QNAP [ Snipe IT ] [ 5.1.5 ] open source IT asset/license management system
QoolBox
Représentant QNAP
2 Janvier 2014
10 635
182
158
51
www.qnap.com
Source : https://snipeitapp.com
Download : arm64, armv7, amd64
Apache73 Version : https://www.qnapclub.eu/fr/qpkg/918
Apache74 Version : https://www.qnapclub.eu/fr/qpkg/919
QPKG Integration
before play with this qpkg you need to setup a DB, and setup correctly /opt/SnipeIT7x/snipe/.env for db connection
About :
General Features
Mobile-friendly for asset updates on the go
Runs on any Linux, Windows or Mac web server
Web-based software so it works on any device
Slack notification integration for checkin/checkout
Tons of security features to keep your data safe
Includes a robust JSON REST API
Translated into several languages for easy localization
Per-user language support for distributed teams
One-click (or cron) backups
LDAP login/user sync
v5.1.5
⚠️ IMPORTANT: 5.2.x versions of Snipe-IT will require PHP 7.4 or greater.
(This is a requirement in order for us to be able to pull forward the dependencies that will allow us to support PHP8 and beyond moving forward.)
This is largely a bug fix release that tries to catch us up on older PRs. (We started v5.1.4 with over 60 PRs, we now have about 9.) There are some minor docker fixes here, some UI improvements, and some LDAP improvements.
New in v5.1.5
Enable use of custom file based SAML certificate/private key
Updated languages
Set docker user as owner of key symbolic links (#7924)
Fixed typo that doesn't accept textarea as custom field type element
Fixed label name for field_values in custom fields edit
Increases DPI of barcode for small lables (#9344)
Extended #6229 to include superuser permission check (#6772)
Fix Ubuntu Vagrant Development VMs (#6909)
Use environmental variables in memory limits
Improvement for auditing feature on mobile [ch14328] (#9181)
Fixed #9404 - include note in accessory API
Removed depreciated Input:: facade
Fixed an issue with CSS when the 'skin' value in settings table is empty
Fixed logic to handle when a cloned user is imported via LDAP. (#9429)
Fixed Sum of purchase cost of components not taking quantity into account in Asset View > Components tab
Updated snipeit.sh php version from 7.1 to 7.4 (#9407)
Fixed #9372 - Error getting users from LDAP directory, error: ldap_search(): Search: Can't contact LDAP server
Handle regex format for custom fields when assigned from API (#9443)
Fixed #9447 change route parameter name in locations view (#9456)
Fix for css when running Snipe-IT in subdirectory (#9445)
(Maybe?) Fixes the problem where we always need the php-ldap extension enabled (implements deferred service provider) (#9321)
Changed “Asset Categories” to “Categories” since there are more than asset categories now
Fixed #9424: import history adds asset model to assigned user and respects checkin date (#9350)
Fixed ldap ad authentication filter query mechanism (#7441)
Fixed the controller signature error people are getting with LDAP logins (#9466)
Restore LOG_CHANNEL environment variable regression. (#9464)
Added
Added sanity check to determine if a bind user account is set. (#9340)
Added a way for a user to override the site skin setting
Added #6695: add API endpoint for license seats (#8058)
Added created_at and updated_at to Asset Model presenter
Added additional LDAP fields to sync (#9318) - resolves #7211, #9197, #7864, [ch15504]
Added support for Debian 10 (#7414)
Added #5977: permission to view files attached to licenses (#9264)
Added option to force TLS connection (#9327)
Added ID columns to tables that don’t have them - reproduces #9363
Added check for valid category name on user's view-assets page
Added #9355: include Accessories and Consumables on the location reports
Added show() redirect for CustomFields::show() - this is mostly to prevent junking up Rollbar when people are experimenting
Added help text to custom fields headline
Added #9313: Add new fpm-alpine docker image and docker secrets support
Added a docker-compose with helper services (#9105)
Added clearer reporting on import when the mime type is incorrect
Improved UI for importer
Adding text/x-Algol68 to import because WTF
Added user locale to REST API GET /api/users response; (#9486)
For a full list of changes, see the complete changelog.
