Qnap Join the QuWAN Beta Program for your chance to win a TS-253D
QoolBox
Représentant QNAP
2 Janvier 2014
10 559
163
153
50
www.qnap.com
Join the QuWAN Beta Program to Win a TS-253D NAS:
The QuWAN Beta Program is your opportunity to be one of the first to try out its brilliant features!
Remember to send us your feedback
– as 10 beta testers who set up meshed VPN topologies between the most devices and provide the most insightful feedback will win a TS-253D NAS.
Beta Test period starts: 18:00 (UTC+8) 20 May 2020.
Beta Test period ends: 23:59 (UTC+8) 20 July 2020.
Deadline for feedback and bug reports: 23:59 (UTC+8) 20 July 2020.
SD-WAN Solution for Resilient IT Infrastructure
QNAP’s QuWAN SD-WAN solution features Auto Mesh VPN, IPsec encryption and cloud-centric management. Compatible with a wide range of QNAP solutions, QuWAN enables SMBs to efficiently build a dependable network at a cost-effective price, and to facilitate digital transformation, multi-site expansion and remote working.
https://www.qnap.com/static/landing...a_Program_and_Win_a_TS-253D!&utm_medium=email
