QNAP QTS 4.5.4.1723 build 20210708
schwinny
6 Janvier 2018
357
142
98
Important Notes
For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
To learn more about NAS models that support the TL-D800C, TL-R1200C-RP, TL-D400S, TL-D800S, TL-D1600S, TL-R400S, TL-R1200S-RP, see the Compatibility List at https://www.qnap.com/en/compatibility-expansion
We have fixed the vulnerabilities in the following apps to ensure your data security: Qsync Central and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
For more information on the kernel versions for NAS models that QTS 4.5.4 supports, see https://www.qnap.com/en/release-note/kernel
Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: phpEasyProject, Dolphin, CMS Made Simple, Vtiger CRM, iStat, and ownCloud.
Due to compatibility issues, the following applications have been removed from the App Center in QTS 4.4.1: FileFlex, MantisBT, SugarCRM, Xeams, DokuWiki, and Azure Storage.
Once you update QTS to 4.4.1 (or later) on the TS-1635AX, you will not be able to downgrade QTS to versions earlier than 4.4.1.
Removed support for Plex Home Theater from HybridDesk Station.
After reaching their end of support in July 2020, Notes Station and Qnotes have been removed from QTS App Center, Google Play, and Apple App Store. We recommend using Notes Station 3 and Qnotes 3 to benefit from the next-generation note-taking features. For details on how to transfer your notes from Notes Station 2 to Notes Station 3, see the following tutorial: https://www.qnap.com/en/how-to/tutorial/article/importing-notes-from-notes-station-2-to-notes-station-3
Removed HappyGet from the App Center due to changes in Google extension policies.
Starting from 4.5.1, QTS is no longer compatible with the following applications: DJ2 Console, CodexPack.
QTS 4.5.4 does not support earlier versions of QVR Client. After updating QTS to 4.5.4 (or later), Surveillance Station users can download and install the latest version of QVR Client from the QNAP website: https://www.qnap.com/en/utilities/surveillance
Fixed Issues
QTS would erroneously detect and display false overheating on the TX-800P storage expansion enclosure, causing unexpected system shutdown.
File Station could not correctly sort folder names when the system language was set to Russian or Simplified Chinese.
SNMP OID (Object Identifier) values were inconsistent with their description.
Available disk space for the file system would sometimes keep decreasing.
ARM NAS models could not display the QR code for authentication for when users enabled 2-step verification.
Known Issues
Browser Station sometimes may stop responding when users add an SMTP service in Notification Center and choose to perform account authentication via Browser Station.
Release Note URL: https://www.qnap.com/en/release-notes/qts/4.5.4.1723/20210708
Téléchargement du firmware "QTS 4.5.4.1723 Build 20210708": https://www.qnap.com/fr-fr/download
Guide de l’utilisateur de QTS 4.5.x : https://docs.qnap.com/operating-system/qts/4.5.x/fr-fr/
