Qnap [Firmware Release] QTS 4.3.5.0713 build 20180928 official release
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
QTS 4.3.5.0713 build 20180928 for all models. live update will be enabled for TVS-x73, TS-x82, TS-x51, TS-x53A, TS-x31, TS-131P, TS-231P, TS-431P, TS-x31+ first
[Important Notes]
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- Below are the kernel versions for the NAS models supported by QTS 4.3.5:
kernel 3.10.20: TS-128, TS-228
kernel 3.2.26: TS-x31, TS-x31U
kernel 4.2.8: HS-251, SS-x79U, TS-x79, TS-x79U, TS-x70, TS-x70U, TVS-x70, TS-x31P, TS-x31P2, TS-x31+, TS-x31X, TS-x31XU, TS-x28A, TS- x35, TS-x51, TS-x51A, TS-x51U, TS-x53, TS-x53A, TBS-x53A, TS-x53B, TS-x53BU, TS-x53S, IS-453S, TS-x53U, TVS-x63, TS-x63, TS-x63U, TS-x73U, TS-x77, TVS-x80, TS-x80, TVS-x80U, TS-x80U, TVS-x82, TVS-x82S, TVS-1582TU, TS-x85, TES-x85U, TDS-16489U, TVS-x71, TVS-x71U, TVS-x73
- Due to the limitations of future kernel updates, QTS 4.3.5 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.5, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Life.
[Known Issues]
- Storage & Snapshots still moves the data in a shared folder to another tier even if auto-tiering is disabled for the shared folder.
- QTS automatically disables and then enables Media Streaming Add-on after the NAS IP address changes.
- Users cannot migrate the system from an NAS installed with QTS 4.3.5 to another NAS installed with QTS 4.3.4 by relocating the disks.
[New feature]
Archive Manager
- Added support for Panasonic Blu-ray archival devices.
- Added QNAP Hybrid Archival Manager.
File Station
- Upgraded the Remote Mount service. It now supports SMBv2 and SMBv3.
- After installing Image2PDF, users can access Image2PDF functions directly from the context menu when selecting images.
HD Station
- HD Station apps can now be installed and managed directly through the QTS App Center.
Installation
- Added cloud installation support through IPv6.
Music Station
- Added support for DLNA Media Server.
Network
- Added a software-defined switch mode.
- Added support for ARM-AL models.
- Added support for stateful/stateless auto-configuration of IPv6 addresses.
- Each network interface now supports separate IPv6 RADVD services.
- Added support for reserved IPs with the IPv4 DHCP service.
- Added support for IPv4 & IPv6 static routing.
- Added more DDNS service providers.
- Added support for customized DDNS.
- Allows multiple DDNS service.
- Added a network topology map for virtual and physical networking.
- Added location information for network and USB-WiFi adapters.
- Added VPN/PPPoE connection status to the overview page.
- Added support to display smart offload features when using QNAP network adapters.
- Moved all system default gateway settings to the interface page.
- VPN/PPPoE connections can now be used as the system default gateway.
- Updated interface for WiFi connections.
- Added support for QNAP PCIe WiFi cards (QWA-AC 2600) in client mode.
Notification Center
- Added support for sending notifications via SMS providers, including Nexmo, Twilio, and Clickatell.
- Added support for Overview and History in Notification Center.
- Added support for 23 languages for notification messages.
- Added support for creating custom notification rules to specify notification criteria, including application categories, severity levels, and keywords.
- Delivery method and message recipient settings are now more flexible.
- Added support for creating multiple notification rules at the same time.
- Added support for sending notifications for a single system event.
- Added Outlook as an SMTP service option.
- Added support for sending notifications via instant messaging applications, including Skype and Facebook Messenger.
QTS - discrete GPU
- Users of certain NAS models can now assign discrete GPU card resources to Container Station (QuAI).
- Added support for multiple discrete GPU cards for certain NAS models.
QTS Desktop
- Certain NAS models can now be configured to play music to help users locate their NAS.
QTS System
- Pre-configured the QTS port to 5000/5001 and WebDAV port to 5007/5008 for certain China-specific NAS models.
- Enhanced the shutdown process user interface. Users can now monitor the status of running applications as the system shuts down.
SAMBA
- Added Microsoft Networking Advanced Options for ABE (access-based enumeration) and ABSE (access-based share enumeration).
- After installing Qsirch, Mac users can now use Spotlight to search files in their mounted QNAP NAS.
- Added a shared folder backup option. This addresses a known issue in macOS High Sierra 10.13.4 and later versions that prevented QTS users from using Time Machine to back up data from their Mac to their QNAP NAS through SMB shared folders.
Storage
- One-time snapshots for file-based LUNs are no longer available, as file-based LUNs can now be protected by volume snapshots.
- Added support for configuring SSD over-provisioning on SSD RAID groups used for SSD cache, storage pools, and static volumes.
- Added support for using RAID 5 and RAID 6 on SSD cache.
- Added support for shrinking thick and thin volumes and converting thin volumes to thick volumes.
- Added support for write-only SSD cache.
- Storage & Snapshots can now perform SSD Trim when creating or enabling SSD cache and when enabling or disabling SSD cache storage.
- Snapshot Manager now allows users to browse, restore, and revert snapshots from a remote Snapshot Vault.
- Added support for exporting or importing source copies when creating snapshot replica jobs.
- Storage & Snapshots now provides support for Seagate IronWolf Health Management (IHM) when compatible Seagate IronWolf drives are detected.
- When creating VJBOD, users can now select interfaces that support the iSER protocol (based on RoCE) to enable iSER connection.
- Added SSD Profiling Tool. This utility tests SSD storage settings such as over-provisioning to help determine the best SSD configuration for your NAS.
- Added LUN Import/Export. This feature enables you to export a snapshot as an image file, which you can use to create or revert a volume/LUN on another QNAP NAS.
- You can now detach and then remove a disk from a RAID group of type: RAID 1, 5, 6, 10.
[Enhancement]
Network
- NCSI (Network Connectivity Status Indicator) services can now be disabled.
- Network interfaces can now display customized names.
- Each network interface now has separate DNS settings.
Resource Monitor
- Added GPU usage statistics in Resource Monitor.
SAMBA
- Added symbolic links options in Microsoft Networking Advanced Options. These allow users to use symbolic links to find and open files.
- Added a new restriction setting in Microsoft Networking Advanced Options. Newly shipped NAS models are now pre-configured to restrict the access of anonymous users, including the Guest account.
Storage
- QNAP recommends performing a file system check for all data volumes after updating QTS to 4.3.5 to upgrade the file system for better system performance and stability.
- Due to a file system upgrade, NAS models with Annapurna Labs processors no longer support downgrading QTS.
- Due to a change in storage architecture, downgrading QTS is no longer allowed when SSD cache is enabled.
- Lowered the memory requirement for using Qtier auto tiering.
- QTS now automatically flushes SSD cache data and upgrades SSD cache after a QTS update.
- Improved the log format of volume, snapshot, and SSD cache features to better integrate with Notification Center.
- Users no longer need to wait for cache flushing when taking snapshots for storage spaces where SSD cache is enabled.
- Added support for performing space reclamation on encrypted thin volumes.
- Added sound effects for snapshots that are taken manually.
- Users can now revert snapshots even when less than 10% of storage pool space is available.
- Enhanced the efficiency of LUN backup and renamed the feature to "LUN Import/Export".
- iSCSI targets and LUNs now have their respective creation wizards.
- Added the option to prevent users from recovering files from snapshots using the "Previous Versions" feature in Windows.
- Added support for formatting external drives to exFAT. (The exFAT license is required.)
- Storage & Snapshots now displays a disk's manufacturer, and its capacity in both binary and decimal format.
- Storage & Snapshots now displays supported ATA commands and advanced features for SSDs.
- QTS increases fan speeds to maximum if the temperature of a disk reaches the temperature warning threshold.
- Added different views for SSD Profiling Tool test results.
- After backing up an encrypted volume or LUN using Snapshot Replica, you can unlock and access the encrypted snapshots on the destination NAS.
System Logs
- System Event Logs now display the application and category information for log entries.
File Station
- Added a lock/unlock encrypted volume feature in File Station.
Installation
- Removed the storage settings from the quick installation wizard. Administrators can still configure the storage settings in QTS.
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/HS-251/HS-251_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/IS-400/IS-400_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/Mustang-200/Mustang-200_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/QB-103/QB-103_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/SS-1279U/SS-1279U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/SS-1879U/SS-1879U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/SS-2479U/SS-2479U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-1079/TS-1079_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-1270U/TS-1270U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-1279U/TS-1279U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X41/TS-131P_231P_431P_X31+_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-1679U/TS-1679U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-470/TS-470_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-470U/TS-470U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-670/TS-670_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-870/TS-870_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-870U/TS-870U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-879/TS-879_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-879U/TS-879U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X77U/TS-X77U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20180928-4.3.5.0713.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20180928-4.3.5.0713.zip
Moi, d'ici deux ou trois release stable.... [emoji3]
Envoyé de mon ONEPLUS A6000 en utilisant Tapatalk
Bon finalement je me suis dévoué... :-?
Alors pour l'instant rien de très problématique :-D mais c'est pour l'instant, je n'ai pas utilisé toutes mes applis non plus.
Par contre:
- l'installation est longue... très longue même.
- une fois redémarré, le NAS va faire une vérification de tous les volulmes puis proposer 2 màj obligatoires (QVPN et Container Station), et plein de màj d'applis,
- je n'ai pas pu terminer l'installation avec HD Station, il faut se connecter au NAS avec un PC,
- par défaut (cf ci-dessus), HD Station n'est pas activé, il faut aller dans le panneau de contrôle pour l'activer,
- je n'ai pas réussi à faire fonctionner normalement VyprVpn (message "Could not resolve") mais je crois que je vais abandonner cette appli (trop de pb dans le temps), un paramétrage manuel dans QVPN à l'air de fonctionner.
Voilà pour chez moi !
Bonne installation alors :geek:
Edit: je rajoute un truc: l'appli SSD profiling tool (nouvelle appli avec 4.3.5) ne peut pas être lancée sans acception d'envoi de données personnelles... je n'aime pas trop le principe :evil:
moi j'ai un soucis depuis la mise à jour :(
toutes mes applis ne s'ouvre plus sur mon navigateur...
un coup de main serait le bienvenu! :cry:
Sorry Qoolbox, problème en partie résolu!
après un reboot les applis principale repartes. :)
cependant "connect to cloud drive" ne se reconnecte pas:
Qcontactz non plus:
que faire de nouveau? :(
He bien moi c'est tout l'inverse !
Installation rapide, et surtout cela a résolu mon problème de leds qui clignotaient comme un sapin de noël depuis des semaines, malgré d'autres maj QTS, réinitialisation, arrêt de services, etc...
Courage.
CORDIALEMENT.
Depuis la MAJ (4.3.4 --­> 4.3.5) mon TS-451+ reste sur l'écran Starting et je ne peu plus y accéder. Je le ping au niveau réseau et je le vois dans Qfinder mais je ne peu rien faire d'autre que de voir les détails et la configuration mais aucune autre option fonctionne. J'ai essayer sans les disques et il semble démarrer normalement comme un neuve sans les disques. J'ai tenté via putty ou en ssh et rien ne veut ce connecter. L'interface web ne fonctionne pas peut importe.
Avez-vous un conseil?
Mat15011 a dit:
Tu tentes d'y accéder en local ou à distance (via myqnapcloud par exemple) ?
Je suppose que tu as rebooté ton Nas ?
Bonne journée
Mat15011 a dit:
Sans disque inséré boot il ? si oui applique cette procédure
Téléchargez le firmware sur notre site et le dézipper
1. Eteindre votre nas
2. Retirer tous les disques (attention de bien les numéroter pour les remettre dans le bon ordre)
3. Demarrer le NAS
4. Attendre 2 bip (1 court puis 1 long)
5. Remettre tous les disques en commençant par le numéro 1 jusque au dernier
6. Attendre le chargement des disques dans le NAS environ 1min
7. Localiser le NAS avec Qfinder (nom du nas: NAS et des chiffres/lettres aléatoires, ex: NAS8D3A22)
Trouvez l'adresse IP du nas
Lancez putty et connectez vous au nas en ssh port 22 http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe avec votre login et mot de passe
(admin / admin )
8. tapez les commandes suivantes:
storage_util --sys_startup
storage_util --sys_startup_p2
umount /dev/md13 ## test lun firmware
e2fsck -f /dev/md13
mount /dev/md13 /mnt/ext
cp /etc/default_config/uLinux.conf /mnt/HDA_ROOT/.config/
rm -r /etc/config
ln -sf /mnt/HDA_ROOT/.config /etc/config
setcfg -f /etc/config/uLinux.conf Misc configured TRUE
ln -sf /mnt/HDA_ROOT/update /mnt/update
Ensuite ouvrez QFinder et refaites une mise à jour avec le dernier firmware si celle-ci échoue redémarrer le NAS (commande : reboot) et retenter le flash du firmware
Merci Qoolbox
J'ai essayé ta méthode vu que je voyais mon qnap dans Qfinder.
Par contre maintenant j'accède à l'interface mais mes disque ce sont mis en Sync du RAID. Alors je ne vois toujours pas mes données, il estime encore a 6h le sync... espèrons.
Et je confirme que c'est le bordel dans les notifications... oufff il y a de l'erreur la de-dans le pire c'est que un firmware supposément stable...
En tout cas je vous tiens au courant merci beacoup.
tu as du faire un reset usine.. du coup smb.conf qui indexe tes partages est reinit
recréé simplement tes partages pour renseigner à nouveau ce fichier de configuration
