QNAP [ QClamAV ] [ 0.103.1 ] an open source antivirus engine for detecting trojans, viruses, malware
QoolBox
Représentant QNAP
2 Janvier 2014
10 800
191
173
52
www.qnap.com
Oui
Source : www.clamav.net
Download : arm-x41 - arm-x64 - x86_64
on QPKG Start
it automatically download latest virus database
and immediately start a scan on your user space "/share"
all infected file are moved automatically inside /opt/ClamAV/quarantine
logs files : /opt/ClamAV/log
config files : /opt/ClamAV/etc
database saved/update : /opt/ClamAV/DB
all binary : /opt/ClamAV/bin (not forced in $PATH, no interaction with the official Qnap it use different socket/PID)
including : freshclam / clamd / clamscan / clamsubmit / clamav-config / clambc / clamconf / clamdtop /clamonacc
if you want change command behavior on your need to modify the clamscan line inside : /opt/ClamAV/clamAV.sh
all has been cross compiled from source with all libs shared as dependencies
USAGE :
[~] # /opt/ClamAV/bin/clamscan --help
Clam AntiVirus: Scanner 0.103.1
By The ClamAV Team: https://www.clamav.net/about.html#credits
(C) 2021 Cisco Systems, Inc.
clamscan [options] [file/directory/-]
--help -h Show this help
--version -V Print version number
--verbose -v Be verbose
--archive-verbose -a Show filenames inside scanned archives
--debug Enable libclamav's debug messages
--quiet Only output error messages
--stdout Write to stdout instead of stderr. Does not affect 'debug' messages.
--no-summary Disable summary at end of scanning
--infected -i Only print infected files
--suppress-ok-results -o Skip printing OK files
--bell Sound bell on virus detection
--tempdir=DIRECTORY Create temporary files in DIRECTORY
--leave-temps[=yes/no(*)] Do not remove temporary files
--gen-json[=yes/no(*)] Generate JSON description of scanned file(s). JSON will be printed and also-
dropped to the temp directory if --leave-temps is enabled.
--database=FILE/DIR -d FILE/DIR Load virus database from FILE or load all supported db files from DIR
--official-db-only[=yes/no(*)] Only load official signatures
--log=FILE -l FILE Save scan report to FILE
--recursive[=yes/no(*)] -r Scan subdirectories recursively
--allmatch[=yes/no(*)] -z Continue scanning within file after finding a match
--cross-fs[=yes(*)/no] Scan files and directories on other filesystems
--follow-dir-symlinks[=0/1(*)/2] Follow directory symlinks (0 = never, 1 = direct, 2 = always)
--follow-file-symlinks[=0/1(*)/2] Follow file symlinks (0 = never, 1 = direct, 2 = always)
--file-list=FILE -f FILE Scan files from FILE
--remove[=yes/no(*)] Remove infected files. Be careful!
--move=DIRECTORY Move infected files into DIRECTORY
--copy=DIRECTORY Copy infected files into DIRECTORY
--exclude=REGEX Don't scan file names matching REGEX
--exclude-dir=REGEX Don't scan directories matching REGEX
--include=REGEX Only scan file names matching REGEX
--include-dir=REGEX Only scan directories matching REGEX
--bytecode[=yes(*)/no] Load bytecode from the database
--bytecode-unsigned[=yes/no(*)] Load unsigned bytecode
**Caution**: You should NEVER run bytecode signatures from untrusted sources.
Doing so may result in arbitrary code execution.
--bytecode-timeout=N Set bytecode timeout (in milliseconds)
--statistics[=none(*)/bytecode/pcre] Collect and print execution statistics
--detect-pua[=yes/no(*)] Detect Possibly Unwanted Applications
--exclude-pua=CAT Skip PUA sigs of category CAT
--include-pua=CAT Load PUA sigs of category CAT
--detect-structured[=yes/no(*)] Detect structured data (SSN, Credit Card)
--structured-ssn-format=X SSN format (0=normal,1=stripped,2=both)
--structured-ssn-count=N Min SSN count to generate a detect
--structured-cc-count=N Min CC count to generate a detect
--structured-cc-mode=X CC mode (0=credit debit and private label, 1=credit cards only
--scan-mail[=yes(*)/no] Scan mail files
--phishing-sigs[=yes(*)/no] Enable email signature-based phishing detection
--phishing-scan-urls[=yes(*)/no] Enable URL signature-based phishing detection
--heuristic-alerts[=yes(*)/no] Heuristic alerts
--heuristic-scan-precedence[=yes/no(*)] Stop scanning as soon as a heuristic match is found
--normalize[=yes(*)/no] Normalize html, script, and text files. Use normalize=no for yara compatibility
--scan-pe[=yes(*)/no] Scan PE files
--scan-elf[=yes(*)/no] Scan ELF files
--scan-ole2[=yes(*)/no] Scan OLE2 containers
--scan-pdf[=yes(*)/no] Scan PDF files
--scan-swf[=yes(*)/no] Scan SWF files
--scan-html[=yes(*)/no] Scan HTML files
--scan-xmldocs[=yes(*)/no] Scan xml-based document files
--scan-hwp3[=yes(*)/no] Scan HWP3 files
--scan-archive[=yes(*)/no] Scan archive files (supported by libclamav)
--alert-broken[=yes/no(*)] Alert on broken executable files (PE & ELF)
--alert-broken-media[=yes/no(*)] Alert on broken graphics files (JPEG, TIFF, PNG, GIF)
--alert-encrypted[=yes/no(*)] Alert on encrypted archives and documents
--alert-encrypted-archive[=yes/no(*)] Alert on encrypted archives
--alert-encrypted-doc[=yes/no(*)] Alert on encrypted documents
--alert-macros[=yes/no(*)] Alert on OLE2 files containing VBA macros
--alert-exceeds-max[=yes/no(*)] Alert on files that exceed max file size, max scan size, or max recursion limit
--alert-phishing-ssl[=yes/no(*)] Alert on emails containing SSL mismatches in URLs
--alert-phishing-cloak[=yes/no(*)] Alert on emails containing cloaked URLs
--alert-partition-intersection[=yes/no(*)] Alert on raw DMG image files containing partition intersections
--nocerts Disable authenticode certificate chain verification in PE files
--dumpcerts Dump authenticode certificate chain in PE files
--max-scantime=#n Scan time longer than this will be skipped and assumed clean (milliseconds)
--max-filesize=#n Files larger than this will be skipped and assumed clean
--max-scansize=#n The maximum amount of data to scan for each container file (**)
--max-files=#n The maximum number of files to scan for each container file (**)
--max-recursion=#n Maximum archive recursion level for container file (**)
--max-dir-recursion=#n Maximum directory recursion level
--max-embeddedpe=#n Maximum size file to check for embedded PE
--max-htmlnormalize=#n Maximum size of HTML file to normalize
--max-htmlnotags=#n Maximum size of normalized HTML file to scan
--max-scriptnormalize=#n Maximum size of script file to normalize
--max-ziptypercg=#n Maximum size zip to type reanalyze
--max-partitions=#n Maximum number of partitions in disk image to be scanned
--max-iconspe=#n Maximum number of icons in PE file to be scanned
--max-rechwp3=#n Maximum recursive calls to HWP3 parsing function
--pcre-match-limit=#n Maximum calls to the PCRE match function.
--pcre-recmatch-limit=#n Maximum recursive calls to the PCRE match function.
--pcre-max-filesize=#n Maximum size file to perform PCRE subsig matching.
--disable-cache Disable caching and cache checks for hash sums of scanned files.
Pass in - as the filename for stdin.
(*) Default scan settings
(**) Certain files (e.g. documents, archives, etc.) may in turn contain other
files inside. The above options ensure safe processing of this kind of data.
Bjr,
Bien mais une fois téléchargé et installé, s’exécute automatiquement et prend la totalité des ressources du NAS. Résultat : NAS indisponible pendant plusieurs heures !
Vu l'utilité de cet AV; à éviter. Je désinstalle dès que mon NAS m'aura rendu la main :)
Bien cdlt.
FD
il faut correctement le paramétrer :mrgreen:
il scanne par défaut tout ce qu'il y a dans /share en suivant les liens symbolique..
et il décompresse toutes les archives pour fouiller si un saleté est dedans (j'ai même inclus les .cab, .iso et image PE de Microsoft)
désolé pas trouvé de Web interface pour faire les choses biens.. il faut mettre les mains dans le cambouis afin de l'optimiser
Et maintenant après avoir redémarré le NAS, l'écran connexion s'affiche pendant des plombes et ça freeze. Donc QClamAV n'est pas à éviter mais à fuir !!!!
Désolé mais pour l'optimiser il faut avoir accès à quelque chose et pour le moment je n'ai accès à rien.
Je suis en télétravail et depuis que j'ai installé ce ClamAVmachin je n'ai plus d'accès à mon NAS, ni messagerie, etc... et je ne peux plus bosser. :x :evil:
Je laisse chacun tirer la moralité de cet AV.
Bien cdlt
FD
Epilogue :
Pour info j'ai fini par retrouver l'accès au NAS; Il a fini par me rendre la main après des heures.
A noter : QclamAV a désynchronisé mon RAID1 ! Depuis le redémarrage, le NAS il est en train de resynchroniser le groupe RAID 1 . Et il en a encore pour des heures...
Bizarre tout ça.
Cdlt
FD
