Father_Mande met à disposition une update de myHD moteur des applications Kodi18, 17, Plex Media Player, etc.
- le point intéressant est le support (en test) du Multi-langage pour l'interface Web ... avec en premier le Français en plus de L'Anglais (par défaut si un texte n'est pas traduit)
- par sécurité vous pouvez aussi invalider l'interface Web et changer le nom d’utilisateur et la mot de passe pour y accéder.
lien original : https://forum.asustor.com/viewtopic.php?f=42&t=10171&start=30#p32840
[EDIT] mise à jour faite ... pas de problème ... a vérifier
Fred.
Hi,
I am please to propose a small update to myHD 0.9.2 before providing more applications
[Version]
0.9.2 R.C.2
... solve some bugs
... ADD Enable or Disable WebUI (for security) ... using myHD command you can do this.
... ADD (first draft) MULTI LANGUAGE support for WebUI (provide en and fr) BUT easy to add your own language or change existing (and send it to me for integration)
... ... language are folder in /share/Web/myHD/text/LANG and text file are with mandatory name (for each cgi) and suffixed by .data
... ... due to NON caching of web page you can test immediately change and do partial translation (English is loaded first) so missing text back to English
... ... save your works, at this time it's not preserved by future update
... ADD change password for WebUI or add your own credentials (one or multiple) and remove it (include myhd user) new credentials are preserved in future update
... This update as usual preserve the Ubuntu environment and settings ...
Download is in first post of this topics.
Philippe.
Fred.
