QNAP QTS 4.2.0 Build 1118
QoolBox
Représentant QNAP
2 Janvier 2014
10 793
191
173
52
www.qnap.com
Oui
[Change]
Due to the lack of compatibility with DVB-T TV dongles, the Digital TV Station app will be removed from the QTS 4.2 App Center in certain regions. If compatibility improves, then the app will be reinstated.
[Bug Fixes]
- Fixed an issue where the NAS could not enter hibernation mode if a network cable is unplugged.
- Fixed an issue where the NAS would display "The File system is not clean." in the system logs after setting up a scheduled shut down.
- Fixed an issue where the NAS could not enter standby mode is a network cable is unplugged.
- Fixed an issue where NAS drives could not enter standby mode if you change the time setting from "Synchronize with ...." to "Manual setting" in the Control Panel.
- Fixed an issue where the NAS would fail to create scheduled snapshots when using Snapshot Agent Manager.
- Fixed an issue where if the NAS reboots while a RAID is resyncing (RAID6), the RAID will be inactive after the reboot.
- Fixed an issue where File Station fails to copy files larger than 30MB from a local device to OneDrive.
- Fixed an issue where Download Station can still download files with an incorrect proxy setting.
- Fixed an issue where RAID groups would become "inactive" after rebooting the NAS when the QNAP signature on the disks is missing.
- Fixed an issue where the TVS-871T would keep trying to recover from an error if it is connected to 2 Thunderbolt devices at the same time.
- Fixed an issue where the TVS-871T could not establish a Thunderbolt link with a Mac via Thunderbolt cable.
- Fixed an issue where the TVS-871T may not produce a Thunderbolt IP after updating to a new firmware.
- Fixed an issue where a TS-871T will fail to reconnect over Thunderbolt after the NAS wakes up from hibernation mode.
- Fixed an issue where a 10GbE NIC will be disconnected after the NAS goes into hibernation mode.
- Fixed an issue where it will fail to open the Credential Manager on Windows 8.1 when the Domain Controller is enabled on the NAS.
- Fixed an issue where the Next button of "iSCSI Target Only" is disabled while a thin volume is created and its status is "Ready".
- Fixed an issue where the NAS is unable to backup files with the one-touch button when a Sony SBAC-UT100 card reader is in EXT4 or EXT3.
Suite à une coupure de courant alors que le TS853Pro était en veille, le système de fichier est annoncé comme non sain à chaque remise sous tension malgré plusieurs vérifications et extinctions ou mises en veille propres.
Bug de cette version de QTS ou bien problème réel, et dans ce cas, comment le résoudre ?
:mrgreen: Ah la vache !
Tous les soirs mon NAS s'éteint et se rallume le matin. J'avais systématiquement chaque matin un message "Système de fichier défectueux...bla bla..."
J'ai tout essayé....sauf d'imaginer que c'était un bug :twisted:
A chaque reboot désormais j'ai droit à un message qui me demande de faire une vérification du raid :(
Autre bug ? Sous filestation, l'indicateur de progression de copie du NAS vers CIFS ne fonctionne pas correctement avec de gros fichiers. Cela semble ok sur le premier gros fichier copié mais l'indicateur de progression ne semble plus être mis à jour régulièrement après ça.
Chris26p a dit:
bug non référencé ca il me semble
ouvre un ticket
malgré cloudlink desactivé, rebelotte, ce matin au boot, il me redemande un check du filesystem :(
