QNAP QTS 4.1.3 build 0408
QoolBox
Représentant QNAP
2 Janvier 2014
10 630
181
158
51
www.qnap.com
Sortie imminente du firmware 4.1.3 build 0408
QTS4.1.3 build 0408
[Bug Fixes]
- Upgraded OpenSSL to 1.0.1m to address multiple vulnerabilities (CVE-2015-0204, CVE-2015-0209, CVE-2015-0286, CVE-2015-0287, CVE-2015-0288, CVE-2015-0289, CVE-2015-0292 and CVE-2015-0293).
- The system fails to detect the Netgear R7000 as a UPnP device.
- The system fails to detect the total volume size and free size in downgraded mode (shown as 0KB).
- Fails to establish a HTTPS connection to a NAS using a Mac via WebDAV.
- Fails to access subfolders on a NAS using NetDriver2 via WebDAV.
- Fails to modify user permissions (or hangs in NetDrive) on a NAS using NetDrive via WebDAV.
- It takes a prolonged time (over 1 minute) to establish a connection to a NAS using a Mac via WebDAV.
- The x53 series reboots after creating VMs using VMware tools with a block-based LUN thin provisioned datastore.
- The block-based LUN unexpectedly disconnects if the storage pool is running out of space.
- The system fans unexpectedly stop after the smart fan temperature unit is set to Fahrenheit.
- User permissions settings on external devices are automatically restored to default after the NAS reboots.
- The system automatically creates an empty folder titled "abc" during OTB backup if the name of a subfolder at the destination contains this combination: "abc+space+parent folder name".
- The "failed to update" message is incorrectly prompted when the firmware version installed on the hard drive is different from that used by the built-in flash.
- The system fails to back up data to the destination during Rsync backup if the name of a subfolder at the destination contains this combination: "abc+space+parent folder name".
- The NAS reboots after creating a 2048GB iSCSI LUN in VHD format using a Hyper-V server.
- The x31 series fails to launch File Station in Russian.
- Photo Station and Video Station fail to detect the VLC web plug-in (version 2.2.0) making them unable to play videos.
[Applicable Turbo NAS]
- All models
En live update à partir du 16 avril
