QNAP QTS 4.2.0 build 0902 RC1
QoolBox
Représentant QNAP
2 Janvier 2014
10 748
185
173
51
www.qnap.com
Oui
arrivé imminente de la RC1 de QTS 4.2
Changelog :
QTS4.2.0 Build 0902
[Bug Fixes]
- Fixed Change Password vulnerability.
- Fixed Apple Networking vulnerability.
- Fixed multiple OpenSSH vulnerabilities (CVE-2015-5600 and other three).
- Fixed WebDAV vulnerability.
- If MySQL fails, the connection of the Qsync Client will act abnormally.
- Pools/volumes created in QTS 4.2.0 will be invalidated if you downgrade to a previous firmware.
- If a WLAN is set as the gateway on a TS-x12 series model, restarting the NAS will cause the gateway to change to LAN1
- The TS-269H cannot connect to Sony SRS-X2 Bluetooth speakers.
- Some MP3s are not audible when playing on Music Station.
- If you check then uncheck the SMB Encryption option in shared folders, the option will still be checked.
- After installing HD Station then rebooting the NAS, encrypted volumes will be stuck in a "Loading" state.
- The NAS will be unstable when enabling the domain controller and changing Windows ACL permissions.
- System Connection logs will be incorrect for opening shared links and downloading files from shared links.
- After reverting to a snapshot using SnapAgent, the Esxi datastore will be empty.
- After NetBak finishes backing up, the VSS should be deleted by the system in SnapAgent.
- TS-x31+ series models fail to download files after downloading torrent files.
- When streaming media files to the DLNA player, if you drag the progress bar in Media Viewer the NAS will exit the play function.
- When accessing QTS using an iPhone 6, the login page will not remember users' log in details.
- Normal users can find QPKGs via search.
- Fails to show personal photos after changing the image.
- HD Station will fail to be installed if Container Station is installed and activated before updating it.
- The connection to a cloud drive via samba in File Station will cause the NAS to freeze if you click on a drive that has over 120 subfolders.
- An error message will be displayed if you remove a connection to Amazon in File Station and then attempt to connect to it again.
- A connection cannot be created if you log in to File Station with a manually-entered IP address.
- Downloading the key file in Encryption Folder will display an Internal Server Error.
- Fails to connect to Box in File Station.
- The [Expand Capacity] button does not work when clicked on.
- When importing users from DC, the password preview will show an incorrect password if it has characters after the "<".
- After expanding capacity, the pool information will still say it's full on the dashboard.
- Moving folder A in Multimedia to a Public folder in File Station will take an excessive amount of time.
- Backup jobs cannot be created with the same name as deleted jobs.
- Checking the file system will result in errors after Gmail Backup is installed.
- User-customized databases will be unable to upgrade to the correct version after you upgrade from 4.1.4 to 4.2.0.
- The Play option is missing when right clicking on media files found by the search function.
Complément sur l'aide ...
il serait souhaitable d'ajouter un peu d'aide sur le mod de connexion en HTTPS (parce-que c'est bien plus meilleur mieux..)
à bientôt
QTS 4.2 Release Candidate 1 is now available for download
Taipei, Taiwan, August 23, 2015 – Thanks to many participants’ valuable feedback and suggestions for QTS 4.2 Beta program, QNAP have completed several enhancements for its latest NAS operating system and today announced QTS 4.2 Release Candidate 1 is now available for download.
QNAP sincerely invite users to install QTS 4.2 Release Candidate 1 to experience the evolution of QTS and extend the possibilities of QNAP NAS. Users can also activate the live update function to receive any new firmware update notification by installing QTS 4.2 Release Candidate 1.
To download QTS 4.2 Release Candidate 1, please visit
http://www.qnap.com/event/qts-4.2/public-beta/en/
For more information about QTS 4.2 Release Candidate 1 Release Note, please visit https://www.qnap.com/qts/4.2-beta-release-note/en/
Availability & Compatibility
QTS 4.2 Beta 2 is now available for the following QNAP NAS models:
24-bay: SS-EC2479U-SAS-RP, TS-EC2480U-RP, TVS-EC2480U-SAS-RP
18-bay: SS-EC1879U-SAS-RP
16-bay: TVS-EC1680U-SAS-RP, TS-EC1680U-RP, TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP
12-bay: SS-EC1279U-SAS-RP, TVS-EC1280U-SAS-RP, TVS-1271U-RP, TS-EC1280U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1270U-RP,TS-1269U-RP, TS-1253U-RP, TS-1253U
10-bay: TS-1079 Pro, TVS-EC1080+, TVS-EC1080, TS-EC1080 Pro
8-bay: TVS-EC880, TVS-871U-RP, TVS-871, TVS-870, TVS-863+, TVS-863, TS-EC880U-RP, TS-EC880 Pro, TS-EC879U-RP, TS-879U-RP, TS-879 Pro, TS-870U-RP, TS-870 Pro, TS-870, TS-869U-RP, TS-869L, TS-869 Pro, TS-859U-RP+, TS-859U-RP, TS-859 Pro+, TS-859 Pro, TS-853U-RP, TS-853U, TS-853S Pro, TS-853 Pro, TS-851, SS-839 Pro
6-bay: TVS-671, TVS-670, TVS-663, TS-670 Pro, TS-670, TS-669L, TS-669 Pro, TS-659 Pro+, TS-659 Pro II, TS-659 Pro, TS-653 Pro, TS-651, TS-639 Pro
5-bay: TS-569L, TS-569 Pro, TS-563, TS-559 Pro+, TS-559 Pro II, TS-559 Pro
4-bay: TVS-471U-RP, TVS-471U, TVS-471, TVS-470, TVS-463, TS-470U-SP, TS-470U-RP, TS-470 Pro, TS-470, TS-469U-SP, TS-469U-RP, TS-469L, TS-469 Pro, TS-459U-RP+/SP+, TS-459U-RP/SP, TS-459 Pro+, TS-459 Pro II, TS-459 Pro, TS-453U-RP, TS-453U, TS-453S Pro, TS-453mini, TS-453 Pro, TS-451U, TS-451S, TS-451, TS-439U-RP/SP, TS-439 Pro II+, TS-439 Pro II, TS-439 Pro, TS-431U, TS-431+, TS-431, TS-421U, TS-421, TS-420U, TS-420-D, TS-420, TS-419U+, TS-419U II, TS-419U, TS-419P+, TS-419P II, TS-419P, TS-412U, TS-412, TS-410U, TS-410, SS-439 Pro, IS-400 Pro
2-bay: TS-269L, TS-269H, TS-269 Pro, TS-259 Pro+, TS-259 Pro, TS-253 Pro, TS-251C, TS-251, TS-239H, TS-239 Pro II+, TS-239 Pro II, TS-239 Pro, TS-231+, TS-231, TS-221, TS-220, TS-219P+, TS-219P II, TS-219P, TS-219, TS-212P, TS-212-E, TS-212, TS-210, HS-251, HS-210
1-bay: TS-131, TS-121, TS-120, TS-119P+, TS-119P II, TS-119, TS-112P, TS-112, TS-110
For more information about QTS 4.2, please visit https://www.qnap.com/qts/4.2.
bonjour,
Petit stress à la fin de MAJ : "La mise à jour a échoué" :shock: ...
Et puis non : redémarrage en Built 0902....tout à l'air bien et beau 8-)
tout à l'air de bien fonctionner, j'ai même l'impression que le système est un poil plus rapide.
sinon le bug que j'avais sous cloudlink a disparu, j'ai pu enregistrer le petit dernier proprement :)
mise a jour effectuée sans problèmes d'installation pour mon ts-231 :)
1) j'ai activée la protection https , et j'ai une page comme cela :
2)protection ssl non activée il faut payé pour 2ans et un mois (il faut le faire ?)
est ce que ma question 2 a un rapport avec le https de Qfinder question 1
merci de votre gentillesse
papa
papa50 a dit:
papa
tu utilise un certificat auto signé par le NAS, si tu veux ne plus avoir ce message il faut un certificat créé par une autorité certifiante (achat de certificat) et les uploader sur le NAS
Qnap vend des certificats, pas cher (QTS 4.2) mais ils sont générés avec ton nom de domaine Qnap Cloud, donc utilisable qu'avec ton QID ;)
le QID tu l'as déjà, c'est ton nom.myqnapcloud.com
après le certificat est généré sur cette base, donc si tu change de domaine, c'est mort...
c'est toi qui vois si tu en a l'utilité ou pas, cela cryptera les connexions vers le domaine nom.myqnapcloud.com
