QNAP QTS 4.4.3.1354 build 20200702
QoolBox
Représentant QNAP
2 Janvier 2014
10 693
182
158
51
www.qnap.com
[Important Notes]
- To learn more about NAS models that support the TL-D800C, TL-R1200C-RP, TL-D400S, TL-D800S, TL-D1600S, TL-R400S, TL-R1200S-RP, see the Compatibility List at https://www.qnap.com/en/compatibility-expansion
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.4.3 supports, see https://www.qnap.com/en/release-note/kernel
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: "phpEasyProject", "Dolphin", "CMS Made Simple", "Vtiger CRM", "iStat", "PostgreSQL 9.3.13.3", and "ownCloud".
- Due to compatibility issues, the following applications have been removed from the App Center in QTS 4.4.1: FileFlex, MantisBT, SugarCRM, Xeams, DokuWiki, and Azure Storage.
- Once you update QTS to 4.4.1 (or later) on the TS-1635AX, you will not be able to downgrade QTS to versions earlier than 4.4.1.
- Removed support for Plex Home Theater from HybridDesk Station.
[New Features]
QTS
- Added support for the QNAP QXP-W6-AX200 (Intel Wi-Fi 6 AX200) PCIe wireless network interface card. For details on the supported NAS models, check the compatibility list: https://www.qnap.com/go/compatibility/
[Enhancements]
QTS
- To enhance NAS security, Malware Remover is now automatically installed for QTS.
- Users can now send usage data from Notification Center to QNAP to help optimize product design and enhance user experience.
- Redesigned the user interface of Qsync Central to enhance user experience.
[Fixed Issues]
- The NAS would play an audio alert during RAID scrubbing even though there were no warnings or errors.
- Users could not power off the NAS with the IR remote control (IR-004) after updating QTS to 4.4.2.1270.
- The completion time of snapshot replication jobs displayed in Snapshot Replica would not be consistent with the time in Snapshot Vault.
- Administrators could not add users to the allowed list in myQNAPcloud Access Control.
- Users could not recover file-based iSCSI LUNs after reinserting an encrypted volume and then unlocking the volume.
- Network & Virtual Switch would display incorrect LAN protocols (IEEE 802.11) when 2.4 GHz Wi-Fi and 5 GHz Wi-Fi had the same SSID.
https://download.qnap.com/Storage/HS-251/HS-251_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/Mustang-200/Mustang-200_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/QB-103/QB-103_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/QGD-1600/QGD-1600_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+_X31K/TS-131P_231P_431P_X31+_X31K_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X31P2_X31P3/TS-X31P2_X31P3_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X51DU/TS-X51DU_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X53D/TS-X53D_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X72/TS-X72_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X72U/TS-X72U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X73AU/TS-X73AU_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X77U/TS-X77U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X83XU/TS-X83XU_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X88/TS-X88_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X88U/TS-X88U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20200702-4.4.3.1354.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20200702-4.4.3.1354.zip
