QNAP QTS 4.2.0 Build 0101
QoolBox
Représentant QNAP
2 Janvier 2014
10 795
191
173
52
www.qnap.com
Oui
mise à jour en cour d'upload
QTS4.2.0 Build 0101
[Bug Fixes]
 Fixed an issue where the NAS would not accept a domain group's name if it contains special characters.
- Fixed an issue where email notifications would be disabled when using 2-step verification if there is no username & password set in the SMTP server.
- Fixed an issue where testing a RTRR job would fail when creating a job to backup files from local to remote via CIFS.
- Fixed an issue where the profile folder would have two IDs with the access right of 3000001 after the domain users setup profiles.
- Fixed an issue where after detaching a JBOD, its image in Storage Manager will remain in chassis view.
- Fixed an issue where after installing CloudLink and rebooting the NAS, the System Event Logs will display a "..file system is not clean.." message.
- Fixed an issue where the progress would be stuck at "0" when relaunching Storage Manager and entering "Storage Space" page when using Internet Explorer 11.
- Fixed an issue where after enabling advanced folder permissions in the Control Panel, File Station would show an error message in the right-panel Permission tab.
- Fixed an issue where File Station would show an error message when sharing files with more than one person and sending an email link via the NAS.
- OpenSSL has been updated to 1.0.0t/ 1.0.1q
- Fixed an issue where the UI may freeze when selecting “Win/Mac/NFS” in “Control Panel” - “Network Services”.
- Fixed an issue where the  Expand Capacity button will be enabled before changing any drive in Storage Manager.
- Fixed an issue where an increasing amount of system RAM will be displayed while copying a large number of small files to the NAS.
- Fixed an issue where the unallocated size will change after taking snapshots, copying some files, then rebooting the NAS.
- Fixed an issue where the content of encrypted folders are not included in snapshots.
- Fixed an issue where the system will fail to create a snapshot replica job to a remote NAS when there is a special character ')' in the password.
- Fixed an issue where there is nothing shown in Background Tasks after Snapshot Replica is executed.
- Fixed an issue where the system log shows "The file system is not clean...." when rebooting with various apps launched and RTRR in process.
- Fixed an issue where the Media Library would occasionally show incomplete file information when changing the iTunes media folder to the NAS multimedia folder.
- Fixed an issue where the WebDAV connection would fail after the HTTPS port is changed to 443.
- Fixed an issue where the content page of songs would be cleared when uploading specific MP3 files.
- Fixed an issue where the AFP connection would be interrupted when connecting through an encrypted folder.
- Fixed an issue where files would be incompletely moved when repeatedly moving files between a shared folder and an external folder in File Station.
Z'êtes très festifs chez QNAP : Après la version du Réveillon de Noël, vl'a la version du jour de l'an :D
Blague à part, toutes ces corrections se retrouvent-elles dans la 4.2.1 actuelle 1224 ?
Si on est en train de tester la 4.2.1 cette mise à jour ne sert pas, n'est pas?
les correctif seront dans la prochaine 4.2.1 avec d'autres...
c'est que pour ceux qui sont en Stable...
la 4.2.1 Stable est normalement prévu pour fin Janvier
ils sont réactifs chez qnap !
Ca, ca va me plaire.
Ca me change de ve-hotech.....ou là c'était du .....0 réaction !
après une petite frayeur il est resté sur la page bleue de redémarrage pendant 15 mn
Qfinder n’était pas à jour :roll:
