Qnap [Firmware Release] QTS 4.3.6.0776 build 20181130 for supporting TR-004 official release
QoolBox
Représentant QNAP
2 Janvier 2014
10 565
163
153
50
www.qnap.com
[Important Notes]
- Important: To use a TR-004 external RAID enclosure to expand NAS storage space, the enclosure must have exactly one external RAID group. Individual disks cannot be used to expand NAS space.
- To ensure system functionality, after updating QTS to 4.3.5, please also update Container Station to 1.9 in App Center before enabling QVR Pro.
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- Below are the kernel versions for NAS models that are supported by QTS 4.3.5:
Kernel 3.10.20: TS-128, TS-228
Kernel 3.2.26: TS-x31, TS-x31U
Kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
Kernel 4.2.8: all other models supported by QTS 4.3.5
- Due to the limitations of future kernel updates, QTS 4.3.5 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.5, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Lite.
[New feature]
Storage & Snapshot
- Added support for using a TR-004 external RAID enclosure in NAS Storage mode to expand NAS storage space.
- Added support for using a TR-004 external RAID enclosure in External Storage mode for data transfer.
[Fixed Issues]
- Improved the compatibility with WD 2.5-inch My Passport 4TB external drive (WDBYFT0040BBK-0A) for the following models: TS-451, TS-651, TS-851, TS-453, TS-653, TS-853, TS-453U, TS-853U, TS-1253U.
[Known Issues]
Storage & Snapshot
- If any TR-004 disks contain corrupted external RAID group configurations and the enclosure's RAID configuration is changed using the hardware mode switch, the RAID configuration of the TR-004 might appear as "Unknown". To resolve this issue, use QNAP External RAID Manager or Storage & Snapshots to remove the corrupted RAID groups.
- After formatting a TR-004 external RAID partition on the NAS, restarting the TR-004 might cause the partition name to change.
https://download.qnap.com/Storage/HS-251/HS-251_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/IS-400/IS-400_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/Mustang-200/Mustang-200_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/QB-103/QB-103_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/SS-1279U/SS-1279U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/SS-1879U/SS-1879U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/SS-2479U/SS-2479U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-1079/TS-1079_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-1270U/TS-1270U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-1279U/TS-1279U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X41/TS-131P_231P_431P_X31+_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-1679U/TS-1679U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-470/TS-470_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-470U/TS-470U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-670/TS-670_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-870/TS-870_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-870U/TS-870U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-879/TS-879_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-879U/TS-879U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X77U/TS-X77U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X83XU/TS-X83XU_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20181130-4.3.6.0776.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20181130-4.3.6.0776.zip
J'ai fait la mise à jour... RAS pour le moment. :cool:
Pour info, j'ai du faire la mise à jour obligatoire de Virtualization Station.
Bonne mise à jour alors ! :geek:
J'ai fait la mise a jour en 4.3.6.0776 et il semblerait que j'ai un soucis.
Je n'ai pas d'affichage en hdmi avec hybridDesk.
J'ai testé différentes choses :
redémarrage du service HybridDesk
redémarrage du NAS
désinstaller l'application et la re installer.
changer d'écran
changer le cable HDMI
Via le bureau a distance j'ai vu que le service fonctionne j'ai un affichage mais pas sur la TV.
J'arrive un peu a court d'idée.
Un avis ? des idées ?
Merci par avance.
Non je n'ai pas joué avec la résolution (que je n'ai pas accès non plus il n'y a rien en face de ce paramètre) ni la fréquence. D'ailleurs qu'entend tu par fréquences ? car je n'ai pas ce paramètre dans HDStation dans l'onglet affichage je n'ai que :
résolution
éteindre l'écran au bout de
balayage
fond d'écran
si les résolution n'apparaissent pas dans HDStation sous QTS
il y a un problème de signale... test de changer de cable HDMI...ou de reinstaller HDStation
J'ai déjà changer de moniteur et de câble.
Lorsque je redemarre le NAS j'ai un affichage du kernel et après l'écran "Starting".
Je vais re essayer de re installer Hd Station.
