CacheMount from the App Center to keep using remote mount services.
Control Panel - Daylight SavingTime
- Added support for cross-year daylight saving time settings.
- Moved Media Streaming Add-on to App Center repository.
QTS - Security
- Added version settings for TLS.
- Added support for HTTP compression.
UPS
- Added support for up to 20 UPS devices.
Web Server
WebDAV
- WebDAV is now disabled by default.
Storage Management
- Updated IronWolf Health Management (IHM) to support new Seagate IronWolf and IronWolf Pro drive models.
- QTS can now check for firmware updates for connected expansion devices and then prompt you to update them each time you log in.
- Added indicators for interfaces that support WoL.
File Station
- Added support for checking access logs in file or folder properties in File Station.
Performance
- Reduced and optimized the maximum latency for SSD storage space.
[Other Changes]
Library
- Updated to SQLite 3.26.0.
- Updated the Apache version to 2.4.39.
- Updated the PHP version to 7.3.4.
File Station
- Removed the "Show files and folders of my PC" function from File Station.
https://download.qnap.com/Storage/TS-X51/TS-X51_20190527-4.4.1.0948.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20190527-4.4.1.0948.zip
TS 253A, inscrit aux bêtas mais pas de distribution proposée par QTS ce jour pour moi, téléchargement sur site QNAP effectué mais installation manuelle ne fonctionne pas.
Je vais attendre patiemment.
KENAVO
Ok merci pour l'info Qoolbox je n'avais pas fait attention aux versions.
CORDIALEMENT
dites-moi avec la Beta 4.4.1.0978 sur le TS-253a-8G (x53II)
Est-ce que vous aussi avec la télécommande vous n'avez plus le menu contextuel grâce au bouton suivant ? :
Merci par avance.
