QNAP QTS 4.5.4.1715 build 20210630
schwinny
6 Janvier 2018
358
143
108
[Important Notes]
- To learn more about NAS models that support the TL-D800C, TL-R1200C-RP, TL-D400S, TL-D800S, TL-D1600S, TL-R400S, TL-R1200S-RP, see the Compatibility List at https://www.qnap.com/en/compatibility-expansion
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.5.4 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: phpEasyProject, Dolphin, CMS Made Simple, Vtiger CRM, iStat, and ownCloud.
- Due to compatibility issues, the following applications have been removed from the App Center in QTS 4.4.1: FileFlex, MantisBT, SugarCRM, Xeams, DokuWiki, and Azure Storage.
- Once you update QTS to 4.4.1 (or later) on the TS-1635AX, you will not be able to downgrade QTS to versions earlier than 4.4.1.
- Removed support for Plex Home Theater from HybridDesk Station.
- After reaching their end of support in July 2020, Notes Station and Qnotes have been removed from QTS App Center, Google Play, and Apple App Store. We recommend using Notes Station 3 and Qnotes 3 to benefit from the next-generation note-taking features. For details on how to transfer your notes from Notes Station 2 to Notes Station 3, see the following tutorial: https://www.qnap.com/en/how-to/tutorial/article/importing-notes-from-notes-station-2-to-notes-station-3
- Removed HappyGet from the App Center due to changes in Google extension policies.
- Starting from 4.5.1, QTS is no longer compatible with the following applications: DJ2 Console, CodexPack.
- QTS 4.5.4 does not support earlier versions of QVR Client. After updating QTS to 4.5.4 (or later), Surveillance Station users can download and install the latest version of QVR Client from the QNAP website: https://www.qnap.com/en/utilities/surveillance
[Security Updates]
- Fixed some security issues.
[New Features]
Control Panel
- Users can now import custom root certificates to certify the SSL certificate of a server that the NAS needs to access.
File Station
- File Station now supports displaying thumbnail previews for PDF files.
Network & Virtual Switch
- Network & Virtual Switch now supports the DDNS service "DDNS Now".
[Enhancements]
Control Panel
- Users can now manually specify the time interval and the maximum number of failed login attempts in Control Panel to further enhance NAS security.
- QTS now enables the default "admin" account and resets its password when users press the Reset button on the NAS for three seconds. Nevertheless, to ensure device security, we recommend disabling the "admin" account and using a new administrator account after you finish resetting the system.
- Added support for Content Security Policy HTTP header.
- To enhance device security, UPnP Discovery Service is now disabled by default.
- Added an option to choose whether to redirect users to the NAS login screen when connecting to the NAS IP address without the system port. To enhance device security, this option is disabled by default.
QuLog Center
- Improved the user interface of Advanced Search in QuLog Center.
- Added support for displaying the total connection time of online users.
- QuLog Center now displays computer names and accessed resources in System Access Log and Online Users.
Security
- To ensure device security, QTS now displays a message to remind users to disable the default "admin" account and to create another administrator account.
- QTS now displays a message to remind users to enable 2-step verification to ensure account security.
- Modified the network connection behaviors of containers to enhance system security.
Storage & Snapshot
- To enhance data availability, Storage & Snapshots now always reserves one snapshot from each time interval when Smart Snapshot Space Management and Smart Versioning are both enabled even when available space is less than 32 GB.
- All users in the administrator group can now use and manage VJBOD.
- All users in the administrator group can now use and manage Snapshot Replica.
[Fixed Issues]
- File Station could not correctly sort folder names when the system language was set to Russian or Japanese.
- When users downloaded files via a shared link, QuLog Center would not record the event.
- Users could not start the TS-x32PX or the TS-x32PXU series via Wake-on-LAN (WOL) after updating the firmware to QTS 4.5.3.1652.
- Non-administrator users with read/write permissions could delete snapshots from the @Recently-Snapshot shared folder in File Station.
- Snapshot Manager could not restore the snapshots of shared folders whose names contained the # character.
- QTS could not correctly display the CPU temperature when Emulex 10GbE network adapter was installed.
[Known Issues]
- Browser Station sometimes may stop responding when users add an SMTP service in Notification Center and choose to perform account authentication via Browser Station.
- QUSBCam2 cannot display the live view of a camera when video coding format is set to H.264.
[Other Changes]
App Center
- To enhance device security, App Center now checks for available updates every day and automatically installs required updates by default.
- To ensure system security, QTS now automatically disables applications that are not updated and that do not meet the minimum version requirements.
