Source : https://github.com/SillyTavern/SillyTavern
Download :
Apache84 https://www.myqnap.org/product/sillytavern-apache84/
Apache83 https://www.myqnap.org/product/sillytavern-apache83/
Mobile-friendly, Multi-API (KoboldAI/CPP, Horde, NovelAI, Ooba, OpenAI+proxies, Poe, WindowAI(Claude!)), VN-like Waifu Mode, Horde SD, System TTS, WorldInfo (lorebooks), customizable UI, auto-translate, and more prompt options than you'd ever want or need. Optional Extras server for more SD/TTS options + ChromaDB/Summarize.
What is SillyTavern or TavernAI?
SillyTavern is a user interface you can install on your computer (and Android phones) that allows you to interact with text generation AIs and chat/roleplay with characters you or the community create.
SillyTavern is a fork of TavernAI 1.2.8 which is under more active development and has added many major features. At this point, they can be thought of as completely independent programs.
--- QPKG info ---
credential default : user/password
modify config file according your need : /opt/SilyTavern84/silytavern/config.yaml
(be sure to back up your config file once modify, on upgrade QPKG it will remain to default)
