QNAP [ TDarr ] [ 0.109 - Beta ] Audio/Video library analytics + transcode automation wth FFmpeg/HandBrake
QoolBox
Représentant QNAP
2 Janvier 2014
10 800
191
173
52
www.qnap.com
Oui
68747470733a2f2f73372e67696679752e636f6d2f696d616765732f47696643726f707065645472616e2e676966
source: https://github.com/HaveAGitGat/Tdarr
Download
https://www.qnapclub.eu/fr/qpkg/1013
Dependencies : HandBrake-CLI
Tdarr is a self hosted web-app for automating media library transcode/remux management and making sure your files are exactly how you need them to be in terms of codecs/streams/containers etc. Designed to work alongside Sonarr/Radarr and built with the aim of modularisation, parallelisation and scalability, each library you add has its own transcode settings, filters and schedule. Workers can be fired up and closed down as necessary, and are split into 3 types - 'general', 'transcode' and 'health check'. Worker limits can be managed by the scheduler as well as manually. For a desktop application with similar functionality please see HBBatchBeast.
Use/create Tdarr Plugins for infinite control on how your files are processed: https://github.com/HaveAGitGat/Tdarr_Plugins
Audio and video library management
7 day, 24 hour scheduler
Folder watcher
Worker stall detector
Load balancing between libraries/drives
Use HandBrake or FFmpeg
Tested on a 180,000 file dummy library with 60 workers
Search for files based on hundreds of properties
Expanding stats page
Hardware transcoding container (install Nvidia plugin on unRAID/Nvidia runtime container on Ubuntu)
68747470733a2f2f692e696d6775722e636f6d2f3876456d4937642e706e67
Bravo. Excellent soft et merci pour ce pkg.
tu utilise quel version de ffmpeg du coup ?
