Qnap [Firmware Release] QTS 4.3.5.0722 build 20181007
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
49
www.qnap.com
[Important Notes]
- To ensure system functionality, after updating QTS to 4.3.5, please also update Container Station to 1.9 in App Center before enabling QVR Pro.
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- Below are the kernel versions for the NAS models supported by QTS 4.3.5:
kernel 3.10.20: TS-128, TS-228
kernel 3.2.26: TS-x31, TS-x31U
kernel 4.2.8: HS-251, SS-x79U, TS-x79, TS-x79U, TS-x70, TS-x70U, TVS-x70, TS-x31P, TS-x31P2, TS-x31+, TS-x31X, TS-x31XU, TS-x28A, TS- x35, TS-x51, TS-x51A, TS-x51U, TS-x53, TS-x53A, TBS-x53A, TS-x53B, TS-x53BU, TS-x53S, IS-453S, TS-x53U, TVS-x63, TS-x63, TS-x63U, TS-x73U, TS-x77, TVS-x80, TS-x80, TVS-x80U, TS-x80U, TVS-x82, TVS-x82S, TVS-1582TU, TS-x85, TES-x85U, TDS-16489U, TVS-x71, TVS-x71U, TVS-x73
- Due to the limitations of future kernel updates, QTS 4.3.5 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.5, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Lite.
[Fixed Issues]
- Removing or disconnecting a disk from a RAID group during Predictive S.M.A.R.T. Migration might sometimes cause data corruption after the rebuilding.
- After users created a port trunking group, System Logs would display unexpected error messages when the NAS woke from sleep mode.
- Users could not install HybridDesk Station on the TVS-1582TU.
- Users could not resize a volume after taking snapshots on other volumes.
- The Virtual JBOD creation wizard would sometimes stop responding.
- File Station could not open PDF files after users updated QTS to 4.3.5.0713 build 20180928.
- After creating URLs for applications using Docker images in Container Station, users could not connect to the URLs in Browser Station or Virtualization Station.
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/HS-251/HS-251_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/IS-400/IS-400_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/Mustang-200/Mustang-200_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/QB-103/QB-103_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/SS-1279U/SS-1279U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/SS-1879U/SS-1879U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/SS-2479U/SS-2479U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-1079/TS-1079_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-1270U/TS-1270U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-1279U/TS-1279U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X41/TS-131P_231P_431P_X31+_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-1679U/TS-1679U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-470/TS-470_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-470U/TS-470U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-670/TS-670_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-870/TS-870_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-870U/TS-870U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-879/TS-879_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-879U/TS-879U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X77U/TS-X77U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20181007-4.3.5.0722.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20181007-4.3.5.0722.zip
Bonjour Qoolbox.
J'ai un TS251 qui est passé en mode lecture seule ce wk.
impossible de réparer...
J'ai eu cette mise a jour de proposé et en désespoir de cause, l'ai installé...
La RAS.
Question: cette mise jour pourrais elle réparer un mauvais FW injecté semaine derniere ?
EDIT: je me suis pas présenté... désolé, je file de ce pas le faire :)
s'il passe en lecture sur la partie volume (pas le RAID)
il y a eut un problème de corruption sur le volume, il est possible que ce firmware corrige ce soucis... en tout cas tu es le premier à qui cela arrive avec le 4.3.5
Bon ravi de le savoir ... ou as :D
En tout cas, je viens de passer la MAJ et de réduire le volume pour mettre un snapshot réplication --> ras. (pas la meilleure idée d'ailleurs que j'ai eu mais bon...)
la je fais vérif de raid --> 69,1% --> ras pour le moment...
bon tant mieux....
Merci de ta reponse ;)
Nas mis a jour hier soir, reboot, mise à jour des applis, utilisé hier soir sans souci
inaccessible ce matin :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
Bref, reboot...
la je flippe... deux reboot plus tard, je n'ai pas de trace du NAS dans le routeur, sur l'afficheur du NAS les IP restent vide...
on voit de l'activité sur le nas, les leds s'agitent, meme celle du lan???
j'ai quoi comme option ?
tu te connectes par HD Station ou par interface web ?
Chez moi, au redémarrage, 4.3.5 désactive HD Station, du coup je suis obligé de me connecter en interface web pour activer HD Station.
Une fois que c'est fait, pas de pb pour utiliser le NAS avec la sortie hdmi et HD Station.
Voilà, début d'idée :-?
Message déjà ouvert sur le forum : https://www.forum-nas.fr/viewtopic.php?f=19&t=10064&sid=934fba69be77a1ea8b077b82371b446f#p68282
Suite à la dernière mise à jour effectuée hier soir, plantage du NAS. Tentative de redémarrage pour solutionner. NAS en carafe sur "Booting ... starting System". Obligé de redémarrer en enlevant un disque, et redémarrer en le remettant, pour forcer la reconstruction du RAID. Je me sers du NAS avec Domoticz, et le port USB de la clef zwave a disparu.
Bref, sympa la mise à jour...
mouaip, ca ne ressemble pas, je n'ai pas les deux bips, le systeme semble demarrer correctement c'est comme si DHCP ne demarrait pas
nas75 a dit:
par le web, enfin quand il obtient une ip... pour l'instant il n'arrive pas jusqu'a cette etape
webmail a dit:
qui a dit que la phase beta était terminée? :)
Ce n'est pas drôle.
le NAS me sert a partager et securiser les documents de notre entreprise (petite certes, mais vitale pour nous..)
j'ai du limiter notre usage: je n'ai plus confiance ni en container station ni note station. Le premier refuse de lancer un container depuis je ne sais plus quelle mise à jour et le deuxieme à perdu toutes les notes dans je ne sais plus quelle bataille (et vu qu'on ne peut plus les sauvegarder en automatique dans la derniere version...)
Aujourd'hui j'utilise Qsync et plex, rien d'autre, je tremble à chaque mise à jour, j'ai banni les betas.
Je n'installe que la deuxieme version stable, et pourtant je me retrouve encore a passer du temps à resoudre des problemes au lieu de developper mon activité...
Bref, ca commence a faire beaucoup
Effectivement, je pense aussi que Qnap devrait soigner un peu plus la partie logicielle (QTS ou applis).
Il y a trop souvent des problèmes (anomalies, régressions,...) suite à des mises à jour.
Du coup, on est réticent à faire ces mises à jour, çà ne va pas dans le bon sens (sécurité par exemple).
Ceci dit, sur 4.3.5, je n'ai pas de gros problèmes (à part HD Station qui est désactivé au redémarrage)... Bizarre quand même ces différences de comportement d'un NAS à l'autre...
Bonne soirée.
ps: çà me fait penser, 4.3.5 apporte "QBelt" dans QVPN Service 2. Si quelqu'un a une info dessus (explication, modop,...), je suis preneur :-? :oops: :geek:
Chez moi pas de souci avec HDStation, mais j'ai fini par résoudre le souci (virtualswitch), mais j'ai encore perdu un temps infini...
c'est peut être parce que je n'ai pas fait les phases beta et la première stable.
Du coup j'ai carrement desinstallé Notestation 3 pour repasser sur la V2, au moins on peut sauvegarder avec celle la
et déjà la version suivante, ca va trop vite ou ce sont des bétas?
4.3.4.0734 build 20181008
[Important Notes]
- To ensure system stability, QNAP recommends updating and then restarting QVPN Service in App Center after you update QTS to 4.3.4.
- As QTS previous versions of ARM models do not support snapshots, when you upgrade to QTS 4.3.4, the original volume cannot use this feature immediately. To solve this problem, you have to back up the existing data on your QNAP NAS to external storage. Then you can rebuild the QNAP NAS and take snapshots to the new storage pool with multiple volumes.
- QTS 4.3.4 is the final available firmware update for the following models:
TS-1269U-RP, TS-869U-RP, TS-469U-RP, TS-469U-SP, TS-869 Pro, TS-869L, TS-669 Pro, TS-669L, TS-569 Pro, TS-569L, TS-469 Pro, TS-469L, TS-269 Pro, TS-269L.
- Starting from QTS 4.3.4, QNAP NAS devices no longer support creating storage pools or static volumes using NVMe PCIe/M.2 SSDs. However, this limitation does not apply to the SSDs installed in built-in M.2 slots or on QM2 expansion cards.
- Below are the kernel versions for NAS models that are supported by QTS 4.3.4:
Kernel 3.10.20: TS-128, TS-228
Kernel 3.2.26: TS-x31, TS-x31U
Kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
Kernel 4.2.8: all other models supported by QTS 4.3.4
[New feature]
- Added a shared folder backup option. This addresses a known issue in macOS High Sierra 10.13.4 and later versions that prevented QTS users from using Time Machine to back up data from their Mac to their QNAP NAS through SMB shared folders.
[Fixed Issues]
- Undeletable snapshots would occasionally appear on certain storage pools.
- Music Station would incorrectly display the length of the last track on a list.
- Deleted files would still appear in @Recycle folders even when users disabled Network Recycle Bin.
- Certain processes would sometimes keep using CPU resources.
- RAID groups could not enter degraded mode after users took snapshots and then remove a component disk.
- The TS-x69 would occasionally stop responding after running out of memory.
- Files in a shared folder mounted on macOS via NFS would display incorrect creation dates.
- Users sometimes could not set the NAS as an additional domain controller.
- The NAS time zone would be changed to GMT +0 after users enabled LDAP Server.
- A certain snapshot-related process would use more memory resources than expected.
- A certain snapshot-related process would use more CPU resources than expected.
- QTS could not correctly display domain users' folder permissions inherited from their user groups.
- QTS would not provide relevant notifications when users could not enable Domain Controller due to the system default gateway not being correctly configured.
- General users could still access @Recycle folders even when the access to Network Recycle Bin was only granted to administrators.
- Users could not join the NAS to an Active Directory domain after enabling Domain Controller.
- Users could not create a subfolder or file in a shared folder mounted via SMB in Windows 10.
- QTS occasionally would not automatically mount volumes after the NAS restarted.
- Users could not restore file-based LUNs from snapshots.
- Snapshot restoring tasks would still run in the background even after the NAS restarted.
- It would take longer than expected to authenticate user connections to NFS shared folders.
- Users could not restore a domain controller database from a backup file on an encrypted system volume。
- Users could not save Microsoft Excel files to a shared folder mounted via AFP on macOS.
bonjour,
C'est quoi ces mises a jour qui te foutent tout en l 'air plus de cameras de nouveau. A chaque mises a jour je flippe maintenant . Pffff. C'est pas sérieux QNAP ça part en C.
