Asustor VirtualBox- satisfaisez tous vos besoins en terme de machines virtuelles -appli développée et maintenue par VirtualBox
Alors le paramètre dans accès facile était pas fait
donc je l'ai fait
et oui j'utilise phpvirtualbox et l'option contrôle a distance dans les paramètre était activer
même après avoir activer accès facile cela ne fonctionne toujours pas
voila ce qui est marquer dans le détail
Exception Object
[message:protected] => Failed to launch Remote Desktop Extension server (Unknown Status -2147467259 (0x80004005))
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /volume1/Web/virtualbox/lib/vboxconnector.php
[line:protected] => 2405
[trace:Exception:private] => Array
[0] => Array
[file] => /volume1/Web/virtualbox/lib/vboxconnector.php
[line] => 938
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => 6f074782576f2803-000000000000159d
[_persist] => Array
[vboxHandle] => 6f074782576f2803-000000000000159b
[fn] => progressGet
[1] => Array
[file] => /volume1/Web/virtualbox/lib/ajax.php
[line] => 304
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Starting virtual machine
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 16903
[hours] => 19
[minutes] => 16
[seconds] => 28
[percent] => 20
[success] => 1
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
[2] => Array
[line] => 304
[function] => progressGet
[type] => ->
[args] => Array
[0] => Array
[_persist] => Array
[fn] => progressGet
[1] => Array
[0] => Array
[data] => Array
[info] => Array
[completed] => 1
[canceled] =>
[days] => 16903
[hours] => 19
[minutes] => 16
[seconds] => 28
[percent] => 20
[success] => 1
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
oui effectivement j'avais optware ipkg installer et que j'ai supprimer
mais même après cela sa na pas fonctionner
bizarrement j'ai tous effacer mis la bêta de ADM installer les application beta etc....
et quand j'ai recrée une machine virtuel ce coup si j'ai pas choisis Windows 7 64bits mais Windows 10 64 bits et cela fonctionne
je vais pas chercher a comprendre :D
seul problème qui m’embête c'est que j'avais installer dans le rack 4 un disque dur exprès pour faire la virtualisation
est une autre question peu être hors sujet mais toutes les application installer peut ton choisir dans que disque dur il s’installe?
En tous cas merci de ton aide :D
koxx13 a dit:
il suffisait de désactiver entware ou dans ton cas optware ipkg (je te déconseille optware ipkg que nous allons virer d'App Central. je te conseille le plus récent - et maintenu - entware - cf sur ce forum dans applications tierces) et redémarrer le NAS . Si ça ne fonctionnait toujours pas désactiver/réactiver Virtualbox et le tour est joué.
"et quand j'ai recrée une machine virtuel ce coup si j'ai pas choisis Windows 7 64bits mais Windows 10 64 bits et cela fonctionne"
=> peux-tu reformuler?
"est une autre question peu être hors sujet mais toutes les application installer peut ton choisir dans que disque dur il s’installe?"
=> idem peux-tu reformuler? tu écris en langage sms et j'ai du mal...
quand tu crée un nouvelle machine avec virtualbox il te demande quel type de système d'exploitation tu va installer dessus (Linux Windows etc..)
je sélectionner tous le temps Windows 7 64 bits mais pour essayer j'ai sélectionner Windows 10 64 bits
Quand on installe un application sur app central, il installe automatiquement sur le Volume 1 (disque dur dans le premier rack)
mais moi j'aimerais savoir si il est possible d'installer les application de l'app central sur un autre volume (disque dur 4 par exemple)
J'ai toujours mon problème ! Je n'arrive pas à utiliser Virtualbox j'ai ce message:
Quelqu'un peut m'aider svp? Je tourne en rond malheureusement...
Exception Object
    [message:protected] => The virtual machine 'Debian 8' has terminated unexpectedly during startup with exit code 1 (0x1)
            [0] => Array
                    [line] => 938
                    [type] => ->
                    [args] => Array
                            [0] => Array
                                    [progress] => a9da8d4fb36f4da0-0000000000000040
                                    [_persist] => Array
                                            [vboxHandle] => a9da8d4fb36f4da0-000000000000003e
                                    [fn] => progressGet
            [1] => Array
                    [line] => 304
                    [type] => ->
                    [args] => Array
                            [0] => progressGet
                            [1] => Array
                                    [0] => Array
                                            [_persist] => Array
                                            [fn] => progressGet
                                    [1] => Array
                                            [0] => Array
                                                    [data] => Array
        [info] => Array
        [completed] => 1
        [canceled] =>
        [operationDescription] => Creating process for virtual machine "Debian 8" (headless)
        [days] => 16952
        [hours] => 18
        [minutes] => 3
        [seconds] => 20
        [percent] => 0
                                                            [success] => 1
                                                    [errors] => Array
                                                    [persist] => Array
                                                    [messages] => Array
            [2] => Array
                    [line] => 304
                    [type] => ->
                    [args] => Array
                            [0] => Array
                                    [_persist] => Array
                                    [fn] => progressGet
                            [1] => Array
                                    [0] => Array
                                            [data] => Array
                                                            [info] => Array
        [completed] => 1
        [canceled] =>
        [days] => 16952
        [hours] => 18
        [minutes] => 3
        [seconds] => 20
        [percent] => 0
                                                    [success] => 1
                                            [errors] => Array
                                            [persist] => Array
                                            [messages] => Array
Merci d'avance
bonjour,
qu'en est il des performances de virtualbox sur un AS6202T (par rapport a un qnap equivalent) ? il y a l'acceleration directx de l'affichage ? en gros si on met un windows on peut jouer avec (a des petits jeux/emulateurs) ?
Peut on assigner les ports usb arrieres a chaque machine virtuelle ?
merci
il y a un truc que je ne comprend pas avec vmware sur ADM Asustor.
Sujet A :
_ clique sur l'icone vmware dans ADM => ouverrture d'un nouvel onglet dans le navigateur avec la console vmware d'administration = OK
_ lancement de VM (Microsoft : XP, seven) ou Linux (Fedora dernière version) : OK
.... enfin, ok, c'est vite dit, car après rien...
=> dois je faire un remote access sur les windows et un ssh sur les linux via putty pour prendre la main ?
ou bien NON : la vm aurait du s'ouvrir dans un nouvel onglet du navigateur internet ?
Sujet B :
Comment rendre ces VM accessible sur le WAN ?
Merci d'avance.
Sujet B : comment accèder aux VMs en WAN :
en terme plus techniques :
Quels sont les ports à ouvrir pour accéder aux VMs depuis le net ?
je lis depuis une brève recherche internet : Remote Desktop requires TCP port 3389 to be open.
ok mais si j'ouvre ce port sur mon NAS, ca ne me dit pas comment accèder à la VM ?
il faudrait que le port route la requête vers la VM mais là je ne vois pas comment.
bon j'ai pu faire une promenade dans le grand monde et testé à cette occasion le WAN pour VirtualBox.
Tout marche sans ouvrir de port via l'adm etc ...; mais 2 points noirs :
j'ai l'impression que c'est du http et non pas du https.
l'onglet virtualbox du navigateur requiert Adobe Flash Player donc pour une visualisation des console dans Android, c'est mort.
Et sur le PC de ma société qui refuse l'installation de soft, c'est mort aussi.
HTML5 devrait permettre de résoudre tout cela non ? Mais dans l'espace, personne ne m'entendra crier, je pense.
JacquesNAS a dit:
Flash Player? peux-tu préciser à quelle fin? je n'ai pas Flash Player et j'utilise VB sans encombre.
VB est développé par Oracle et non pas nous https://www.virtualbox.org/. Dis moi ce qui coince
dsm installer VirtualBox avec nas synology dans asustor peut être installé que quelqu'un a fait et testé grâce
Dami1 a dit:
JacquesNAS a dit:
Il parle de du bouton "console" qui permet d'accéder au CLI/GUI de la VM. Sans Flash, pas possible... Mais IE ou FF fonctionne très bien avec Flash.
mikelpatriot a dit:
merci de veiller à ton écriture, c'est aussi difficile à comprendre que le SMS d'un ADO ;)
Bonjour tous le monde!
Le sujet de Flash player + phpvirtualbox m'intéresse aussi :
Romz a dit:
Dami1 a dit:
JacquesNAS a dit:
Car je suis dans le même cas que JacquesNAS:
Mon portable du boulot bloque toute installation d'application avec un compte admin. Or des fois il serait bien d'avoir accès à certains softs.
Lorsque je me connecte sur ADM et phpvisturalbox, je démarre ma VM et dans l'onglet console j'ai le message suivant: "The Adobe Flash plugin is not installed."
J'ai essayé avec tous les navigateurs rien à faire. Je ne vois pas d'où peut venir le problème :!:
Quelqu'un à une idée ?
